Like Tree42Likes
Old 10-07-2012, 03:02 PM   #196
Trader Rating: 24 (100%+)
Send a message via AIM to Max K
Nice job Team CRC!!!!!
RC America - XRAY - HUDY - Trinity - ORCA - Sanwa - ULTI - PROTOform - MaxFX - Slapmaster Tools - ApexRC - SXT
Max K is offline   Reply With Quote
Old 10-07-2012, 03:32 PM   #197
Why all the drivers use the Transverse "T" Configuration Kit ?
zozo is offline   Reply With Quote
Old 10-07-2012, 04:46 PM   #198
Most listed above where "inline" as noted.
Team CRC is offline   Reply With Quote
Old 10-07-2012, 05:18 PM   #199
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Knapps car was defininately fast in the mod a Main. He just needed to settle in a little but man it was a rocket!
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 10-07-2012, 05:37 PM   #200
EA
You looked good all weekend as well EA. Good running.
Old 10-07-2012, 08:37 PM   #201
kingbee9's Avatar
Trader Rating: 30 (100%+)
had mine on the track yesterday at The Gate. holy smokes do this car steer! i had mine setup with the transverse battery and the servo up front. i could dial out almost all the dual rate on the radio and the car still carved awesome turns.
Brian Wedge
www.ashfordhobby.com
NORCAR R/C Racing at The Gate
www.norcarracing.com
kingbee9 is offline   Reply With Quote
Old 10-08-2012, 12:38 PM   #202
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
I am just now starting to recharge some energy from a long week at Las Vegas. The new Xti did great. I showed up with a pair of them, one for 13.5 and one for mod. The 13.5 car started off inline, the mod trans. While I didn't lay down anything very impressive, here's some notes from my week. CRC has two styles of front ride height shims that were getting beta tested. A shim that goes between the horseshoe and the arm, but the range is limited to 0.040". If you bolt your horseshoe to the chassis, you can get from 41.5 to wheel. If you want to use bigger wheels, you will need to shim between the horseshoe and chassis. CRC also has a trio set of shims that go between the horseshoe and chassis. Juggling 3 pieces and 2 wrenches is not as easy as an old school phillips screw driver. I was looking for a particular kind of steering from my inline car that I would describe as lifting late and attacking the corner rather then lift a bit earlier rolling the corner. I ran all practice and R1 inline. Then I chose to build the transverse to see if anything could be gained in R2. I left the same tires and motor package in the car, same battery. It was a pure test of my style and chassis layout. I went 5 seconds faster, 0.1th of a second over all. So I dubbed the Xti a Play-Do car, you can mold it into anything to fit your driving style. Others were running inline and going faster then I was. Kenny and Mark for instance were really tuned in with the inline layout. I ran my car different every run, I kept changing parts to see if something would click for me. Its a shotgun approach and not very smart to do at a big race, but I learned a lot. I felt like the pit work horse, trying several things. Frank even tried his magnetic side springs. I don't think that they will ever become production, but he was faster then me with them! I might suggest trying more mod tires then the conventional stock spec type tires. Try magenta fronts, pink rears... maybe some yellow rears. Another combo tried was chrome front, graylow rear with very good success. Another tuning part on the way is various thickness height shims between the upper arm and lower arm to change camber gain. Use no shim and stock spec tires or shim up and reach for the mod tires. Check your laps and see which works better for you. Also watch for the new version of front springs; old = black, new = silver. The silver fronts are a little shorter so you may want to shorten the kingpins up to .400", the .407" with a black spring is still a solid number. Kingpin length is like drop to a TC, so pay attention to it. I've seen sloppy handling cars be cured with kingpin lengths. Most drivers were using lighter dampening fluid (5k-20k) in the tubes with the car inline. Some had luck with 30k inline so it's not written in stone. This car did pretty well considering it's been out barely a week in the general hands. IIC was only just the beginning.
Stay dialed my friends!
www.slapmastertools.com
Team Roche USA
Team Orca orcharc.com
Slapmaster6000 is offline   Reply With Quote
Old 10-08-2012, 02:35 PM   #203
When the stepped ride height tool for the back comes out...will it be in .5 or .25mm increments?
Old 10-08-2012, 04:10 PM   #204
Trader Rating: 85 (99%+)
Frank you forgot about one crc car in the 17.5 main
tony block was driving a crc xi
i finnished 9th
Originally Posted by Team CRC View Post
Just a quick update from the IIC...
Andrew Knapp took his Xti to an A-main win in the 13.5 Superstock class. Andrew used CRC Magenta front and rear tires in the main and set fast lap time in the process. Joining Andrew were CRC drivers Hupo Honigl and John Tortorice.
In the 17.5 class, it was a CRC sweep with Xti inline cars taking 2nd and 3rd in the hands of Mark Smyka and Kenny Lambert. Birthday boy John Tortorice had a lot to celebrate taking the TQ and win with his CRC Gen-Xi. John also used the CRC 1s lipo and CRC tires to win and set fast lap. Joining the podium trio were CRC drivers Carrissa Smyka and Robert Dirla making it 5 out of 10 drivers with CRC rides. The 3 podium drivers used CRC 1s lipos.
In the modified 1:12th class, Andrew Knapp put on quite a show with his inline Xti charging to the front in a fury of flying foam. An unfortunate and untimely "board" meeting sent him back a few positions. In his charge back, Andrew managed to hot-lap the field setting fast lap time in the A-main with his inline Xti. Knapp used Magenta front and pink rear CRC 1:12th tires.
In the World GT 13.5 class, another CRC podium sweep with TQ man Dave Ehrlich taking the win with his CRC Gen-X 10 LE and CRC lipos. Joining Dave on the podium, Denver driver Mario Ficco (2nd) and Brian Bohlman (3rd) in their Gen-X 10 LE rides.
It was another great event in Vegas and another great result for Team CRC!
Sponsors
Awesomatix USA, Roche USA, LRP USA, EA MOTORSPORTS, Ko Propo, TQ wire, GENESIS RC, Serpent USA
tony block is offline   Reply With Quote
Old 10-08-2012, 05:16 PM   #205
Kenny L's Avatar
The Xti is money after having only two days on car before showing up to IIC couldn't ask more of the performance of pretty much box stock form minus springs and tube lube. I can't wait to see what some time on it will come up with. My cars were super easy to drive.
Team Tekin, Ko Propo America
Kenny L is offline   Reply With Quote
Old 10-08-2012, 10:20 PM   #206
Default crc xti finished build (opinion wanted)
just finish building my xti running lrp sxx competition esc, blinky mode, express 17.5 3.5 revtech 6500 mah lipo, spur gear 72 pinion 47, rear tire diameter 42mm front diameter 41mm. front ride height set at 3mm mid at 3.5 rear set at 3mm need to play around with ride height ajustment. but overall what you think of my roll out?
bigtee is offline   Reply With Quote
Old 10-09-2012, 07:25 AM   #207
i finnished 9th
Awesome!!
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 10-09-2012, 08:55 AM   #208
Andrew Knapp's Avatar
Send a message via AIM to Andrew Knapp Send a message via Yahoo to Andrew Knapp
What can I say about the new CRC XTI other than that it's DIALED!
I took the win in 12th 13.5 in Vegas and finished 6th in mod 12th!
I ran my 13.5 car transverse and my mod car inline!
Post setups soon!
Team CRC www.teamcrc.com--Team Trinity--Revtech--Team Spektrum www.spektrumrc.com--protoform--SXT--Rapid Competition RC Raceway and my dad!
Andrew Knapp is offline   Reply With Quote
Old 10-09-2012, 11:58 AM   #209
Default want to balance my xti help
using 4 pocket scale this what i get in grams. r-f 174.9 l-f 136.9 r-r 186.9 l-r 205.3 on xti
my xi is r-f 124.6 l-f 171.4 r-r 228.6 l-r 136.9
can i get some help with balancing
Old 10-09-2012, 12:26 PM   #210
LonnyJ1950's Avatar
The fact that your weights are off diagonally suggests your car is tweaked. Back the side springs all the way off and disconnect the damper tubes and see if that makes a difference. Also be sure the scales and car are level side to side and front to back.
Lonny
LonnyJ1950 is offline   Reply With Quote
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 565 09-25-2017 05:19 PM
