Like Tree42Likes
Old 10-23-2012, 08:37 PM   #376
nashrcracer's Avatar
R/C Tech Charter Subscriber
Originally Posted by LloydLoar View Post
I am not Mario Ficco,
that's not a bad thing
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 10-24-2012, 12:09 AM   #377
Default Team CRC diffuser
when will it be available
bigtee is offline   Reply With Quote
Old 10-24-2012, 09:38 AM   #378
theatriks's Avatar
Ok im paypal ready !! whos got the XTI in stock....talk to me.
theatriks is offline   Reply With Quote
Old 10-24-2012, 10:26 AM   #379
Mark Day, who owns Timezone, said he had one in stock. Not sure if he still has it but it's worth asking. His screen name is MAD916.
malkiy is offline   Reply With Quote
Old 10-24-2012, 10:33 AM   #380
theatriks's Avatar
Ok thanks ....anybody else just in case?
Old 10-24-2012, 12:17 PM   #381
FaanP's Avatar
Here is my Xti doing a balancing act
When in doubt - GAS IT!!
FaanP is offline   Reply With Quote
Old 10-24-2012, 12:21 PM   #382
AdrianM's Avatar
I think there is a ROAR rule against aerodynamic aids like the diffuser.
Adrian Martinez
Old 10-24-2012, 01:09 PM   #383
wingman2's Avatar
What did you whack to knock the front end out like that mate?!
Sponsored by CML Distribution - http://www.cmldistribution.co.uk
wingman2 is offline   Reply With Quote
Old 10-24-2012, 01:15 PM   #384
superspeed's Avatar
No xti to race for this weekend 2 day racing event, ETA is 11/15 for the kit to arrive, dang.
superspeed is offline   Reply With Quote
Old 10-24-2012, 02:24 PM   #385
FaanP's Avatar
Small crack at the front body post that I managed to fix, I did not even notice it till you mentioned it. Rest of the front is not assembled,
Old 10-24-2012, 03:40 PM   #386
Radio Active's Avatar
I think you will find that rule applies to TC but not 12th. In most 12th rule sets the rule reads "no additional aerodynamic aids may be attached to the body" A diffuser is attached to the chassis not the body. I'll go and double check the ROAR rules now, but I know that's what it says in Aus.
Reigning NSW 4WD Group 20 Champion
Member: Maitland Radio Car Club (http://www.morcc.com.au)
twitter: @dvcotton
Australian 12th Scale hastag: #EP12AU
Radio Active is offline   Reply With Quote
Old 10-24-2012, 03:46 PM   #387
It looks like ur chassis has broken no??
Jampot is offline   Reply With Quote
Old 10-24-2012, 04:15 PM   #388
Ok, I've checked the 2010 ROAR Rules (they are the ones I have). Diffusers are not mentioned specifically anywhere. The diffuser does meet the ROAR definition of a wing:
Originally Posted by 2010 ROAR Rules
6.5.1 Definition: Wings are aerodynamic devices attached to vehicles to increase down force and traction when a vehicle is traveling at speed. The dimensions of wings vary depending on the class of racing, and are described in class rules or specifications.
6.5.2 Only single element or two-element wings may be used, and then only when allowed by the class rules.
If you go to the 12th rules then there is nothing mentioned about wings at all, it doesn't say they are allowed or disallowed. There are dimensions for a rear spoiler, but spoilers are defined differently.
However, it is also worth pointing out that the diffuser could also meet the definition of a bumper (so long as the edges aren't sharp, and depending on what the bumper is actually made of) which certainly is allowed.
6.2 BUMPER RULES
6.2.1 Bumpers are not required in all classes, but when used, they must be shock absorbing and non-metallic, with no sharp edges. For safety, rigid bumpers, such as fiberglass and composites, are not permitted.
6.2.3 Rear bumpers must be made of a solid material with rounded edges and may not extend to the side beyond the outer edges of the tires, and may not extend beyond the rearmost part of the body except in off-road vehicles.
So, at best it is a grey area in the ROAR rules. As I'm in Australia that doesn't really bother me. A diffuser is allowed under Australian regulations as I've already said.
For those interested in the IFMAR rules they are closer to the Australian rules, and a careful reading reveals that a diffuser can be used. There is no definition of what a wing is, and in the absence of a definition you'd have to say that a diffuer is not a wing, it's a diffuser. Twice in the IFMAR rules it uses the wording "4.2.1 No additional items may be fastened to the body exterior other than the rear trim tab /Gurney strip." As for the Aus rules it says body not chassis or vehicle. So, under IFMAR regs you are cool with a diffuser.
twitter: @dvcotton
Old 10-24-2012, 04:33 PM   #389
I think ROAR's rules against aerodynamic aids refers mainly to things like moveable aerodynamics.
Old 10-24-2012, 06:42 PM   #390
TENCHO's Avatar
Hey Bert remember me??? It's Jesus! You know I'm getting one of these! I'm in seattle
TENCHO is offline   Reply With Quote
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 565 09-25-2017 05:19 PM
