Like Tree31Likes
Old 11-20-2012, 06:30 AM   #631
Originally Posted by avink007 View Post
Does anyone know the steering turnbuckle length? Thanks in advance for the info!
42mm
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 11-21-2012, 10:44 AM   #632
theatriks's Avatar
Does anybody know the part number for the front spring kit on the XTI
theatriks is offline   Reply With Quote
Old 11-21-2012, 10:57 AM   #633
Trader Rating: 19 (100%+)
i personally do not know of a "kit" or "set" but all the optional springs are on the website. the kit comes with .50 springs on it so youll just need the .45, .55, and .60 springs for it and that should set you up.
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 11-21-2012, 11:00 AM   #634
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I know the center and side springs come in kits, but I am pretty sure the front springs are sold only in pairs.
3390 - Front End Spring .45 mm
3392 - Front End Spring .50 mm
3394 - Front End Spring .55 mm
3396 - Front End Spring .60 mm
These are the old black springs as far as I know, but as I posted above, I think there are some new springs, I'm not sure if they are new numbers or?
Old 11-21-2012, 11:28 AM   #635
Trader Rating: 15 (100%+)
Originally Posted by FaanP View Post
Can somebody please explain this to me: http://www.petitrc.com/reglages/spee...hassisSag.html
Sounds like the same thing ... and what is the effect?
I have always thought of it like the difference between measuring downstop height and droop over ride height. Pod Droop doesn't take ride height into account, chassis sag does.
Maybe I have it completely wrong, but that is how it makes sense to me.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 11-24-2012, 10:57 PM   #636
jarrodh's Avatar
anyone got advice on how to get more mid/late corner steering? it turns in good, and handles good.. but on sharp low speed corners, seems like i have to wait on the car before i can start to accelerate off the corner
pretty well stock box set, with slightly longer kingpin length, and stiffer damper fluid, and 2 caster shims at the back. and the cf upper suspension brace
www.irocc.ca
jarrodh is offline   Reply With Quote
Old 11-25-2012, 12:08 AM   #637
Are you running the 10* caster blocks?
Old 11-25-2012, 09:04 AM   #638
What weight oil is included for the rear shock? I can't seem to find that info in the Manuel, I'm guessing its probably 30wt .
dan22 is offline   Reply With Quote
Old 11-25-2012, 10:20 PM   #639
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
Dan22; 30wt.... it's about all they use, stock, race. Depending on your class, track smoothness, you can go up/down 5wt.
Jarrod; If you make it to the Gym next week, come see me: Brian Bodine. What class are you racing? Stock/Mod. Inline/trans? Tires? Anytime you have steering push, take the braces off, only run them if you are traction rolling or need to take that little "edge" off of steering. I found the trans chassis better for my style and it allowed me to move the battery fore/aft to get that weight bias effect. You can also do the same thing by putting the bullet plug fwd/rearward. If you are running stock, yel/black is going to be the combo to use about 90% of the time. If you want to get a bit more "racy" try graylow/chrome, you may need to CA the front side walls. You can also use yel/mag with CA. If you are kit, it came with .50 front springs. Try .45's. Your king pin should measure .400 to .404". Watch out for new and old front springs, they are silver and black, they are different lengths. Start with .400" front king pin with silver springs and .404" with black springs. You can vary from there, but I wouldn't go beyond .003"+. Then, what body? Audi R8C? That is the best for this car for stock. If you are going faster: Mohawk. Camber should be set about -.5*. I tell guys to use as much camber as you can until it traction rolls, then back it off. If your car is twitchy up front and pushy at the end, try less camber and more dope till it gets it right.
Stay dialed my friends!
www.slapmastertools.com
Team Roche USA
Team Orca orcharc.com
Slapmaster6000 is offline   Reply With Quote
Old 11-25-2012, 11:05 PM   #640
Anyone happen to know what brand 30wt it is?
Old 11-26-2012, 06:05 AM   #641
theatriks's Avatar
30wt is just the viscosity ....any manufacturer like Losi...associated..mugen...etc ...will all make 30wt.
Old 11-26-2012, 07:22 AM   #642
locked's Avatar
The same "weight" from different brands can have very different cst ratings. Not all 30wt is the same viscosity. I assume that's why he was asking which brand.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 11-26-2012, 07:58 AM   #643
theatriks's Avatar
if i need 30wt oil i go buy a bottle that says 30wt on it ....i dont bring it to a lab and test all manufacturers 30 wt.......30 wt is 30 wt if there off between different brands a bit its not gonna make a huge difference.
Old 11-26-2012, 08:16 AM   #644
locked's Avatar
No need to take them to a lab. It's written on the bottles. 30wt from one brand is 300cst, but 30wt from another brand is 400cst. You seriously believe there's no noticeable difference between 300cst and 400cst?
Dave Locke
Old 11-26-2012, 08:21 AM   #645
wingracer's Avatar
Trader Rating: 23 (100%+)
Most 30 wt is fairly close but there are some that are way different. I believe the old Serpent 30 wt was more like 50 in most other brands.
Just pick a brand you like and stick with it. I use pretty much all Losi oils.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 565 09-25-2017 04:19 PM
