Like Tree42Likes
Old 10-22-2012, 04:24 PM   #361
Originally Posted by al dente View Post
we measure kingpin length from the steering block to the bottom of the e clip groove. basically you are taking the measurement of the eclip, spring and pivot ball, if that makes sense. the king pin should not be angled unless it is screwed into the steering block wrong, or bent. there is a moulding seem on the steering block, try not to measure from there, but always try to go from the same spot. i.e., even with where the set screw goes in, or something like that.
i just checked my kingpin length seems to me that if you measure from the set screw you will have way to much preload on the springs so i don't think you can measure from that. seem to me the best place to measure from would be the top side of the lower arm to the eclip. i am guessing here but that to me seems the most logical way to get a .404 kingpin length. so let me know if i am wrong ? maybe some pics would help
bigtee is offline   Reply With Quote
Old 10-22-2012, 05:50 PM   #362
troyer25's Avatar
you measure from where the king pin goes in the steering block to the eclip groove, you have to remove the tire,eclip,spring and remove the king pin from the lower arm. then using your calipers measure from the eclip groove to the bottom of the block. What al dente was suggesting is to measure from the same spot as in line your calipers up with the set screw so both sides are the same, not measure from them. hope this helps
G2 Designs,Team CRC, Hobbywing North America,Dumper's Speed Shop,CRC Raceway and Hobbies
troyer25 is offline   Reply With Quote
Old 10-22-2012, 08:24 PM   #363
i got it now that makes sense
Old 10-22-2012, 11:36 PM   #364
jarrodh's Avatar
Originally Posted by Slapmaster6000 View Post
I have to ask that brutal honest question: does your track have some hard barriers and are you getting in contact with them?
I ran my Xti hard into a fastened barrier at IIC into the left rear. It didn't improve its smoothness, but I didn't kill it either. If you are concerned about your track being too firm, slide a 3/16" o-ring on the axle and then shim with 1/4 spacers... make a little cushion out of it.
Brian
i like that idea..
track isnt road hard, we use crc clik-track with small velcro strips on the bottom. i did hit a couple times.. but not more than i have with any other crc car ive had..
im goin to try that oring idea.. just have to shave the spacer/collar down that little bit to keep the track width..
thanks
www.irocc.ca
jarrodh is offline   Reply With Quote
Old 10-23-2012, 01:56 PM   #365
al dente's Avatar
having a longer king pin will give the car more front droop, if you run a shorter kingpin than the .404, you are running preload in the front spring, a longer king pin should let the front of the car roll more, and increase steering, a shorter one will tighten up the front.
Team CRC / Dumper's Speed Shop / Team Scream Racing / Black Art
RC America / FB/FX / Colorado On Road RC Club
5280 Raceway (5280raceway.com) home of the MILE HIGH INDOOR CHAMPS April 19-22, 2018
al dente is offline   Reply With Quote
Old 10-23-2012, 02:55 PM   #366
what should the kingpin length be? i see a lot of people referring to a .404 kingpin length.
Old 10-23-2012, 04:36 PM   #367
troyer25's Avatar
.404 is ran just about every where. you can adjust it as needed but .404 inches is a good place to start
Old 10-23-2012, 04:44 PM   #368
al dente's Avatar
run .404, then run .407. see if you can feel a difference. just like some will like inline, and some will like transverse, each setup item will have pros and cons for each driver. there is no golden setup that will be perfect 100% of the time for 100% of the people. try them both, see what difference it makes, then you will have that information for tuning in the future.
Old 10-23-2012, 05:27 PM   #369
thanks i will try it out
Old 10-23-2012, 05:31 PM   #370
Default hobbywing 1s esc ver 1
whats the most drag brake should i have setup in the esc running 17.5 blinky
Old 10-23-2012, 05:49 PM   #371
Trader Rating: 15 (100%+)
I am not Mario Ficco, but my response would be "none". 17.5 12th is all about carrying corner speed and unless you run a Max-like setup where you let off the throttle quite a lot, you really never need to back off on the throttle that much. Throttle movement in 17.5 blinky is like 1/16th of your trigger travel.
Alternately, since you should likely never hit neutral position until the end of the race, you can run as much damn drag brake as you would like.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 10-23-2012, 07:17 PM   #372
Radio Active's Avatar
Anyone know where I can get the diffuser from apart from CRC. Their site is down and I've just decided I want one now! lol
Reigning NSW 4WD Group 20 Champion
Member: Maitland Radio Car Club (http://www.morcc.com.au)
twitter: @dvcotton
Australian 12th Scale hastag: #EP12AU
Radio Active is offline   Reply With Quote
Old 10-23-2012, 08:00 PM   #373
not sure but i don't think they are available yet. think crc is still working to get them to the public.
Old 10-23-2012, 08:15 PM   #374
Ok, I guess I'll just keep making my own out of buggy wings until then.
twitter: @dvcotton
Old 10-23-2012, 08:32 PM   #375
ByteStream's Avatar
Hmm ...
Team CRC Xti 1/12th Scale!!-t_13240.jpg
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 567 Yesterday 04:06 PM
