Like Tree42Likes
Old 06-05-2013, 03:16 PM   #1111
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I usually go with softer center and/or side springs.
AWD
Old 06-05-2013, 10:38 PM   #1112
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
Originally Posted by tim fry View Post
Has anyone got any tips for calming the front end down on initial turn in?
Any front tire diameter over 42 would be considered "huge" and would cause this. So would camber over 1*.
Stay dialed my friends!
www.slapmastertools.com
Team Roche USA
Team Orca orcharc.com
Slapmaster6000 is offline   Reply With Quote
Old 06-06-2013, 12:35 AM   #1113
tim fry's Avatar
I'm running small tyres and white centre and white sides. I was running red centre but moved to white and this made it better. It just turns in quite quickly making some larger sweepers hard to keep a good line.
tim fry is offline   Reply With Quote
Old 06-06-2013, 02:18 AM   #1114
Try less caster up front. That will affect your corner entry and exit.
Old 06-06-2013, 02:48 AM   #1115
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
I went to blue side springs.
On some layouts I even went to orange.
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 06-06-2013, 08:41 AM   #1116
Old 06-07-2013, 08:01 AM   #1117
Front king pin length; very important! Measure from the bottom of the steering block (right against the king pin) to the bottom of the e-clip groove with the inside jaws of your calipers. Then look at the color of your spring, either black (old ones) or silver (new ones). For black springs, your king pin should measure .406" (10.31mm). Silver should be .401" (10.18mm). If they are uneven lengths or too long, whacky things will happen. These are kind of base numbers, you can be +/- of these, but not much.
Team Roche USA
Old 06-20-2013, 04:59 AM   #1118
Default Gen XTi
Hi.
Can I use the new Slider Rear Pods of Gen XTi in the Gen XL?
bosschick is offline   Reply With Quote
Old 06-20-2013, 08:26 AM   #1119
pmes's Avatar
Slider Pod Conversion for the-Gen-X,XL,Xi + Gen X10
pmes is offline   Reply With Quote
Old 06-20-2013, 09:37 AM   #1120
steveM3's Avatar
What lube are you running? If it's cutting too hard you can go to a lighter lube to calm down the initial reaction.
Steve McNichols
Serpent- Desoto Racing
steveM3 is offline   Reply With Quote
Old 06-20-2013, 02:41 PM   #1121
tim fry's Avatar
I'm running 20k lube but sounds like it might be worth trying 10k
Old 06-20-2013, 03:33 PM   #1122
CypressMidWest's Avatar
10k has been my "go to" fluid for this car. I've been as low as 7k. Because the car tends to transfer so little weight laterally, less dampening is necessary to keep roll in check. Blue side springs are my usual, but like Wayne said, oranges can be beneficial on some layouts. I have my shock mounted one hole further forward than stock on the upperdeck, and I'm running a green spring with 35 wt. Losi oil. This seemed to settle the car down ALOT on exit, without sacrificing any steering into and through the middle of a corner.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 06-20-2013, 03:38 PM   #1123
pmes's Avatar
Anyone use Shur Lube in their tubes?
Old 06-20-2013, 04:24 PM   #1124
tim fry's Avatar
Thanks for the info
Old 06-20-2013, 11:56 PM   #1125
Thanks for the info
No problem. The stock Xti is a very nimble platform. Too many people jump to the altered ego set-up before trying different set-ups to dial in the car. Anything else I can help with, feel free to ask.
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 567 11-20-2017 04:06 PM
