Like Tree31Likes
Old 04-02-2014, 06:39 PM   #1396
ghoppa's Avatar
Trader Rating: 54 (98%+)
Default Front arm track width
Hope someone can help
Cpl of the local fast guys who run (AE platforms) have addressed that I may need to widen my front track with on my ego. Is there a longer lower front arm as an option vs the stock arm that comes with the kit??? All they have to do is shim the arm away from the bulkhead, what is our option with the altered ego platform??? Can someone enlighten me on any option please.
Thx!
R1 Wurks - ActivRC - ApexRC - P1 Brands
ghoppa is offline   Reply With Quote
Old 04-02-2014, 07:33 PM   #1397
I)arkness's Avatar
how much wider are you needing to go? and what width do the AE guys run at, as you will eventually be limited by what maximum width is in the rules you race to.
B.Portelli
Hyper RC - RAB Hobbies - Wild Turbo Fans
Race Opt - Team Powers
I)arkness is offline   Reply With Quote
Old 04-02-2014, 07:53 PM   #1398
max width according to rules is 172mm.
Andrew S is offline   Reply With Quote
Old 04-02-2014, 07:55 PM   #1399
why do you want to go wider? That makes the car have less steering and therefore slower.
I can see why if your on high traction and traction rolling or car is to aggressive.
Old 04-03-2014, 03:46 AM   #1400
ghoppa's Avatar
Im currently running 166mm the cars I mentioned are 169 & 168mm. They seemed just a bit more planted entering and in the middle of on throttle sections of our local track
Old 04-03-2014, 03:48 AM   #1401
ghoppa's Avatar
the local track is super high bite for sure, I believe this will help, just need to know if there are longer arms available..
Old 04-03-2014, 04:30 AM   #1402
I think it would help. Why can't you just add shims to the axle?
166 is pretty narrow.
Old 04-03-2014, 04:37 AM   #1403
I)arkness's Avatar
not sure what your budget is but crc did release the CRC Pro Strut Front End (1/12th Scale) [CLN3240], which i believe uses longer arms
B.Portelli
Old 04-03-2014, 07:44 AM   #1404
avs
avs's Avatar
that is not new.
the xti uses a plate 32583 that would need to machined with a wider placement. a new cnc machined part more likely than a new molded plastic part. I don't see how to change the front width other than shims on the front axle or a different front wheel offset.
Tony Shimko
avs is offline   Reply With Quote
Old 04-03-2014, 11:37 AM   #1405
gdiddy's Avatar
Default Xti Inline for sale
http://cgi.ebay.com/ws/eBayISAPI.dll...m=141245290025
The desired effect is what you get when you improve your interplanetary funksmanship.
gdiddy is offline   Reply With Quote
Old 04-03-2014, 02:52 PM   #1406
I)arkness's Avatar
Originally Posted by avs View Post
that is not new.
i never stated it was new!
B.Portelli
Old 04-03-2014, 03:22 PM   #1407
That is the same as the front end that comes with the car already. There is a longer upper arm option but that doesn't make the car wider and can't be used with the in-line version of the car because the servo is in between the front arms.
Apex RC
www.apexrc.com - Hawaii's #1 RC Proshop
Share & Like Our Page:https://www.facebook.com/ApexRCProshop
Win free stuff!
Old 04-03-2014, 03:26 PM   #1408
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
You CAN use the long arms with the servo between the arms. It will work on the inline car as well as the transverse car with the servo mounted up front.
Kevin Van Ert | MFR | CRC Racing | Team Scream Racing | Hobbywing | Xenon USA | Dumpers Speed Shop | Genesis RC | Race Rewards | Lake Superior RC Car Club | www.lsrcc.com
Kave is offline   Reply With Quote
Old 04-03-2014, 03:36 PM   #1409
You can use the long arms with the hinge pin in the short arm holes. But to use the long arms with the battery in-line the brace that moves the arm mounts will hit the servo. Unless you can find a really tiny servo that will fit under the brace and still give you enough room to adjust for ride height. Not everyone is running a servo that small.
Apex RC
Win free stuff!
Old 04-03-2014, 04:24 PM   #1410
I)arkness's Avatar
my mistake, i thought the long arm set was actually physically longer, making the front end wider,
so yes as AVS mentioned you would need to make a new carbon plate where the arms bolt onto to offset them out 2mm, if you are not able to just shim the front on axles
B.Portelli
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 565 09-25-2017 04:19 PM
