Like Tree3Likes
Old 11-15-2012, 09:47 PM   #616
corallyman's Avatar
Trader Rating: 97 (100%+)
Originally Posted by FaanP View Post
How do you get to 1.81 if everybody is giving 2 cents? Or is the income tax already deducted?
That's easy, Slapmaster's opinion is worth .03 cents
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 11-17-2012, 08:20 PM   #617
Default xti inline setup or transverse
would like to get a general consensus on the inline or transverse setup i have mine setup inline but i am seeing seasoned local guys in my area are setup transverse and when asked why the say that they don't like the way the inline handles. looking for some opinions form the seasoned crc drivers or team crc thanks
bigtee is offline   Reply With Quote
Old 11-17-2012, 08:43 PM   #618
Default inline vs transverse
when I first got my XTI, I built it inline. With the battery down the middle it steered super hard (a good thing) for 5 or 6 minutes. But towards the end of each run (always in 13.5 blinky) the car would always start hooking the corners abruptly which had the effect of killing the car's momentum. I was unable to find an inline setup that didn't stall in the corners at the end of the runs, so I fitted the transverse setup. With the weight of the battery farther back in the car, that does seem to forefit some of the early-run super agressive steering. But it does help the car towards the end of the runs. For me, the transverse battery arrangement has been more consistent and therefore slightly better than the inline arrangement.
vafactor is offline   Reply With Quote
Old 11-18-2012, 02:14 AM   #619
FaanP's Avatar
Does anybody have a shore chart or something similar of the CRC tires? Or just a listing from soft to hard?
When in doubt - GAS IT!!
FaanP is offline   Reply With Quote
Old 11-18-2012, 04:42 AM   #620
b_recliner's Avatar
Trader Rating: 22 (100%+)
12th Scale Racing is Alive and Well in So Cal
there is a foam tire rating writeup near the top not too mention a plethora of other useful information all relating to 1/12. the gentleman who put this thread together deserves some serious props.
Tracks: Richfield Raceway, LCRC, DRP
Current Cars: Xray t4 '14, Schumacher Cougar KF, Schumacher Mi5, Losi 22 2.0, Losi 8ight E 3.0
b_recliner is offline   Reply With Quote
Old 11-18-2012, 06:10 AM   #621
Originally Posted by vafactor View Post
... so I fitted the transverse setup. With the weight of the battery farther back in the car, that does seem to forefit some of the early-run super agressive steering.
Are you saying your car is less aggressive with the battery further rearwards???
JamesL_71 is offline   Reply With Quote
Old 11-18-2012, 08:39 AM   #622
WRR
Less weight over the front wheels. Moved the balance further back I suppose.
A 45/55 ratio is what I have found to be ideal in 13.5
Xray X12 - Schumacher K1
WRR is offline   Reply With Quote
Old 11-18-2012, 09:23 AM   #623
Trader Rating: 19 (100%+)
It takes weight off the front tires which means they dont get as much heat in them so they do not "gum up" so much during a race so the car is not as aggressive late in the run as he was saying. transverse setup is more consistent throughout the run, however, Andrew Knapps setup works very well throughout the run. Personally I am using his inline setup with 10* front reactive caster instead of the 5* that he uses and it is a very smooth setup and is well worth a try.
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 11-18-2012, 04:55 PM   #624
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Originally Posted by dumper View Post
Wheelbase is the same as the XI. Body mounts are the same too.
Diffuser will be coming soon.
Any more info on an ETA for the diffuser?
Old 11-18-2012, 09:24 PM   #625
Default Jr Sport MN48 Servo
Has any one tried this servo: Jr Sport MN48? Is it any good?
Announcing the new Team CRC Xti 1/12th Scale!!-jsp20040.jpg
BIGBOT is offline   Reply With Quote
Old 11-19-2012, 06:26 AM   #626
It works ok, but with the speed being .19 it is kind of slow.
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 11-19-2012, 12:29 PM   #627
FaanP's Avatar
Can somebody please explain this to me: http://www.petitrc.com/reglages/spee...hassisSag.html
Sounds like the same thing ... and what is the effect?
Old 11-19-2012, 02:48 PM   #628
sag is when the middle of the fully loaded and race ready car is slightly lower than the back of the pod. Sag can be created (or increased) by loosening the collar that puts tension on the center spring.....allowing the middle of the car to "sag" down closer to the track. By contrast, droop is the the amount that the middle of the chassis can be raised up beyond ride height before the rear tires lift off the ground. Droop can be created (or increased) by lengthening the shock itself. Myself, I always adjust my shock spring so that the bottom of the race ready chassis plate is level (no sag). And I adjust the fully extended length of the shock so that the middle of my car will raise up slightly (1/2 to 1mm) beyond level before the rear tires lift off. That range always seems to work for me.
Old 11-19-2012, 10:40 PM   #629
I thought I remembered reading something about new silver springs on the Xti,but I can't find it now? Anyone remember? Ran mine for several packs today and it seems the kit,silver 50's I think, springs collapsed, something I haven't had happen before with the dark springs. Anyone else notice something similar?
Old 11-19-2012, 11:16 PM   #630
Does anyone know the steering turnbuckle length? Thanks in advance for the info!
avink007 is offline   Reply With Quote
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 563 11-20-2016 07:18 AM
