Like Tree42Likes
Old 12-07-2013, 11:45 AM   #1261
avs
avs's Avatar
Originally Posted by JamesL_71 View Post
Edit: Again, this may be the angle of the pic or just my eyesight failing me... but it also looks like the inside of your front upper arms are angled to the outside pretty substantially?
maybe its the camera lens, but it looks like the upper pivot ball stud is angled back. maybe you could try to measure the caster. it does seem like you may have excessive caster due to the pivot ball stud threading into upper arm at an angle.
Tony Shimko
avs is offline   Reply With Quote
Old 12-07-2013, 01:05 PM   #1262
tobamiester's Avatar
Trader Rating: 281 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
Originally Posted by RedBullFiXX View Post
How much wheel lock are you using to get around the track ?
That much wear on Pink X2, would suggest you have a bit of understeer
How many runs till the tire looks like that
Are you rotating tires every 8m run ?
3 to 4' turning circles is a baseline
Yeah i've usually been running Lilacs but running the PinkX2 tomorrow to try.
I'd been getting basically one raceday out of tires (practice pack or two, 3 x 8 mins quals and main). Yes been rotating.
Good to know, maybe I have way too much steering travel. Will test that tomorrow
tobamiester is offline   Reply With Quote
Old 12-07-2013, 01:08 PM   #1263
Originally Posted by InspGadgt View Post
Those aluminum caster blocks do have a tendency to bend...from that picture angle they do look like they may have bent. I would double check those...plus what everyone else suggested.
I have a set of stock plastic ones, will compare.
Thanks will check that too..
Old 12-07-2013, 02:58 PM   #1264
kiwidave72's Avatar
Send a message via MSN to kiwidave72
Default tarmac setup
hi guys,
im new to this 1/12th class, and the club has put down a new tarmac surface, and can now take out my xti (with the alter ego chassis) for a play.
ive heard that pan cars are very different to setup than touring cars.
so could someone point me to a really good start point setup sheet for tarmac, and some good advice on what to change in the front / rear.
ill be racing with a 10.5 with boost/turbo for now.
cheers
David.
Yokomo YZ-4 / Speedpassion 17.5. / Hobbywing v3 ESC
Yokomo BD7 / Speedpassion 13.5 v3. / Hobbywing v3 ESC
kiwidave72 is offline   Reply With Quote
Old 12-07-2013, 09:27 PM   #1265
Slapmaster makes a handy little tool for checking caster
Old 12-10-2013, 07:29 AM   #1266
Thanks everyone for there help and advise. I took the Alum Casterblocks off and they did seem a little warped. Put a set of stock ones in and it looked much better.
Going to look into those Slapmaster tools
Old 12-16-2013, 01:39 AM   #1267
corally's Avatar
Hello
i have two small trouble with my Xti...
1) use a SRG-HR servo, but when exit from curve to go on straight line i always put a small correction for realign the car..i use 5 caster block and 0.5 camber ...yestardy i chenge with 0 degree and seem was solved..
2) when open gas on straight the car push on one side..i try to twek the car
but not is sufficient.
Some suggestion?
Thanks !
corally is offline   Reply With Quote
Old 12-16-2013, 06:40 AM   #1268
Trader Rating: 41 (100%+)
Sounds like your Car is not balanced left to right. Get some balance buttons and remove the rear pod then balance your car. will make things much easier.
Next check your front springs for the same height one might have collapsed and is now shorter.
check for binding in the rear pod.
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 12-16-2013, 06:55 AM   #1269
corally's Avatar
Why remove rear pod?..sorry what is "balance button"..? ths small poit to fit in center hole in the chassis?
I not think about this...i check
When check tweak is better to leave the dumper tube?
THANKS!
Old 12-16-2013, 09:31 AM   #1270
THANKS!
Balance buttons http://teamirsrc.com/index.php?main_...roducts_id=202 or http://www.hudy.net/xhudy/products/p...hp?prod_id=173
It is better to take off the tubes when you check tweak on the car.
avink007 is offline   Reply With Quote
Old 12-16-2013, 09:41 AM   #1271
corally's Avatar
Thks
i have old style Hudy balance button...i should remove the rear pod ?
Old 12-16-2013, 10:11 AM   #1272
Thks
Yes remove the rear pod then balance the main chassis. You can also balance the pod on its own.
Old 12-16-2013, 11:55 AM   #1273
Above answers are correct.
Spend the time getting your car balanced and not trying to get it tweaked later. If you are spot on you can run the side springs with little to no preload. which will make for a more even handling car
Jason Deadman
Old 12-16-2013, 12:06 PM   #1274
tim fry's Avatar
What would you guys recommend to stop the rear end being lose?
I was running transverse but have gone back inline and its lose at the end of our large sweeper just before
getting back on power.
tim fry is offline   Reply With Quote
Old 12-16-2013, 01:03 PM   #1275
DesertRat's Avatar
Your results may vary, but one factor I've seen affect the transition between high-speed (on-power sweepers, end of straight, things like that) and low-speed cornering is the front end alignment. Sight unseen, you might want to try a different reactive caster block, static caster, toe, or camber. If your tires wear flat, you may be pretty close, but a little may go a long way. If you don't want to change the front alignment, changing to a different front kingpin tube lube may have some effect.
Hard to say, really.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. Losi 22 4.0, CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 567 11-20-2017 04:06 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
MrHistory
