Old 01-09-2013, 11:51 AM   #871
Pulse_'s Avatar
Originally Posted by evirobs View Post
Here it goes......HW 1S esc with Hitech 225MG Servo & Ko propo Receiver.
I have since changed to a Futaba 9650 with a little mod on the front brace.
The Hitech servo is crap! lol
Thanks, funny to see we have the same cars considering they aren't the same generation at all
I actually just found a second used HW 1S so we will have this speedo on both cars
https://www.youtube.com/channel/UC1CAwFfuz1K3chBSVpIlSew
Pulse_ is offline   Reply With Quote
Old 01-10-2013, 03:56 PM   #872
Trader Rating: 16 (94%+)
here it is straight from CRC if you have the xti and are converting it to the altered ego chassis and are still running inline you just need the 3 peices from CRC which is called the kit you are not able to run transverse until you buy and add the transverse top plate which is $15.99 and you also have to get the longer links the stock number is 3281 then you can run whatever way u want to.
SFutahrc is offline   Reply With Quote
Old 01-11-2013, 04:48 AM   #873
choisan's Avatar
i am going to buy this car and would appreciate if you could post these 3 part# so that i won't buy anything unnecessary. thanks!
choisan is offline   Reply With Quote
Old 01-11-2013, 06:17 AM   #874
Send a message via MSN to Mark Stiles
3226 - Altered Ego Conversion Kit
32113 - Transverse Battery Tweak Plate
3281 - Side Links
Yokomo - Reedy - Protoform - A-Paint - CML Distribution - Racer Magazine - Zen-Racing - MomentumRC
BRCA 1/12 Electric Circuit Section Chairman
Mark Stiles is offline   Reply With Quote
Old 01-11-2013, 07:01 AM   #875
choisan's Avatar
thanks so much! very much appreciated.
and please, what other parts are crucial to buy as spare
Old 01-11-2013, 02:29 PM   #876
kiwidave72's Avatar
Send a message via MSN to kiwidave72
3281 - Side Links
is there any chance for crc to update their website to included this information.
cheers,
David
Yokomo YZ-4 / Speedpassion 17.5. / Hobbywing v3 ESC
Yokomo BD7 / Speedpassion 13.5 v3. / Hobbywing v3 ESC
kiwidave72 is offline   Reply With Quote
Old 01-11-2013, 03:16 PM   #877
Default new xti main chassis
Just wondering what xti owners here in the USA are doing with the xti are most converting to the alter ego conversion?
bigtee is offline   Reply With Quote
Old 01-11-2013, 03:55 PM   #878
Pulse_'s Avatar
I would like to know more about this too. Is the XTi too nimble or not stable enough for most drivers? Or is it about the type of tracks?
Old 01-11-2013, 04:03 PM   #879
Trader Rating: 38 (100%+)
Both of mine are set up for inline with the kit parts only. I run mostly 13.5 and 17.5 blinky and see no need to change the configuration.
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
Old 01-11-2013, 04:22 PM   #880
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
,Anyone have a high traction set up they r willing to share ? Just picked up xti and some yellow ,graylow, magenta rears and black and pink fronts. Running 17.5 blinky with hw1s and futaba 9651 (I think)servo airtronics receiver.tks
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 01-11-2013, 05:51 PM   #881
choisan's Avatar
For me, i dont really go to the alter ego but just in case i cant fit all my gadgets in it. I dont run 12th scale for more than 20+ yrs. I will put in a futaba gyro for fun. I am afraid the inline is too packed
Old 01-11-2013, 05:53 PM   #882
bvoltz's Avatar
Trader Rating: 44 (100%+)
I'm not the fastest, but here is my sugguestions, let's see what the fast guys think...
Inline setup:
RH Front 3.2
RH Rear 3.5
RH Center 3.3
Center droop 1mm over RH
Center spring Red
Camber .5
Side springs White, just touching
Front spring .5
Kingpin .404
15K oil on the kingpin
30k oil in the tubs (I do my differently then the book so I run 10K, but put a lot on and in the tube and bleed)
Center oil 30wt AE oil
Fronts - CRC Chrome, cut to 1.63
Rears - CRC Low-grey, cut to 1.67
.5 shim under the front center shock ball
0 toe in on front ( I run .5 of toe out, but that is because I want more turn it)
5 on front caster
Car is balanced right to left
I shimmed my servo so the steering links are level across
Total Rear with 171mm
Total Front, one shim on the outside, one inside. but with high bite, full wide..
Roll out (I'm running 92) but that is because of the track... start with 100.
Set dual rate to half the lane.
Mount equipment as low as possible.
1 drop of bearing oil after 2 runs on the wheel bearings.
SXT 3.0 Treat rear full, front 25% to 30% and looking to go as little as possible. Front is pushing on me at the 4 min mark, as in over .7 of second loss in lap times... Need to reduce this, so working on getting a setup that will not fad as bad at the 4min mark... it is really bad at 6 mins to the end....
Ok so fast guys... let see what you think....
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 01-11-2013, 06:20 PM   #883
Well this weekend's race it'll be the tried and true Xi...next race my Xti will be operational again as I just ordered the parts to fix it as well as some other goodies for it
Old 01-11-2013, 07:30 PM   #884
Goodies ? Please elaborate
The Hobby Shop,The Ohio RC Factory
T.O.P. Photon CRC XTI, XRAY T4 15 xray xb4 xb8e losi sct 2.0
insanity takes it's toll...please have exact change
bpalmer is offline   Reply With Quote
Old 01-11-2013, 07:48 PM   #885
Nothing special...just an assortment of springs for center and side, the front upper braces in long and short (long arm one is for my Xi), and the Xti front ride height shim set.
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 563 11-20-2016 08:18 AM
