Old 10-30-2012, 08:53 PM   #436
Originally Posted by andrewdoherty View Post
Anyone know where to buy a Sanwa SRG-HR to be shipped to the US? My LHS can not get them, and everywhere I know to look online either doesn't carry it or is out of stock with no ETA.
CRC Raceway and Hobby has the Airtronics 94761 (not HV) version in stock. Not the SRG-HR, but it works pretty well and may be a better choice if you run a speedo with a built in booster.
Team CRC is offline   Reply With Quote
Old 10-30-2012, 09:00 PM   #437
Originally Posted by bigtee View Post
i cracked my main chassis right where the front body post mounts on both sides. what i did to protect the front chassis more was i took a slapmaster 1/12 bumper and mounted it on the car i then press it tightly to the chassis i then traced the outline of the front chassis, i then shaved down the bumper so that the front of the chassis is flush with the bumper. the front edge of the chassis is protected real nice. let me know what you think of this idea.
The Slapmaster bumper or the CRC 3259 fitted to the Xti front body posts will practically eliminate any chassis breakage.
Old 10-30-2012, 09:33 PM   #438
thanks for the info i have a new chassis coming ordered by middle river hobbies in Maryland my lhs. i will be ordering a few crc 3259 as well if mrh don't have them in stock.
bigtee is offline   Reply With Quote
Old 10-30-2012, 09:39 PM   #439
Default team
when will the diffuser be available
Old 10-30-2012, 09:40 PM   #440
Default Team CRC diffuser for xti
when will it be available
Old 10-30-2012, 10:01 PM   #441
BCbud's Avatar
Trader Rating: 37 (100%+)
i would like to see some pic of that. i know crc sell some type of lexan bumper
This is my first one, a little rough but it should be functional.
Announcing the new Team CRC Xti 1/12th Scale!!-dscf0002.jpg   Announcing the new Team CRC Xti 1/12th Scale!!-dscf0003.jpg
Xray NT1 - Xray T4 2013 TC - Xray T4 2013 VTA - CRCgenX10 - CRCgenX - CRCgenXi - Slash 4X4 with LCG conversion -Associated RC8Be - Xray XB4 - DX3R PRO
Recycled teenager.
www.irocc.ca ; www.corvictoria.com ; http://www.wcics.ca/
I will not send Pay Pal as a gift or add fees to the price so DO NOT ASK!
BCbud is offline   Reply With Quote
Old 10-30-2012, 10:22 PM   #442
Trader Rating: 39 (100%+)
I built my own "what I thought" was lexan and it tuned out to be a pvc and the first hit to a wall it exploded
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 10-30-2012, 10:28 PM   #443
BCbud's Avatar
This is what I used.
Announcing the new Team CRC Xti 1/12th Scale!!-dscf0005.jpg
Recycled teenager.
Old 10-31-2012, 12:50 AM   #444
to me that's a bad idea there is no give you will still brake the chassis if hit hard. thanks for the pic
Old 10-31-2012, 07:58 AM   #445
BCbud's Avatar
CRC makes one that I based my design on.
http://www.teamcrc.com/crc/modules.p...od&prodID=1357
Recycled teenager.
Old 10-31-2012, 09:39 AM   #446
yea i think that was and idea early on, but don't think crc uses it or any team drivers. i never seen anyone with it on any 1/12 scale cars. like i said i think it was and early idea. but if that what works for you then stay with it. good luck. that may have been intended for asphalt use
Old 10-31-2012, 02:43 PM   #447
any type of rigid bumper will have two big drawbacks: 1) rigid bumpers are heavy, which is especially problematic with all of that added weight hanging out in front of the front wheels, and 2) upon impact there is huge stress put on the attachment screws and in turn on the chassis in the area where the screws go thru. That force risks pulling the screws thru the graphite or making the chassis plate delaminate. Foam bumpers are way better for 3 reasons : A) they weigh almost nothing, B) they protect the chassis better, and C) they also protect and support the body nicely. CRC sells a nice foam bumper, Slapmaster sells one, and AE also sells a very small one for the R5 cars that will also fit.
vafactor is offline   Reply With Quote
Old 10-31-2012, 05:35 PM   #448
Slapmaster6000's Avatar
Trader Rating: 15 (100%+)
You can use Kimbrow spurs, just remove the 2 1/4" shims from the diff by the red spacer and you may need to reshim the axle for center. Using the 1/8" diff balls will move the diff side tire out 2 shims worth.
Frank watched me plow into outside wall in the front chicane at IIC. After I bounced what felt like 30' backwards, I drove off. Slapmaster part number #105 - black foam bumper, 4 grams. Wasn't a moment of grace, but I did finish my race. I did shear the e-clip off inside the shock. There was just no way it was going to stay in place with that kind of rapid deceleration. Moral to the story: run a foam bumper! A few bucks for a bumper is way less then a chassis, body damage, and wasting your time in the pits putting a new chassis under the car.
Think I'm going to ring some door bells for candy.
Brian
Stay dialed my friends!
www.slapmastertools.com
Team Roche USA
Team Orca orcharc.com
Slapmaster6000 is offline   Reply With Quote
Old 11-01-2012, 12:33 PM   #449
Trader Rating: 38 (100%+)
Originally Posted by bvoltz View Post
Help...
I have built the car but I get ZERO ride height in the front.
What do I have wrong? I have attached pictures to show how it is built....
Fronts are cut at 1.65
I have taken all the shims out....
This is probably a stupid question, but did you install the springs on the kingpins correctly? From the photos it looks like they are compressed a lot or not there.
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
Old 11-01-2012, 01:05 PM   #450
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
Help...
With that size tire you have to take the alum. spacers between the chassis and The front end mount plate out. They are ment for full size front tires. You will need the optional l ride height shims to get to the correct ride height.
Link- http://www.teamcrc.com/crc/modules.p...prodID=7719457
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 563 11-20-2016 08:18 AM
SEO by vBSEO 3.5.0
