Like Tree42Likes
Old 12-16-2013, 06:41 PM   #1276
Trader Rating: 41 (100%+)
Also try lighter Tube lube in the rear
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 12-16-2013, 08:43 PM   #1277
avs
avs's Avatar
Originally Posted by tim fry View Post
What would you guys recommend to stop the rear end being lose?
I was running transverse but have gone back inline and its lose at the end of our large sweeper just before
getting back on power.
if your inline layout moved the cg forward compared to the transverse layout, then it might make sense to remove droop front and rear to reduce the forward weight transfer in off power corners?
you didn't mention what you did with the side and front spring stiffness. It seems inline layouts tend to have softer side springs and possibly stiffer front springs. (but I have yet to be faster with a inline layout compared to transverse, so I may be full of _it.)
Tony Shimko
avs is offline   Reply With Quote
Old 12-17-2013, 03:01 PM   #1278
tim fry's Avatar
Front end is basically the same as I have always run it.
Ive got the rear fairly soft with blue sides and 7k damper fluid.
tim fry is offline   Reply With Quote
Old 12-17-2013, 11:19 PM   #1279
Try less rear droop
Apex RC
www.apexrc.com - Hawaii's #1 RC Proshop
Share & Like Our Page:https://www.facebook.com/ApexRCProshop
Win free stuff!
Old 12-18-2013, 11:31 AM   #1280
Can you post your entire setup
Jason Deadman
Old 12-18-2013, 12:52 PM   #1281
tim fry's Avatar
Front
.50 springs
5 deg blocks
1 spacer in front 2 behind top arm
1 deg camber
Thick roll centre spacer
Top brace
Centre
White spring
30wt oil
Rear
7k fluid
Blue side springs just touching
Magenta front
Pink rear
It seemed as if it was fine until I let off power at the end of the sweeper and then it became lose. It was ok everywhere else.
Old 12-18-2013, 01:30 PM   #1282
That's a really soft setup for Pink rears. If you have yellow or "Greylows" Try that.
Do you get any build up of black gunk anywhere on the bottom of the chassis. If so you might be too soft in the springs and tubes to get the most out the tire traction.
Also ride height? For a Low traction track go up higher than normal helps with the weight transfer.
Also to smooth out the steering try double Pink fronts. With Magenta's I find they bite too hard sometimes which can make a simple corner hard to navigate
Jason Deadman
Old 12-18-2013, 02:42 PM   #1283
tim fry's Avatar
No noticeable marks on the chassis. We all tend to run that combo of compounds as we are running 10.5t. I might try double pink though as it might help.
Old 12-19-2013, 11:33 AM   #1284
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
Tim, blue sides on the inline should be the correct springs, whites for transverse. 7k in the tubes for inline strike me as a bit light, but it's certainly not going to cause "loose" at the end. 10.5 is pretty zippy and not to be underestimated. Two things might be happening: the magenta fronts maybe picking up grip as the run progresses and the pink rears could be getting some fuzz wrapped on them towards the end. Add both of these up equals a mess to drive. I have really fallen in love with the greene crc rears for mod with a magenta front. Start to finish, all the way down to the wheel, best combo I've been on to date. Don't forget to really round those side walls over!
You may find that transverse for 10.5 a bit more accommodating.
Brian
Stay dialed my friends!
www.slapmastertools.com
Team Roche USA
Team Orca orcharc.com
Slapmaster6000 is offline   Reply With Quote
Old 12-23-2013, 02:33 PM   #1285
tobamiester's Avatar
Trader Rating: 281 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
Anyone have the part# for the longer front carbon top plate for the Xti ? Is it 3276 ?ordered the shorter one by mistake. And is it worth running ? Does it affect handling?
Thanks in advance
tobamiester is offline   Reply With Quote
Old 12-23-2013, 07:36 PM   #1286
Thanks in advance
3276 is correct for running the short arms, 3278 is for long arms. It strengthens and helps alighn the front end. It will reduce steering a little bit though because it reduces flex in the front end. Its a good tuning part to have.
avink007 is offline   Reply With Quote
Old 12-23-2013, 07:44 PM   #1287
Thanks, yeah I was a little concerned with loss of flex but I'll give it a try and see how it feels on my local track/layout.
Old 01-11-2014, 04:52 AM   #1288
Default manual for altered ego
hi,
does anyone got the manual for altered ego for download?
just wanna take a look before purchase.
thanks thanks
My blog: http://ongbenghui.blogspot.com
ongbenghui is offline   Reply With Quote
Old 01-11-2014, 08:25 AM   #1289
Originally Posted by ongbenghui View Post
hi,
thanks thanks
Nope there isn't one. I just built my kit this week. You get a stock Xti manual and then the transverse instructions, and then have to sort of pull the two together. Its fairly straight forward
I took a ton of pictures during my build and was gonna do a quick blog post to help others. PM me if you have any questions.
Old 01-11-2014, 11:13 PM   #1290
Hi,
I am curious how does the servo mount works. Does the servo need to be in front and horn behind? Ie, servo weight is forward, vs the traditional servo behind, horn in front like every other 1/12? Any pics on that?
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 567 11-20-2017 04:06 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
