Like Tree42Likes
Old 01-19-2013, 05:24 PM   #901
Well while tearing down my car to replace the lower pod plate I broke...I discovered I had also cracked the front of the chassis around the front left body post I've sent CRC an e-mail and hope to get it replaced soon. But I really wanted to run the car still. I remembered the old DA chassis used to come with a brace piece that went across where the body mounts attach. Early pan cars were very prone to this area cracking so the brace was to reinforce that area. I decided to make one myself out of some scrap carbon fiber. I think it came out pretty good and should solve the problem for awhile. It does make pulling out the front ride height shim a bit of a pain but I'll deal with it.
Old 01-19-2013, 11:00 PM   #902
bvoltz's Avatar
Trader Rating: 44 (100%+)
I saw today at the track a shim kit used for ride height that you place under the front Strut. Is the Part number 4260 Link? I have the washer shims (spacers) but they are a pain in the butt to change the ride height...
Can anyone confirm these are the correct ones?
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 01-20-2013, 01:39 AM   #903
Yes 4260 is the part number for the front ride height shims.
http://www.teamcrc.com/crc/modules.p...prodID=7719457
Old 01-20-2013, 04:09 AM   #904
Pulse_'s Avatar
Just to let you know I'm selliing a new CRC XTi complete in its box if anyone is interested drop me a pm I can ship it everywhere in Europe
edit: car is now sold
https://www.youtube.com/channel/UC1CAwFfuz1K3chBSVpIlSew
Pulse_ is offline   Reply With Quote
Old 01-30-2013, 12:53 PM   #905
theatriks's Avatar
Hey guys im a sedan guy getting into 12 scale ....bought an xti a while back and finally a 12 scale night opened up ....my question is ...would a regular xti set up work on a 30 x 20 track ...it very small track but thats all we got ......or should some specific things be changed for such a small tight track?
theatriks is offline   Reply With Quote
Old 01-30-2013, 01:51 PM   #906
theatriks's Avatar
http://www.petitrc.com/reglages/crc/...0106/1-800.jpg
anybody know which front brace this is 3276 or 3278?
Old 01-30-2013, 02:38 PM   #907
Radi0Flyer's Avatar
Loving this car already. It was so easy to assemble. I opened the box, lots of parts. Closed the box...
...shook it around a bit...
...opened the box again...
...done.
This is my first 1/12 since my Trinity MCR...and 4-cell NiCds...and brushed motors.
1s LiPo, brushless and links are all new to me. Any driving or setup tips for migrating from a t-bar car to this bad boy?
Sean
I'll drive it til the wheels fall off and burn
Radi0Flyer is offline   Reply With Quote
Old 01-30-2013, 04:48 PM   #908
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
Most of the Team is in Fl racing 'Birds. I stayed home. Since that is mounted with the short arms, it's #3276. #3278 is for the long arm (which is a shorter length top brace).
Stay dialed my friends!
www.slapmastertools.com
Team Roche USA
Team Orca orcharc.com
Slapmaster6000 is offline   Reply With Quote
Old 01-30-2013, 05:33 PM   #909
Yes, #4260 is the preferred shim. Those little dinky washers are a pita, but at least they were included with the kit to get you started. For what it's worth, if you bought two of those shim kits, you can get as much as 2 yellows under the arms and still get the arms aligned into the horseshoe. Using the fork shims between the chassis and the horseshoe again are a pita but you can use larger tires.
For what it's worth, you can get 42 fronts on the car with 2 yellows under the arms and get 3.25 ride height, you can run to the wheels with none. This is with no shims between the chassis and horseshoe. If you need to run bigger fronts, you will need the fork shims.
Is that clear as mud?
Team Roche USA
Old 01-30-2013, 10:34 PM   #910
SLOWINSLOWOUT's Avatar
Trader Rating: 19 (100%+)
Well, seems that I just ordered two of these cars. Hope it is as good as everyone says it is. It will replace my X12, which is a very easy car to drive, but, it is getting very loose(as in, the parts on the car) with only 4-5 race days on it. Not impressed. Thus the change of brands. I had recently got a used X 10LE, and was impressed with it, for a used car, it was all still tight and looked to be of better design. So, it made sense to me to get the same brand to consolidate parts spares.
I have read through this thread, and a lot of good stuff here, is there some set up sheets and base setting suggestions for 17.5 boosted please.
SLOWINSLOWOUT is offline   Reply With Quote
Old 01-31-2013, 09:02 AM   #911
theatriks's Avatar
What are you guys doing for tire care ....after trueing should i be C A ing the edges or rounding the edges off to keep them from chunking?
Old 01-31-2013, 09:16 AM   #912
theatriks's Avatar
For anybody interested in tire truing methods i found this ....seems pretty legit
http://www.petitrc.com/Tech/XRC_True...ueFoamTire.htm
Old 02-01-2013, 09:33 AM   #913
theatriks's Avatar
i ordered 4262 by accident .....they look like they might work have you tried these before?
Old 02-01-2013, 10:26 AM   #914
Robert_K's Avatar
Originally Posted by Radi0Flyer View Post
What Servo is that?
Regards Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 02-01-2013, 11:16 AM   #915
The slots/holes in those are made to just fit around 8-32nd screws so they are too wide for the lower 4-40 screws and too narrow for going around the plastic lip on the bottom of the suspension arm. You might be able to widen the holes to use under the suspension arm but I'm not sure how viable it is to do that.
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 565 09-25-2017 05:19 PM
