Team CRC Xti 1/12th Scale!!
#751
Thank you avink007!
I flipped the esc around. We'll see how it goes. I'll post pics but honestly the wiring isn't up to par at all.
Fun kit to build! Went together very well and I've never built a 1/12 scale before. Running it tonight for the first time so we'll see.
#752
broken xti main chassis plate and rear pod plate
Team CRC my main chassis plate and rear pod plate was broken about a month or so ago. i posted on the tread about this and i also posted a few days ago about returning the both for replacement. i have since replace both pieces myself with the original xti chassis and pod plate. i have been looking for the old broken parts to send in for replacement for the newer version of the original xti chassis and rear pod plate. i seem to can't find them. because they was broken i probably threw them away. so what can i do to get the newer version of the original xti chassis?
#753
is there any plan on selling the complete "altered ego" car
would make sense especially over here in europe
#755
Bello ad you know KO 949 fit on Xti?
thanks
thanks
#756
First CRC that I have built, I have some great local CRC guys that I get to race with who gave me some great build advice so it went together well. I have to change my wires to smaller gauge though and a little shorter sensor wire. The car was great first time out, only about 0.1 seconds off the fast lap this last weekend, not too bad since I race against guys that have been top 10 at IIC and one has won Cleveland.
#757
#758
For those who are looking for a setup sheet for the Xti, there is one on petit.
It is not as pretty as Frank and his crew can do but at least it is functional.
#759
I think this may have been asked already but will there be an Altered Ego complete kit coming?
#761
I'd like to reduce the bump toe-in on my Xti. I have the outer ball studs shimmed up and am using an Airtronics 94761 with the Kimbrough 114 servo saver with the inner ball studs mounted in the middle holes. The manual has you add a shim between the servo and the chassis. Is there a purpose for these shims I am missing?
#762
#764
Does anyone know what rating the kit damper tube oil is?
