Like Tree11Likes
Old 02-10-2013, 03:53 PM   #946
Originally Posted by Applesauce View Post
Can someone give me an estimated sensor wire length?
150 mm works on mine
The Hobby Shop,The Ohio RC Factory
T.O.P. Photon CRC XTI, XRAY T4 15 xray xb4 xb8e losi sct 2.0
insanity takes it's toll...please have exact change
bpalmer is offline   Reply With Quote
Old 02-11-2013, 04:08 AM   #947
corally's Avatar
Hello at all
plse what value off roll out for a 13.5 motor?
corally is offline   Reply With Quote
Old 02-12-2013, 10:34 AM   #948
Can anyone tell me what size socket i need for the rear axle nut on my xti with a slapmaster thrust bearing assy ??
car is at home and i am at work and snappy just rolled in
Old 02-12-2013, 10:38 AM   #949
DesertRat's Avatar
11/32"
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 02-12-2013, 11:04 AM   #950
Originally Posted by DesertRat View Post
11/32"
THANKS !
Old 02-12-2013, 01:09 PM   #951
SLOWINSLOWOUT's Avatar
Trader Rating: 19 (100%+)
I'm setting up the electronics on my car. What is the consensus on layout, ESC in front or rear? Also, is the kit set up a good starting point for med/hi traction? One car will be 17.5 boosted, other 10.5 boosted.
SLOWINSLOWOUT is offline   Reply With Quote
Old 02-12-2013, 02:05 PM   #952
Radio Active's Avatar
Can anyone tell me if the diffuser has been released yet, and if so where I can buy it. I can't find it for sale on the CRC site.
Reigning NSW 4WD Group 20 Champion
Member: Maitland Radio Car Club (http://www.morcc.com.au)
twitter: @dvcotton
Australian 12th Scale hastag: #EP12AU
Radio Active is offline   Reply With Quote
Old 02-12-2013, 02:09 PM   #953
Yes part#4170
Just place your order on the website, and reply to the confimation e-mail to order it for the moment.
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 02-12-2013, 02:28 PM   #954
Originally Posted by dumper View Post
Yes part#4170
Thanks.
twitter: @dvcotton
Old 02-12-2013, 02:44 PM   #955
Radi0Flyer's Avatar
Side springs in relation to the pod. Should they be touching or not? If they are supposed to be touching, what's the preload? Mine are a few mm away from touching. I have the kit springs.
Sean
I'll drive it til the wheels fall off and burn
Radi0Flyer is offline   Reply With Quote
Old 02-12-2013, 03:53 PM   #956
CypressMidWest's Avatar
Sean
Just touching, with no pre-load is generally preferable to start with. Then you can experiment with additional pre-load. I personally hate the way my cars drive with "deadband" (springs not touching the pod plate), but some people run the car that way.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 02-12-2013, 04:07 PM   #957
Radi0Flyer's Avatar
Thanks Cypress. Did you use some of the leftover front ride-height shims to lower the spring?
Sean
Old 02-12-2013, 07:32 PM   #958
HenryC's Avatar
Yes part#4170
How do we do that if we are only looking to order the diffuser? Since part # 4170 is not yet on the website, I see no way to place the order. I just received some parts today and do not need anything else yet.
HenryC is offline   Reply With Quote
Old 02-12-2013, 08:13 PM   #959
jsinclair's Avatar
Sean
You adjust them with the 4-40 grub screw in the plate. They are also used to adjust tweak.
jsinclair is offline   Reply With Quote
Old 02-13-2013, 07:03 AM   #960
Radi0Flyer's Avatar
Doh! For some reason I was thinking that grub screw was also holding the pivot ball for the damper tube. I need to pay more attention.
Sean
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 564 06-09-2017 04:00 PM
