Like Tree42Likes
Old 09-29-2012, 09:17 AM   #166
OVA
OVA's Avatar
Trader Rating: 78 (100%+)
Originally Posted by Slapmaster6000 View Post
Look Ma.....Twins! Like Danny Devito and Arnold
which one is Danny?
OVA is offline   Reply With Quote
Old 09-30-2012, 08:03 PM   #167
Trader Rating: 38 (100%+)
I was a little light so I ended up putting 7 grams of lead on both sides of the speed control and ended up with 47% weight on the front. The good news is the car worked very well. Last weekend the fast lap here was my Xi at an 11.322 with two other racers running 11.467 and 11.490 in the main. The heats for round 2 were in the 11.6 to 11.7 range. Fortunately the XTi ran mostly in the 11.7's with a best of 11.625 today. This to me isn't bad since we only had two cars on the track and it was a bit dirty from the off road track next to it.
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
Old 10-01-2012, 02:23 PM   #168
Miholc's Avatar
Hello fellow CRC Xti owners!
I preordered mine, waiting to arrive end of the week or early next week. Since I live in "EUROland" I need to know what items do I need to stock up? Please help me with where to get the parts?
I tought the screws pack, spurs, ... ?
I will be running custom "open" setup as where we run we do not have any limitations on the cells and motors nor weight. 3S 1000mAh or 4S 800mAh setup with 17.5 or 21.5 motors :-) I run now 1800 2S on 13.5 motor with 80/26 gearing in Xray XII link. Very light. :-)
Miholc is offline   Reply With Quote
Old 10-01-2012, 07:57 PM   #169
Well my Xti is in the mail. After a couple years of not running pan car this car convinced me to get into it again.
Two questions:
1) What standard hex/nut drivers are needed to build this kit? (why can't it be metric haha)
2) What is a good starting rollout for a 10.5 on a 80X50 track?
Thanks in advance.
-Kane
Kane-o is offline   Reply With Quote
Old 10-01-2012, 08:03 PM   #170
nice
Mingsti is offline   Reply With Quote
Old 10-02-2012, 05:41 AM   #171
kingbee9's Avatar
Trader Rating: 30 (100%+)
got mine...it's built and ready to go. will put it on the track this saturday. can't wait!
Brian Wedge
www.ashfordhobby.com
NORCAR R/C Racing at The Gate
www.norcarracing.com
kingbee9 is offline   Reply With Quote
Old 10-02-2012, 11:44 AM   #172
Csaari77's Avatar
Trader Rating: 34 (100%+)
Mine will be waiting for me when I get home from work.
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 10-03-2012, 01:12 AM   #173
Two questions:
Thanks in advance.
-Kane
Bump for some help.
Old 10-03-2012, 07:34 AM   #174
big_ads's Avatar
Trader Rating: 80 (100%+)
Send a message via MSN to big_ads
Bump for some help.
3/32, 5/64, 1/16, .050" 11/32 nut driver for the diff. 5mm nut driver works for the locknuts, not sure what the SAE number is on that one.
No idea on on roll-out.
Adam Balk
Northern Mini Racers (www.facebook.com/groups/northernminiracers/)
Team CRC - Protoform/Pro-line - Big Head Racing - Dumpers Speed Shop
big_ads is offline   Reply With Quote
Old 10-03-2012, 07:52 AM   #175
Csaari77's Avatar
Started assembling my kit last night, and I have a question about the pod movement. It states that the pod should move freely, but does that mean it should flop around loose? I got mine to move smoothly, but it doesn't move on it's own if I let it go.
Old 10-03-2012, 08:14 AM   #176
nitrobeast's Avatar
Trader Rating: 41 (100%+)
I always set mine up so it falls on its on weight.
Rui Goncalves
Team CRC|Awesomatix USA|TQ Wire|
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 10-03-2012, 10:08 AM   #177
Thank you sir!
Old 10-04-2012, 06:52 AM   #178
johnnywhopper's Avatar
The locknuts are 3/16" hex.
The pod should fall under it's own weight, especially if the added weight of the pod plates are already installed. If it does not, then you will need to loosen the fit on either the center pivot, or the side link pivot balls, or both. just go a little at a time on the clamping screws on both pieces and get the pod to flop around easily without making any excessive play in either of these pivots.
John
Team CRC, Spektrum, Hobbywing, JDJ Vinyl Graphics, Moby Graphix, Black Art, Power Push
johnnywhopper is offline   Reply With Quote
Old 10-04-2012, 06:58 AM   #179
Csaari77's Avatar
John
Thanks. I messed with it last night and got it set. I had the side links too tight, which was binding the movement. Are there any tricks to setting them, or is it just trial and error?
Old 10-04-2012, 07:01 AM   #180
Radio Active's Avatar
Bump for some help.
60 mm.
Reigning NSW 4WD Group 20 Champion
Member: Maitland Radio Car Club (http://www.morcc.com.au)
twitter: @dvcotton
Australian 12th Scale hastag: #EP12AU
Radio Active is offline   Reply With Quote
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 565 09-25-2017 05:19 PM
