Like Tree42Likes
Old 10-28-2012, 08:07 AM   #406
Trader Rating: 15 (100%+)
Originally Posted by bigtee View Post
xti car is twitchy in turns rear come around s/r on radio 76%, steering travel 80%, expo 34%, servo speed 88%. do i need to dial more steering out of the radio or change set up in car?
Make sure the car isn't tweaked, and then adjust how much front to rear bias you have via springs, front dope amount, ride height, pod droop, etc.
How much of the front tire are you doping and what tire compounds are you using?
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 10-28-2012, 08:17 AM   #407
side springs just touch; ride height front 3mm middle 3.5mm rear at 3.5mm rear pod at 3mm i dope the whole front tires.
bigtee is offline   Reply With Quote
Old 10-28-2012, 09:12 AM   #408
303slowdown's Avatar
Trader Rating: 24 (100%+)
A little bit of preload on the side springs can calm a car down also back down the dope on the fronts to 1/2 to 3/4 ,going to long arm or raising the upper arm with the new roll center shims would help calm the front end down.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 10-28-2012, 10:41 AM   #409
jarrodh's Avatar
Originally Posted by jarrodh View Post
im goin to be testin out the theory this weekend.. hopefully it works aswell as it does in my head..
and save the rear axle bearings
it worked great, didnt kill a single bearing..
but now my esc packed it in.. i cant catch a frekin break.. fix one problem, 2 more pop up..
so far, new car, new battery, new voltage booster, replaced rx the second night, fixed the bearing issue, replaced the sensor wire and new motor 3rd night, now i might need a new tekin?..
im done spending money on this thing.. it can just sit on the shelf for a while now..
www.irocc.ca
jarrodh is offline   Reply With Quote
Old 10-28-2012, 10:57 AM   #410
A racer at our local track was having issues with his sedan being way too twitchy... turned out he had +30% st expo.
If you are having to run negative 34% expo, something is probably wrong with the setup... If you are running positive expo... well that is just a mistake.
JamesL_71 is offline   Reply With Quote
Old 10-28-2012, 08:49 PM   #411
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Really depends on how you want the car to feel. Ive never seen anyone run positive expo on purpose though.
Paul Lemieux commonly runs -20 to -30 Expo on his 12th and TC though.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 10-28-2012, 11:00 PM   #412
Default foam bumper for xti
does anybody know what foam bumper Andrew Knapp use on the xti ? it seem that bumper goes around the front end pretty good. i been using team associated for their 1/12 scale doesn't do much too protect the corner of the front chassis for i broke mine in crash right where the front body mount mounts. now i have to get a new chassis.
Old 10-28-2012, 11:57 PM   #413
FaanP's Avatar
There is some new option option parts for the Xti available on their site.
When in doubt - GAS IT!!
FaanP is offline   Reply With Quote
Old 10-29-2012, 03:21 AM   #414
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Anyone know where to buy a Sanwa SRG-HR to be shipped to the US? My LHS can not get them, and everywhere I know to look online either doesn't carry it or is out of stock with no ETA.
Old 10-29-2012, 04:18 AM   #415
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hello Andrew,
I think this might be it under the airtronics name.
http://www3.towerhobbies.com/cgi-bin...&I=LXJTU7&P=SM
hope this helps
Mike
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 10-29-2012, 08:04 AM   #416
big_ads's Avatar
Trader Rating: 80 (100%+)
Send a message via MSN to big_ads
Depends on what radio you are using though too. The futaba is negative to slow the initial reaction, but on the older Spektrum radios (dont know about the newer ones) it was positive expo to slow the initial reaction.
Adam Balk
Northern Mini Racers (www.facebook.com/groups/northernminiracers/)
Team CRC - Protoform/Pro-line - Big Head Racing - Dumpers Speed Shop
big_ads is offline   Reply With Quote
Old 10-29-2012, 08:29 AM   #417
Trader Rating: 38 (100%+)
Yes, I found this out the hard way when I switched from Spektrum to Futaba on my airplanes. For cars I've never used Expo but it's always safest to verify that the radio adjustment you just made did what you were expecting it to.
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
Old 10-29-2012, 08:53 AM   #418
locked's Avatar
RC mushroom sells it, but they are out of stock. I think you are probably looking for model number 94971.
http://www.rc-mushroom.com/product_i...ducts_id=21691
LRP says they have some, but I don't know how you are supposed to order from their site. The online shop seems to just be in German. I was able to find the sanwa servos section, but this one wasn't there.??
http://www.lrp.cc/en/products/sanwa/...autos/details/
Good luck finding one.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 10-29-2012, 03:52 PM   #419
Originally Posted by mike ivy View Post
Hello Andrew,
hope this helps
Mike
From what I can find there's a distinct difference in performance between the Airtronics and Sanwa. Same case size and shape, but I think the Airtronics 94761z is like 65 in/oz and .14 secs at 6.0 volts and the Sanwa is 53 in/oz and .07. I found lot's of European shops that carry the Sanwa and have it in stock, but after e-mailing them I couldn't find one that would ship to the USA.
Old 10-29-2012, 04:11 PM   #420
Andrew, I was using the Airtronics 94761 in my car last weekend. On paper, the specs aren't quite as good as the JRs I was using before... but on the track, the servo was great.
I seem to recall that the Sanwa's speed is spec-ed @ 45* as opposed to 60*, or something like that. It's actual speed was something on par with the JR 3650.
That being said... if you find a source for them, let me know.
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 567 11-20-2017 04:06 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
FunStuff
