Old 11-26-2012, 09:50 PM   #661
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Originally Posted by al dente View Post
here is an idea....
call crc and have them send you some more oil.
I've done that and have been through my share of the CRC kit oil. I'm curious so I can make adjustments in oil as I didn't think there were any other oils offered by CRC. Not knowing the brand or CsT makes it a little harder to go up or down a known amount. But you're right, calling CRC is a great idea to get help. John always answers my questions.
Old 11-26-2012, 09:56 PM   #662
schreff's Avatar
Send a message via AIM to schreff
The kit shock oil in the Xti kits is Losi 30wt. That should take away any unknowns so you can test using the same brand oil.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 11-27-2012, 05:58 PM   #663
jarrodh's Avatar
thanks brian..
today i picked up some gears.. and got my rollout to 107.9.. 56/75.. biggest i could go with with the spur.. smallest the shop here had..
also, put it back to the 5 deg blocks, and shortened the pin length..
picked up another set of the grey-low/black tires, and a set of front chrome tires to try.
cant wait till the weekend..i think its ready to go..just need to set it back to blinky, and tweek it.. dont have the equipment here in my dorm to do that..haha..
www.irocc.ca
jarrodh is offline   Reply With Quote
Old 11-28-2012, 05:30 AM   #664
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Default Set up info
Hey Guys,
I just got back from the US Indoor Champs and thought I'd share my set up info with you.
I ran 1/12 17.5 Masters, TQ'ed and won the main with the following set up:
.50 front springs (.01" gap between stearing block and lower pivot)
10* blocks
1* camber
black fronts at 1.62"
3.5mm clearance
stock shock oil
red spring
1.5mm droop
outside of tubes raised with 20k
orange side springs
3.5mm clearance on back of chassis
3.5mm clearance on front and back of lower pod plate
magenta rears at 1.66"
Here's a pic
Announcing the new Team CRC Xti 1/12th Scale!!-dscn9394.jpg
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is online now   Reply With Quote
Old 11-28-2012, 05:39 AM   #665
Default upper pod plate question
does anybody know if the #1762 extended upper pod plates (the ones that have the longer tab where the top end of the shock attaches) will fit on the new XTI slider pod?
vafactor is offline   Reply With Quote
Old 11-28-2012, 07:14 AM   #666
They do not fit.
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 11-28-2012, 09:20 AM   #667
Default xti
wish i can get my xti to work car is vary aggressive
bigtee is offline   Reply With Quote
Old 11-28-2012, 09:26 AM   #668
sg1
sg1's Avatar
Try my set up a few posts above.
The first race day the car was too aggressive, with the set up on there now it's smooth and easy to drive.
Old 11-28-2012, 10:40 AM   #669
Do you have the roll center spacers? That will calm the car down. It should decrease your front camber gain.
malkiy is offline   Reply With Quote
Old 11-28-2012, 12:02 PM   #670
i have mine pretty much setup the same way i didn't raise damper tubes
Old 11-28-2012, 12:06 PM   #671
sg1
sg1's Avatar
If you are running the same tires I listed, try chrome fronts.
Those had a slight push to them when I tried them.
Old 11-28-2012, 12:11 PM   #672
sg1
sg1's Avatar
One other thing I forgot to list, I used orange side springs.
Those are 2 steps softer then the kit white.
Old 11-28-2012, 12:13 PM   #673
303slowdown's Avatar
Trader Rating: 19 (100%+)
Are the orange side springs mudslide springs?
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 11-28-2012, 12:15 PM   #674
sg1
sg1's Avatar
To be honest I'm not sure who made them.
I borrowed them from a friend who has had them in their oval box for years..lol..
I originally tried Assoc. springs, but they were too soft.
Old 11-28-2012, 09:38 PM   #675
gijoe64's Avatar
Trader Rating: 27 (100%+)
Selling my unused Gen Xti
New unused Gen Xti with TP 10.5 motor and JR 3717
Raymon Robinson
ARC, LRP Go Blue!!
gijoe64 is offline   Reply With Quote
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 563 11-20-2016 08:18 AM
