Like Tree31Likes
Old 10-21-2012, 02:48 PM   #346
Trader Rating: 40 (100%+)
I find the more pod droop the more forgiving the rear end is. Not a tonne more rear traction but easier to drive. But also can feel lazy getting onpower. I only run less than 1mm to none. I have tried more but it's not a feeling I like
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 10-21-2012, 02:58 PM   #347
Blue Screw's Avatar
Send a message via AIM to Blue Screw
Mark Erce...
by looking at the spec's of that servo the torque might be a little to low.. def has the speedo though... still would suggest the KO pds 951, fut 9650, and the sanwa
Originally Posted by Mark Erce View Post
seems like the other crc xi thread is dead so sorry for posting this stuff here but can someone please tell me if this will work in my crc xi before i buy it. thanks
http://www.amainhobbies.com/product_...-Digital-Servo
theatriks,
They look very similiar to the TRC rims from trinity
Originally Posted by theatriks View Post
Who makes those wheels?
Angelo DAlessandro
AE~REEDY~LRP~JCONCEPTS~NOVAROSSI~HUDY~IRS~KALGUARD ~ABSOULUTE HOBBYZ~GRAVITY-RC~TnT CUSTOM GRAPHICS
NITRO ONROAD
XRAY~RCAMERICA~HUDY~SRC~MURNAN MODS
Blue Screw is offline   Reply With Quote
Old 10-21-2012, 04:03 PM   #348
jarrodh's Avatar
anyone else having problems killing/exploding the LR axle bearing? i didnt get to finish a race the other day because i killed 2 of them.. 1 one in the first heat and another 3 minutes into the main..
anyone else?
www.irocc.ca
jarrodh is offline   Reply With Quote
Old 10-21-2012, 04:36 PM   #349
theatriks's Avatar
anyone else?
Im not sure dont have the car yet....btw what size is that bearing?
theatriks is offline   Reply With Quote
Old 10-21-2012, 06:55 PM   #350
Trader Rating: 38 (100%+)
anyone else?
I haven't had any issues, it made the entire week at the IIC and two days of local races here already. The only thing I can think that would cause you to be killing the axle bearings is bad bearings to begin with or your pod might not be set level left to right and this would cause one or both bearings to bind.
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
Old 10-21-2012, 08:34 PM   #351
jarrodh's Avatar
its the same size bearing as the old cars.. dont know the exact measurements off hand..
could be out of level.. but its pretty damn close with my mic... and both times it was the same side/bearing
i think that now the bearing are mounted in aluminum, rather than the plastic inserts of the older cars, that there is no give anymore.. and that little collar/spacer between the hub and the bearing just drives the center race out everytime theres contact.. ive never in all my years runnin crc cars even blown a rear axle bearing, nevermind 2 exploding in the same night, back to back.
im goin to see if i can get/make a washer that is the same O.D as the bearing, maybe itll hit flat rather then punch the center out..?
www.irocc.ca
Old 10-21-2012, 09:54 PM   #352
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Sounds like a recipe to create a bind in corners as the axle will no longer have an effective bearing on the outside.
Old 10-21-2012, 10:14 PM   #353
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
I have to ask that brutal honest question: does your track have some hard barriers and are you getting in contact with them?
I ran my Xti hard into a fastened barrier at IIC into the left rear. It didn't improve its smoothness, but I didn't kill it either. If you are concerned about your track being too firm, slide a 3/16" o-ring on the axle and then shim with 1/4 spacers... make a little cushion out of it.
Brian
Stay dialed my friends!
www.slapmastertools.com
Team Roche USA
Team Orca orcharc.com
Slapmaster6000 is offline   Reply With Quote
Old 10-22-2012, 12:55 AM   #354
anyone else?
I blew out 2 rear bearings at the IIC...one in my Xi and one in my Copperhead 10. Wasn't either of the car's fault...I just kept hitting stuff
Old 10-22-2012, 09:32 AM   #355
Originally Posted by Andrew Knapp View Post
13.5 CRC XTI transverse
.55 front spring
.404 king pin length
5 degree caster
.5 degree camber
Crc red center spring
30wt oil in center shock
4mm pod.droop
3.5mm ride height. Front , center and rear.
Magenta front tire
Magenta rear tire
White side springs 1.5 turns down... Fairly compressed
50000 dampner tube lube
Crc.black art audi r8c body
Hobbywing 1s speedo
Trinity d3.5
Revtech batteries
Spektrum radio
Crc xti inline .55 front spring
5 degree caster
.5 degree camber
Crc black center spring
2mm pod.droop
Magenta front tire
pink rear tire
blue side springs just touching
20000 dampner tube lube
Protoform amr
Lrp sxx v2
Trinity d3.5
Revtech batteries
Spektrum radio
how is the king pin length measured?
dlandaker is offline   Reply With Quote
Old 10-22-2012, 09:41 AM   #356
I want to know this too The king pin is always angled. Which side do you measure? Front, side or rear? I do know you measure from the c-clip to the knuckle.
malkiy is offline   Reply With Quote
Old 10-22-2012, 10:07 AM   #357
al dente's Avatar
we measure kingpin length from the steering block to the bottom of the e clip groove. basically you are taking the measurement of the eclip, spring and pivot ball, if that makes sense. the king pin should not be angled unless it is screwed into the steering block wrong, or bent. there is a moulding seem on the steering block, try not to measure from there, but always try to go from the same spot. i.e., even with where the set screw goes in, or something like that.
Team CRC / Dumper's Speed Shop / Team Scream Racing / Black Art
RC America / FB/FX / Colorado On Road RC Club
5280 Raceway (5280raceway.com) home of the MILE HIGH INDOOR CHAMPS April 19-22, 2018
al dente is offline   Reply With Quote
Old 10-22-2012, 10:26 AM   #358
thanks for the prompt reply.
how does a shorter king pin length effect the handling?
Old 10-22-2012, 02:40 PM   #359
Default wind tunnel racing product shur lube
does anyone know the exact weight of the lube 1-6? the web site says that 1 is the thinnest and 6 is the thickest but i want to know what i am using for set up of my xi and xti cars not just guess so if someone has some info the different colored lubes please let me know thanks
bigtee is offline   Reply With Quote
Old 10-22-2012, 02:48 PM   #360
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
Not sure of the exact weight rating on it but when I used that stuff in the past I always ran Green #3 or Red #4
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 565 09-25-2017 04:19 PM
