Like Tree42Likes
Old 06-27-2013, 05:35 PM   #1141
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Originally Posted by ALBOP View Post
Can you let us know what your rollout was?
Cheers,
In the main I ran a Team Scream tuned Kill Shot with 65* of timing with 49-76 gearing.
Rear tires were 1.65". Motor temp was 130's*f after 8 minutes and lap times started at 9.8's and finished 10.1/10.2's.
I also tried 50* of timing with a 56-76 gearing and turned almost identical times.
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 06-29-2013, 03:48 PM   #1142
Trader Rating: 72 (100%+)
Anybody got a Hobbywing 1s (the old version, not the new v3.1 version) laying around that you want to get rid of? If so, PM me, as I need to pick up one.
Bill S
waswadener is offline   Reply With Quote
Old 06-29-2013, 07:37 PM   #1143
avs
avs's Avatar
Bill S
how much are you trying to save? CRC is blowing them out for $99 and hobbypartz for $89. those are both very good values
Tony Shimko
avs is offline   Reply With Quote
Old 06-29-2013, 10:07 PM   #1144
Car Breaker's Avatar
I ran XI/XL and like it a lot. after switching to XtI for two day I crush the car onto the concrete wall by accident, I didn't feel sad at all. so I go back to XI/XL. Xti to me is a race car. everything has to be well done before placing the car into track. in my local public track, we normally run the same tire without truing it, therefore fast ride height adjustment is very important. on Xti the front ride height is very difficult without dropping parts. the rear is nice except when tire has uneven wear out the drive shaft will not sit horizontally well hence affecting the power transfer a bit. the rear slide pod is a nice idea, just need to make some marking on the pod to allow easier balance of the drive shaft.
to me the ideal car for my local track is a XL with front mount servo and a marked slider pod not to mention a minimum cut off of the chassis. The Japanese version XL chassis is nice, all it need is the front mount servo cutting.
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 07-13-2013, 05:40 PM   #1145
Csaari77's Avatar
Trader Rating: 34 (100%+)
Finally got my car back on the track after a long layoff. I really gave the lower pod plate made out of the new material a workout and it passed with flying colors! The track had a kink in a high speed section that had a gap in the pipes that had ripped a few arms off TCs during the day. I managed to catch the right rear tire on it and watch the car spin down the straight. An impact like that would have ripped the entire pod off the car with the old material. This time I was able to drive away and finish the race!
Big thumbs up to CRC for addressing the problem.
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 07-16-2013, 08:21 AM   #1146
danthrc's Avatar
What body do you guys lean toward for the Xti inline config running 13.5?
danthrc is offline   Reply With Quote
Old 07-16-2013, 01:56 PM   #1147
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
AMR 12 or TR-12. I personally like the AMR best, but I haven't driven a lot with the TR.
Old 08-01-2013, 10:47 AM   #1148
CanyonCarverR1's Avatar
Originally Posted by sg1 View Post
Just thought I'd share a set up I used last weekend at my home track NORCAR at the Gate. It's 90 x 40 and high bite carpet. Fairly open layout.
Front:
Gray tires 1.58"
.50mm springs
1* camber
10* castor blocks (2 shims back)
50k lube on kingpins
.01" gap between stearing block and lower a-arm pivot under weight
3mm clearance
Rear:
Magenta tires 1.65"
15k lube in tubes (outside elevated with high roll center balls)
30wt in shock with windtunnel "V-hive" red spring
blue side springs (just touching)
1.5mm droop
3.5mm clearance
Other info:
Team Scream 17.5 (Kill shot based)
Power Push white lightening battery
SXT traction
TQ wire
If you have any questions feel free to ask
You clearly know this car. Some of us have been asking or a starting asphalt setup (med traction, xti, not altered ego), can you offer some suggestions?
CanyonCarverR1 is offline   Reply With Quote
Old 08-01-2013, 11:01 AM   #1149
sg1
sg1's Avatar
I have never run this car on asphalt.
Let me see If I can get ahold of a few CRC guys who have and see what they have for a starting point.
Old 08-01-2013, 11:14 AM   #1150
That would be great, thanks!
Old 08-03-2013, 10:13 AM   #1151
I noticed in this picture the side springs mounted in a more medial position that my instructions show. What would be the handling affect of this?
Team CRC Xti 1/12th Scale!!-harpercrc-2%5B1%5D.jpg
Old 08-04-2013, 04:37 PM   #1152
danthrc's Avatar
Put mine together and ran it for the first time with the factory setup and the car was outstanding. Very balanced and easy to drive. Was running 13.5 blinky but had a low roll out. Increased that and will test more this week.
Old 08-04-2013, 05:05 PM   #1153
hey guys I'm starting to consider this chassis for the up coming season. I believe we might be going 13.5 blinky so would inline or T set up be more beneficial.
I also noticed that there is a alter ego chassis kit avail too. just curious what that might be all about.
Cheers
cyrrus is offline   Reply With Quote
Old 08-04-2013, 07:19 PM   #1154
Cheers
The stock chassis is in-line only. The Altered Ego kit allows you to run the car with the battery crosswise. I run mine in-line in 13.5 blinky and like it a lot. But it comes down to personal preference.
Old 08-04-2013, 08:23 PM   #1155
I)arkness's Avatar
did anyone else running the spektrum h5020g servo have issues with mounting? as the only way i could get it o fit was to dremel the carbon brace the arms mount onto.
im hoping it hasn't weakened it to much that it will not crack in an accident?
B.Portelli
Hyper RC - RAB Hobbies - Wild Turbo Fans
Race Opt - Team Powers
I)arkness is offline   Reply With Quote
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 567 Yesterday 04:06 PM
