Like Tree42Likes
Old 02-01-2013, 11:28 AM   #916
theatriks's Avatar
Originally Posted by InspGadgt View Post
The slots/holes in those are made to just fit around 8-32nd screws so they are too wide for the lower 4-40 screws and too narrow for going around the plastic lip on the bottom of the suspension arm. You might be able to widen the holes to use under the suspension arm but I'm not sure how viable it is to do that.
thanks dude ...i will try it out tonight at the track.
theatriks is offline   Reply With Quote
Old 02-01-2013, 11:03 PM   #917
Radi0Flyer's Avatar
Originally Posted by Robert_K View Post
What Servo is that?
Regards Robert
Hi Robert,
It's an innexpensive Turnigy servo from HK.
http://www.hobbyking.com/hobbyking/s...dProduct=23467
I didn't expect much from it but it's testing at the specs and is centering good. We'll see how long it lasts.
Sean
I'll drive it til the wheels fall off and burn
Radi0Flyer is offline   Reply With Quote
Old 02-02-2013, 01:22 AM   #918
Wow that's a nice little servo. If the stats hold up that's .07s at 98oz/in! I may have to look into one of those myself!
Old 02-02-2013, 01:35 AM   #919
Robert_K's Avatar
Thanks Sean!
That was exactly what I was thinking ;-)
Regards Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 02-02-2013, 02:44 AM   #920
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
Does anyone know of a link or able to tell me what degree when adding shims to the front arms
So 0 shims = 1.2degrees and 1 shim = blah blah
Having looked at most of this tread I guess it is in another thread
v-dezign // black diamond
Hoot RC for Local Supplies > www.hootrc.com.au
Me_MrTyson is offline   Reply With Quote
Old 02-02-2013, 07:22 AM   #921
theatriks's Avatar
I'm gonna have to try that servo too ...nice find .
I've been trying to find the "recommended " servo the srg-hr but that's impossible to find? Rcmart has been out of stock for months and I cannot find it anywhere else .....redrc article says its the best 12 scale servo but nobody sells it lol idk sometimes I just gotta shake my head and laugh.
Old 02-02-2013, 07:42 AM   #922
choisan's Avatar
luckily i bought 2
choisan is offline   Reply With Quote
Old 02-02-2013, 08:06 AM   #923
theatriks's Avatar
Originally Posted by choisan View Post
luckily i bought 2
where did you buy it and do you want to sell me one lol
Old 02-02-2013, 09:32 AM   #924
theatriks's Avatar
luckily i bought 2
Also what are the stats on the side of the package of that servo....lrp and red rc site is saying 7sec and 5 sec.......and theres one on ebay that shows the box and it says 8 seconds and 10 seconds????? whcih one is it...or are there 2 different srg-hr sanwa 12 scale servos
Old 02-02-2013, 10:13 AM   #925
Radi0Flyer's Avatar
The conversion is approx. 14 oz-in per kg-cm. 1.1 kg-cm @ 4.8v equates to only 15.4 oz-in.
Not really a strong servo at all but adequate to steer a 1/12th pan car IMO.
Thanks Sean!
Regards Robert
I'm a sucker always looking for the perfect cheap servo LOL.
I also picked up one of these and might use it to replace the Futaba s132H in my Associated 1/12th car.
It's the same size as the 212 but specs out much stronger and has an all-alloy case for cooling. It's a bit heavier too but only by several grams. 2.5kg-cm @4.8v = 35 oz-in.
As a side note, these servos are all too fast for me and even on 4-cell (or 1s) I will likely have to turn down the expo on the steering. I got used to the Hitec HS81 in my Trinity MCR but find that I could use just a bit faster than that. The Hitec is a durable servo though and has never given me a problem.
Sean
Old 02-02-2013, 12:03 PM   #926
Ah...I guess the unit converter site I went to didn't do the conversion right.
As for the HiTec...you've been lucky. I've seen far too many of their servos fail and have centering issues to even consider them.
Old 02-02-2013, 12:13 PM   #927
BCbud's Avatar
Trader Rating: 37 (100%+)
Sean
Will a servo saver fit that Turnigy servo? I bought this one and the servo shaft is a lot smaller than the standard.
http://www.hobbyking.com/hobbyking/s...dProduct=22687
Xray NT1 - Xray T4 2013 TC - Xray T4 2013 VTA - CRCgenX10 - CRCgenX - CRCgenXi - Slash 4X4 with LCG conversion -Associated RC8Be - Xray XB4 - DX3R PRO
Recycled teenager.
www.irocc.ca ; www.corvictoria.com ; http://www.wcics.ca/
I will not send Pay Pal as a gift or add fees to the price so DO NOT ASK!
BCbud is offline   Reply With Quote
Old 02-02-2013, 12:55 PM   #928
Radi0Flyer's Avatar
Nope.
I hadn't noticed that. I guess I will have to use it on one of my aircraft if I can't find a servo saver that fits.
Sean
Old 02-03-2013, 05:33 AM   #929
choisan's Avatar
my friend helped me to buy from Hong Kong, he said hr been but available for a while, sold out immediately.
Old 02-06-2013, 07:59 AM   #930
Trader Rating: 23 (100%+)
So what version of the car is the majority running for 17.5?
bmcallister is offline   Reply With Quote
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 567 11-20-2017 04:06 PM
