Like Tree3Likes
Old 10-03-2013, 05:10 AM   #1186
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by Troy Carter View Post
Sorry if this has been covered, I can't find it.
If you want to run the solid chassis...
http://www.teamcrc.com/crc/modules.p...prodID=7719466
What else do you need?
Longer side link 3281?
Do you need the transverse kit also?
Where do you mount the side springs?
Thanks,
I believe you'd still need the tranverse kit - assuming you're planning on running your battery sideways
yes, the longer link is needed
side springs mount on the tranverse 'top deck' - I guess you could use the standard Xti top deck, but not sure how that would all work out.
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 10-04-2013, 06:50 AM   #1187
madjack's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to madjack
Originally Posted by sg1 View Post
They are CRC tires, I put adhesive wheel dots on.
For glue, I have some cheap brush on super glue from Walmart
Center spring, I thought the car was more balanced from high to low speed on the high bite track.
I just got all the new CRC springs in (center shock and side) and haven't tried them yet I'll be trying those in 2 weeks (next road race) and let you know which ones work the best at my track
New CRC springs? Due tell...
Never mind, just checked the CRC site. doh
madjack is offline   Reply With Quote
Old 10-13-2013, 04:29 PM   #1188
madjack's Avatar
Default IIC
Looked like the CRC crew did well in Vegas last week, is there any info. available as too which chassis the team drivers used in Vegas last weekend in 17.5, 13.5? (altered ego or xti).
Old 10-13-2013, 05:40 PM   #1189
Most of the cars I saw there were Altered Ego versions of the Xti. I did see a couple stock in-line Xtis though.
If the person in my heats that I was talking to about their chassis is on this forum please PM me. I believe it was a father/son team that had made their own chassis.
Old 10-13-2013, 05:40 PM   #1190
Congrats to the CRC crew on their successes at the IIC...Can't wait to see that F1 car come out!
Old 10-13-2013, 05:55 PM   #1191
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
John Wiita ran an Xi and got 2nd as well in 17.5.
Kevin Van Ert | RC^2 | CRC Racing | Team Scream Racing | McFactory | Lake Superior RC Car Club | www.lsrcc.com
Kave is offline   Reply With Quote
Old 10-13-2013, 07:27 PM   #1192
Trader Rating: 14 (100%+)
I ran over the weekend at NORCAR's annual Vegas Warm-up race.
A TQ and win for my XTi ride!
Here's a pic and the set up I used.
Take note, the CRC carpet was just put down on a new subfloor and the traction was very high!
Set up:
Front:
1.60" grays, 1/2 inside SXT, sidewall glued
.50mm springs (.01" gap between steering block and lower pivot ball)
10* blocks, 2 shims back
1* camber
3.5mm clearance
Rear:
stock shock oil with windtunnel blue "v-hive" spring
CRC blue side springs
15K in tubes, outside elevated
1.65" grays, 3/4 middle SXT, safety glue on seem
3.5mm clearance
1.5mm droop
Notes:
Black Art body
Power Push White Lightening battery
Team Scream motor (Trinity based Killshot)
Hobbywing 1s ESC
Attachment 1112805
Do you think Grays are good on Medium Traction carpet?
Codfather is offline   Reply With Quote
Old 10-13-2013, 09:41 PM   #1193
Just a quick note to congratulate Randy Grosse and Andrew Knapp for winning the 17.5 and 13.5 classes at the 2013 IIC.
Randy Grosse used a VERY STOCK, inline CRC Xti car to dominate the A-main. Randy lapped up to 3rd setting fast lap in the process. Randy used a stock, inline Xti. No Altered Ego, no transverse kit, stock, the way the Xti comes in the box. John Wiita finished second with his CRC ride. The 4 CRC cars in the A-main finished 1-2-4-5, great result!
Randy also used the CRC Rocket Fuel 1s pack, Black Art R8C body as well as CRC Pro Cut tires.
In 13.5, Andrew Knapp dominated qualifying winning 3 of 4 rounds (CRC's Mitch Witteman won the other). Andrew led wire to wire with his CRC Xti in the transverse battery position. Not an Altered Ego version, Andrew chose the standard Xti with the transverse battery position. Knapp used the R8C body and CRC Pro Cut tires.
We WILL get these setups on the website. Thanks for all the support and kind words.
Team CRC is offline   Reply With Quote
Old 10-13-2013, 10:53 PM   #1194
Trader Rating: 40 (100%+)
Congrats Everyone!
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 10-14-2013, 02:17 PM   #1195
corally's Avatar
Hello at all
i have Xti on build...for carpet racing without additive what tyre ?...
corally is offline   Reply With Quote
Old 10-14-2013, 02:24 PM   #1196
Andrew Knapp's Avatar
Send a message via AIM to Andrew Knapp Send a message via Yahoo to Andrew Knapp
I will post my setup soon!
Team CRC www.teamcrc.com--Team Trinity--Revtech--Team Spektrum www.spektrumrc.com--protoform--SXT--Rapid Competition RC Raceway and my dad!
Andrew Knapp is offline   Reply With Quote
Old 10-14-2013, 02:58 PM   #1197
Also on display at the meet and greet were 2 new 1/12th bodies and a new WGT body...all 3 looked very cool. Hopefully they come out soon!
Old 10-15-2013, 04:22 PM   #1198
madjack's Avatar
Thanks, looking forward to hearing what spring combinations were used since the release of the new springs.
Old 10-21-2013, 05:25 PM   #1199
Default my setup 2013 IIC
2013 IIC 13.5 12th Scale TQ+Win
Traction Compound: Jack the Gripper
Front Traction: Inside 1/8" for ~ 3 min
Rear Traction: whole tire for ~15 min
Traction: High
Motor: Trinity Revtech Killshot RPM Stator
Spur Gear: CRC 80 tooth
Speed Control: Hobbywing 1s
Radio" Spektrum DX4
Car: CRC XTI (ran in transverse with solid XTI Chassis)
Body: CRC Black Art Audi R8C
Front Tires: CRC Magenta 1.60"
Rear Tires: CRC Blue 1.63"
Front Springs: .55 with 50000 lube on king pin (.400" kingpin length)
Side Springs: .50 just touching on rear pod
Center Spring: CRC Blue
Center Shock Oil: 30wt
Center Shock Position: stock position (all the way back)
Dampner Tubes: 50000 lube
Battery Position: Forward
Caster: 5 degree blocks with all 3 shims forward and graphite spacer under caster block
Camber: Zero
Toe Out: ~1
Long Arm with CRC Top Brace
Rear Pod Droop: ~6mm (ALOT)
Front width: 166.5mm
Rear width: 171.7mm
Ride height: 3mm front, center, and rear
you can find pictures of my car at: http://teamcrc.com/crc/modules.php?n...rticle&sid=184
if you have any questions just post them up!
Old 10-21-2013, 07:23 PM   #1200
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Would you mind sharing what you were running in mod?
AWD
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 563 11-20-2016 07:18 AM
