Like Tree42Likes
Old 09-16-2013, 07:40 AM   #1171
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
I ran over the weekend at NORCAR's annual Vegas Warm-up race.
A TQ and win for my XTi ride!
Here's a pic and the set up I used.
Take note, the CRC carpet was just put down on a new subfloor and the traction was very high!
Set up:
Front:
1.60" grays, 1/2 inside SXT, sidewall glued
.50mm springs (.01" gap between steering block and lower pivot ball)
10* blocks, 2 shims back
1* camber
3.5mm clearance
Rear:
stock shock oil with windtunnel blue "v-hive" spring
CRC blue side springs
15K in tubes, outside elevated
1.65" grays, 3/4 middle SXT, safety glue on seem
3.5mm clearance
1.5mm droop
Notes:
Black Art body
Power Push White Lightening battery
Team Scream motor (Trinity based Killshot)
Hobbywing 1s ESC
Team CRC Xti 1/12th Scale!!-img_0737.jpg
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 09-16-2013, 09:12 AM   #1172
Thanks for the update SG1! I'm going to have to try the gray front/ gray rear tire combo.
AL
www.carcar.ca
ALBOP is offline   Reply With Quote
Old 09-16-2013, 11:45 AM   #1173
tdu verney's Avatar
Sg1 great job! Congrat's for sure!!!
tdu verney is online now   Reply With Quote
Old 09-16-2013, 01:10 PM   #1174
Is that a 17.5 motor?
Old 09-16-2013, 01:33 PM   #1175
sg1
sg1's Avatar
It is!
Killshot RPM stator
Old 09-16-2013, 03:50 PM   #1176
I)arkness's Avatar
whats the go with cutting the battery/ shock brace? or is it just to get easier access to plugging in lipo
B.Portelli
Hyper RC - RAB Hobbies - Wild Turbo Fans
Race Opt - Team Powers
I)arkness is offline   Reply With Quote
Old 09-16-2013, 04:00 PM   #1177
sg1
sg1's Avatar
Didn't need it, so I cut it off
Old 09-16-2013, 04:39 PM   #1178
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Thanks for sharing Wayne. The transparency is nice.
Old 09-16-2013, 11:05 PM   #1179
DriftDreamer06's Avatar
Set up:
Front:
1* camber
3.5mm clearance
Rear:
3.5mm clearance
1.5mm droop
Notes:
Black Art body
Hobbywing 1s ESC
Attachment 1112805
thank you for the info!
what manufactor for the gray tires? looks like smooth rim?
what kind of glue on the seem?
what was the feeling change from a standard spring to the bee-hive? i get linear and progressive but car feel change?
DriftDreamer06 is offline   Reply With Quote
Old 09-17-2013, 03:07 AM   #1180
sg1
sg1's Avatar
They are CRC tires, I put adhesive wheel dots on.
For glue, I have some cheap brush on super glue from Walmart
Center spring, I thought the car was more balanced from high to low speed on the high bite track.
I just got all the new CRC springs in (center shock and side) and haven't tried them yet I'll be trying those in 2 weeks (next road race) and let you know which ones work the best at my track
Old 09-22-2013, 06:44 AM   #1181
tim fry's Avatar
Been running my xti with the standard chassis mod to run the cell across the car not the altered ego. With what I would consider a minor hit it seems to pop the centre shock off. I have replaced the plastic parts but its not much better. Any ideas?
tim fry is offline   Reply With Quote
Old 09-22-2013, 09:56 AM   #1182
Check to see that your battery isn't causing it. Shim the shock up 1-2 mm for clearance and see if that helps.
AWD
Old 09-23-2013, 10:27 AM   #1183
Hey Guys,
On the Altered Ego chassis can the servo be mounted in the standard configuration (servo saver facing foward) and if so are there holes in the chassis to mount the angle type servo mounts (Aluminum Servo Mount - 4 hole Anodized 4017) ?
BIGBOT is offline   Reply With Quote
Old 09-23-2013, 11:21 AM   #1184
DesertRat's Avatar
In short, yes. I have mine mounted on the angled mounts, I feel the car just runs better that way.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. Losi 22 4.0, CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 10-02-2013, 03:59 PM   #1185
Trader Rating: 20 (100%+)
Sorry if this has been covered, I can't find it.
If you want to run the solid chassis...
http://www.teamcrc.com/crc/modules.p...prodID=7719466
What else do you need?
Longer side link 3281?
Do you need the transverse kit also?
Where do you mount the side springs?
Thanks,
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 565 09-25-2017 05:19 PM
