Like Tree42Likes
Old 11-10-2012, 09:34 PM   #571
Trader Rating: 16 (100%+)
I just picked up a XTI kit. does anyone know of a way to run the short CRC battery with this kit? Thanks
brettweir78 is offline   Reply With Quote
Old 11-10-2012, 09:52 PM   #572
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
You might be able to fit a layer of servo tape on the battery and still get it under the shock mount.
Old 11-11-2012, 02:11 AM   #573
I servo taped my shorty pack to the upper brace. That way I can remove the battery with just a couple of screws and not have to mess with battery tape.
Old 11-13-2012, 05:04 PM   #574
theatriks's Avatar
Seeing how this is my first 12 scale ....hows gearing work?......is it the same as F1?
theatriks is offline   Reply With Quote
Old 11-13-2012, 05:14 PM   #575
That depends if you are thinking of rubber tire F1 or foam...With foam we go by roll-out rather than straight up gear ratio because the diameter of the tires affects the final gearing traits. With rubber tire F1 some people do roll-out and some people just gear ratio. I think these days most people are using roll-out.
Old 11-13-2012, 05:48 PM   #576
theatriks's Avatar
Ya that's what I mean by F1 ...meaning foam tire F1 .. Measuring tire diameter x Pie yadda yadda yadda.....am I still shooting for a roll out in between 5-6
Old 11-13-2012, 07:27 PM   #577
There's an app for that
Old 11-13-2012, 07:33 PM   #578
Danny-b23's Avatar
I'm relatively new to this whole 1/12 thing. Someone please post a picture or a diagram or something as to how to cram a Tekin RS Pro, a TQ Booster, a SR3100 Rx, and a PT into one of these things. I know it shouldn't really be a problem, but I'm lost as to where stuff will fit under the body, where I can run wire so it won't tweak the car, and where stuff can sit that it won't come loose and get damaged or get hit.
EDIT: Inline only. Transverse I know I could do it easily.
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 11-13-2012, 07:56 PM   #579
theatriks's Avatar
Lol I know theres an app for it ...I want to know what rollout number should you shoot for ......you know what Nevermind I'm gonna gear by temperature
Old 11-13-2012, 08:34 PM   #580
LonnyJ1950's Avatar
Blinky or boosted, what motor? More information please.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 11-14-2012, 10:01 AM   #581
bvoltz's Avatar
Trader Rating: 44 (100%+)
Last night I ran the car and must say it was very easy to drive and fun...
Now for the questions from a 1/12th newbie (you have been given notice )....
It worked best with 2.5 of front camber (because I did not have a way to measure or a setup board for 1/12th, someone else did and changed it to 1, and the lap times got slower... I need to at .5.... Interesting...
I also having a mind problem with this (it's me....) but to set pod droop the ball end on the center shock does not screw on, it turns to a point then spins... So not sure how to use this to set the pod drop... maybe the end is just bad...
I also was running 2.5mm front RH, 3.0mm Center and 3.5 Rear... Again, this was me not paying attention. I really thought I had it at 3.5, 3.0 and 3.5....
As we corrected issues, I noticed it got harder to drive and the lap times got slower.... I found this interesting....
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 11-14-2012, 10:07 AM   #582
bvoltz's Avatar
Will these work on the Xti? 4262 - Optional Precision Front Ride Height Shims
Old 11-14-2012, 10:31 AM   #583
theatriks's Avatar
Sure that would help eh ....I'm gonna just try 17.5 blinky to start with....the motor is my cheater corally pro red but this is just for practice day ...thanks
Old 11-14-2012, 12:03 PM   #584
So i take it the front ride height shim set cln 4262 doesnt work on the xti?
Originally Posted by dumper View Post
No, part number 4260. It is on the website and available.
Looks like the one you want is 4260
Old 11-14-2012, 05:33 PM   #585
Slapmaster6000's Avatar
Bvoltz, I just jumped in here and read your post. Odd that you had better lap times with 2.5 camber, it should have screwed right into the carpet. But that said, what tire combo? What is your carpet traction like? What's your sauce pattern (full rear - 3/4 inside front?)
You really want to aim for 3.25-3.5mm of r/h. You can rake the chassis (lower at the nose then the tail) if you want to increase steering, but that is a very subtle setting.
Yes, the #4262 ride height shims are for the xti.... Burt wins a CRC sticker!
A little trick, you can use a header card, a business card, anything with a square 90* corner as a camber gauge. Place it along side your front tire and see how much gap you have at the top. 0.040" or 1mm is going to be about -1* of camber. We normally do not run that much.... so use just slightly less.
Brian
Stay dialed my friends!
www.slapmastertools.com
Team Roche USA
Team Orca orcharc.com
Slapmaster6000 is offline   Reply With Quote
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 565 09-25-2017 05:19 PM
