Like Tree10Likes
Old 06-21-2013, 02:21 AM   #1126
I want to try the Altered Ego for the long side links but keep the in-line configuration of the Xti...one of the many projects I intend to get back to once I find a new job.
Old 06-21-2013, 03:18 AM   #1127
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
Having matched my laptimes at the local track in both configs think both can actually show great qualities
The inline has great aggressiveness which with a little harder setup can be tamed..
When I asked questions on this thread everyone just told me to invest in AlterEgo..
Heading back to inline after next weeks big race at my local track, shall see how it matches my current setup
v-dezign // black diamond
Hoot RC for Local Supplies > www.hootrc.com.au
Me_MrTyson is offline   Reply With Quote
Old 06-21-2013, 02:49 PM   #1128
DesertRat's Avatar
My altered ego benefited from running the front end super soft, .45 springs, no brace, plastic rideheight washers. It was a bit more loose but I turned my steering throw down a few percent and I had never driven a car with more corner speed on club-race traction. It may be worth a try if a hard turn-in tends to make your car want to swap ends.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 06-21-2013, 04:01 PM   #1129
Thumbs down
Coming back to 12th after a few years off chose the xti with ego converstion as i loved my gen xl,however after getting the kits brand new sealed,was not happy when you need long links,for the car that i thought should be in the conversion kit.
Get them of shop,then go to try to fit my ko 949,does not fit,you need to use servo tape to hold other servos in seems the sanwa hgr is the only one to get which is another 70.
If i knew it was going to be hassle like this,dont think i would of gone with the xti.
Seems to of gone backwards in design.
Quietman is offline   Reply With Quote
Old 06-21-2013, 04:39 PM   #1130
tim fry's Avatar
It is a bit annoying but why not try the in line setup first?
As for the servo again yes not ideal but I think it's only a small cost in the whole scheme of things.
What class are you running it in?
tim fry is offline   Reply With Quote
Old 06-22-2013, 02:09 AM   #1131
Be running 10.5 at our local club may see if i can do the shootout,then its mod at plymouth during winter series and do the nationals did gt12 last year did ok,but got the need for speed
Old 06-22-2013, 06:27 AM   #1132
tim fry's Avatar
I would try the in line first it does need a bit of taming at first but it is good.
Old 06-22-2013, 06:33 PM   #1133
Originally Posted by pmes View Post
thanks
bosschick is offline   Reply With Quote
Old 06-27-2013, 11:53 AM   #1134
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Just thought I'd share a set up I used last weekend at my home track NORCAR at the Gate. It's 90 x 40 and high bite carpet. Fairly open layout.
Front:
Gray tires 1.58"
.50mm springs
1* camber
10* castor blocks (2 shims back)
50k lube on kingpins
.01" gap between stearing block and lower a-arm pivot under weight
3mm clearance
Rear:
Magenta tires 1.65"
15k lube in tubes (outside elevated with high roll center balls)
30wt in shock with windtunnel "V-hive" red spring
blue side springs (just touching)
1.5mm droop
3.5mm clearance
Other info:
Team Scream 17.5 (Kill shot based)
Power Push white lightening battery
SXT traction
TQ wire
If you have any questions feel free to ask
Announcing the new Team CRC Xti 1/12th Scale!!-img_0374.jpg
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 06-27-2013, 12:05 PM   #1135
Grey fronts?
Old 06-27-2013, 12:12 PM   #1136
tdu verney's Avatar
SG1 the mechanical set up is great!!! Lucky for me I just added Grays to my inventory! I'm back to my Xti and love it! Thanks.
tdu verney is offline   Reply With Quote
Old 06-27-2013, 12:33 PM   #1137
sg1
sg1's Avatar
Originally Posted by InspGadgt View Post
Grey fronts?
Yep
At the US Indoorchamps I ran black fronts.
I tried them on this layout and they were smooth, but the gray's gave a bit more corner speed. The turns were tuff to carry corner speed. We had 30 or 40' shoots into hard 180's. At times I'd even use breaks.
Old 06-27-2013, 01:56 PM   #1138
tim fry's Avatar
Front:
Gray tires 1.58"
.50mm springs
1* camber
3mm clearance
Rear:
Magenta tires 1.65"
1.5mm droop
3.5mm clearance
Other info:
SXT traction
TQ wire
Nice looking car there. What was your reason to run blue sides?
Old 06-27-2013, 02:52 PM   #1139
Front:
Gray tires 1.58"
.50mm springs
1* camber
3mm clearance
Rear:
Magenta tires 1.65"
1.5mm droop
3.5mm clearance
Other info:
SXT traction
TQ wire
Can you let us know what your rollout was?
Cheers,
AL
www.carcar.ca / www.karz.ca
ALBOP is offline   Reply With Quote
Old 06-27-2013, 04:29 PM   #1140
sg1
sg1's Avatar
I typically run oranges, but this track had alot of bite and the turns were hard to get a car to rotate around quickly. I tried whites, but the car started to square off a bit.
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 564 06-09-2017 04:00 PM
