Old 04-15-2013, 11:01 AM   #1066
DesertRat's Avatar
Theres nothing stopping you from buzzing the pivot plastic so the motor will slide further forward, that would let the motor move forward considerably and in my opinion a motor further forward in the pod is good for handling.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 04-15-2013, 12:20 PM   #1067
M3Roc's Avatar
Trader Rating: 108 (100%+)
I was hoping to avoid any kind of permanent mod's but now that you mention it, I did see one of our guys did dremel the plastic mount around the pivot ball. I will try that, I suppose it wont be too expensive if I mess up or need to go back. Thanks!
☆ What a wicked web we weave, when first we practice to deceive. ☆
☆ Wolves don't lose sleep over the opinions of sheep. ☆
☆ Life never favored weakness, Only the strong survive. ☆
M3Roc is offline   Reply With Quote
Old 04-15-2013, 12:38 PM   #1068
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by andrewdoherty View Post
If it does fit, it would only be with one ear removed. I am not certain it fits with an ear missing though.
I found out the hard way today that this servo didn't fit
guess i'm ordering a Spektrum
anyone have any opinions of the spectrum 5040?
thanks!
I know I've saw a lot of questions asking about the availability of the rear diffuser - was it ever release separately?? I don't recall seeing a post where it said it was..
one more question - can the Xti work with the original steering knuckles?? I bought the conversion kit for mine, but it didn't come with any parts to convert the knuckles to the 1/8th bearing or the new plastic pieces...
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 04-15-2013, 02:17 PM   #1069
DesertRat's Avatar
servo cases are like three bucks, to be proactive I would consider buying a few extra when you buy a servo.
Old 04-15-2013, 02:25 PM   #1070
I cut both ears off of my JR servo and just use Shoe Goo to hold it in place. This gives me just enough room next to the servo to mount my transponder
Old 04-16-2013, 12:38 PM   #1071
pmes's Avatar
The diffuser is garbage unless you're going to mount it on a shelf queen.
pmes is offline   Reply With Quote
Old 04-16-2013, 12:39 PM   #1072
k_bojar's Avatar
well ok then
Old 04-16-2013, 12:51 PM   #1073
I am all about the defuser..I could care less if it doesn't work it just looks cool..
cookie1 is offline   Reply With Quote
Old 04-16-2013, 03:19 PM   #1074
CypressMidWest's Avatar
Does your car go fast enough to make use of it?
It looks awesome, and I can tell you from experience that it does work. If it didn't work, it wouldn't be hanging off the back of my car.
Team CRC, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 04-16-2013, 03:29 PM   #1075
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I am worried about how fragile it is. For as expensive as it is, I am hesitant.
AWD
Old 04-16-2013, 03:51 PM   #1076
AWD
After all the shots my Xti took to the rear-end this past weekend, I can tell you it holds up VERY well. On small, tight, slow tracks it won't offer any advantage at all, but on a fast, medium to large layout, the difference in feel is immediately noticeable.
It does make ride height changes a little more difficult though.
Old 04-17-2013, 08:05 AM   #1077
HenryC's Avatar
AWD
I tried it on mine, but ended up taking it off for two reasons. First, it made changing ride height a pain (you have to remove the diffusor to get to the lower ride height screws). Second reason was all the light hearted ribbing I got about it being 1/12th scale and not a F1 class Actually, the real second reason is the current track layout at the indoor track I race at is a bit more technical than before, so I an not sure if the diffusor would do much now.
It does look good though
HenryC is offline   Reply With Quote
Old 04-17-2013, 08:11 AM   #1078
robk's Avatar
Trader Rating: 22 (100%+)
I have put diffusers on foam tire F1 cars and I guarantee you they work...1/12 should be no different
robk is online now   Reply With Quote
Old 04-19-2013, 10:38 AM   #1079
theatriks's Avatar
I got 2 xtis for sale plus a bunch of tires and spares....pm me!
theatriks is offline   Reply With Quote
Old 04-27-2013, 04:35 AM   #1080
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
shock help!!
What happens if you mount the shock more forward by installing shock mount in forward holes
v-dezign // black diamond
Hoot RC for Local Supplies > www.hootrc.com.au
Me_MrTyson is offline   Reply With Quote
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 563 11-20-2016 08:18 AM
