Like Tree4Likes
Old 10-16-2012, 03:26 PM   #286
Trader Rating: 40 (100%+)
Last Year I ran a personally modified Futaba 9650 between the front end mounts (forward) in my old GenX that I like to play with modding and it ran great. Just had to remove the entire left mounting ears and shoo goo it to the chassis. Worked flawlessly.
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 10-16-2012, 06:31 PM   #287
smyka's Avatar
Send a message via AIM to smyka
I have run every 1/12 servo ever made I think and I found that the new airtronics/sanwa works awesome and no cutting of cases required just bolt in and run
Trinity, Proline ,EA motorsports, T.O.P Racing ,Futaba ,Bsr Racing tires ,Advantage racing products,Hot Bodies racing,Tq Wire ,REDS Racing, Orca ,Protoform racing
smyka is offline   Reply With Quote
Old 10-16-2012, 06:54 PM   #288
Originally Posted by theatriks View Post
Does anybody know if this car is in stock at calandra?
A bunch of kits shipping tomorrow and early next week. We should be fully caught up by this time next week. Thanks for your support and patience.
Team CRC is offline   Reply With Quote
Old 10-16-2012, 07:01 PM   #289
b_recliner's Avatar
Trader Rating: 22 (100%+)
What is the timeframe on the xt to xti conversion kits?
Tracks: Richfield Raceway, LCRC, DRP
Current Cars: Xray t4 '14, Schumacher Cougar KF, Schumacher Mi5, Losi 22 2.0, Losi 8ight E 3.0
b_recliner is offline   Reply With Quote
Old 10-16-2012, 07:14 PM   #290
theatriks's Avatar
No problem...thanks for the info
theatriks is offline   Reply With Quote
Old 10-16-2012, 07:29 PM   #291
Mark Erce's Avatar
Trader Rating: 77 (100%+)
I have a CRC XI and I'm having issues installing the servo mounts(little black L shaped ones) I have a savox and a KO standard servo. seems like the holes in the chassis dont line up. is there something i'm missing???
<> St.Louis Dirt Burners <> Smac Trac <> Tiny Boat Guy Paint Designs <> VP Pro USA
Mark Erce is offline   Reply With Quote
Old 10-16-2012, 07:35 PM   #292
up until the latest super skinny version of car, all the CRC chassis plates have come drilled for Jr size servos placed on the right side of center and with a different set of mounting holes so that Futaba/airtronics/and I believe KO sized servos will bolt up to the holes that are provided on the left side of center. If your servo doesn't look as if it is lining up with the mounting holes on one side of the chassis, try flipping the servo over and using the different offset holes that are on the other side of the chassis plate.
vafactor is offline   Reply With Quote
Old 10-16-2012, 07:37 PM   #293
That car takes a smaller servo. I use a JR Sport MN48. Works great!
I am The Stig!
"First things first, but not necessarily in that order". -Doctor Who
jayman24 is offline   Reply With Quote
Old 10-16-2012, 09:19 PM   #294
Mark Erce's Avatar
hey thanks for the info! what are some other good options for servos. i dont know anything about these mini/micro servos! i got a KO Eurus with a 407 and 409 rx's if that even matters. thanks again for the tips
sorry,,,,go figure I read back just one page and I see the answers to my question lol
Old 10-16-2012, 09:58 PM   #295
What is the airtronics part number for this servo?
BIGBOT is offline   Reply With Quote
Old 10-16-2012, 10:04 PM   #296
Mark Erce's Avatar
Originally Posted by linkless View Post
Honestly the only logical servo to get for it currently is the Sanwa. The Futaba doesn't fit in the forward position, the Spektrum isn't currently available and the JR costs quite a bit more than the Sanwa. I have the Sanwa in mine and wish I had put it in my Xi instead of the more expensive JR.
where can you find this sanwa servo? does anyone here have any experince with the Hitec HS-225MG servo? according to the manual thats what this car recommends and Amain seems to have it in stock and its not expensive. what do you think?
Old 10-16-2012, 10:15 PM   #297
Trader Rating: 38 (100%+)
I am using the Airtronics 94761Z High Speed High Torque Micro Digital Servo (copy and paste).
I believe you should be able to get them anywhere, mine was 64.99 from Amain.
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
Old 10-17-2012, 01:16 AM   #298
Stay away from Hitec...just stay away...
Old 10-17-2012, 04:21 AM   #299
smyka's Avatar
Thanks link less that's the one I use
Old 10-17-2012, 05:13 AM   #300
could these servos work?
Features and Specifications:
• Torque at 4.8v: 28oz-in (2.0kg-cm)
• Torque at 6.0v: 33oz-in (2.4kg-cm)
• Speed at 4.8v: 0.08sec/60
• Speed at 6.0v: 0.07sec/60
• Weight: 0.99oz (28.0g)
• Dimensions: 1.26 x 0.63 x 1.24in (32.0 x 16.0 x 31.5mm)
• Gear Train: Nylon
• Bushing/Ball Bearing: Dual Ball Bearing
• Motor Type: Coreless
• Torque at 4.8v: 35oz-in (2.5kg-cm)
• Torque at 6.0v: 39oz-in (2.8kg-cm)
• Speed at 4.8v: 0.12sec/60
• Speed at 6.0v: 0.10sec/60
• Weight: 0.38oz (10.8g)
• Dimensions: 0.93 x 0.45 x 0.83in (23.5 x 11.5 x 21.0mm)
• Gear Train: Metal
• Bushing/Ball Bearing: Single Ball Bearing
• Motor Type: Standard 3-Pole
• Torque at 4.8v: 21oz-in (1.5kg-cm)
• Torque at 6.0v: 25oz-in (1.8kg-cm)
• Speed at 4.8v: 0.07sec/60
• Speed at 6.0v: 0.06sec/60
• Weight: 0.68oz (19.2g)
• Dimensions: 1.16 x 0.47 x 1.02in (29.5 x 12.0 x 26.0mm)
• Gear Train: Metal
DS3517MG High-Speed Mini Servo MG
Specs
Size Category: Minis and Micros
Type: Digital
Application: Small Airplane and Small Helicopter Cyclic
Torque: 42 oz-in @ 4.8V, 51 oz-in @ 6V
Speed: .11 sec/60 degrees @ 4.8V, .09 sec/60 degrees @ 6V
Length: 1.02 in
Width: 0.58 in
Height: 1.30 in
Weight: 1.04 oz
Bushing Or Bearing: Bearing
Connector Type: JR
Gear Type: Metal
154 Digital High-Torque Micro
FUTM0654
Volts Torque Speed
4.8V 21 oz-in (1.5 kg/cm) 0.10 sec/60
6.0V 24 oz-in (1.7 kg/cm) 0.09 sec/60
Dimensions Weight
7/8 x 7/16 x 13/16 in
(22 x 11 x 20 mm) 1/4 oz (7.9 g)
S3157 High-Speed/High-Torque Micro
FUTM0657
Volts Torque Speed
Dimensions Weight
7/8 x 7/16 x 7/8 in
(22 x 11 x 23 mm) 5/16 oz (8.3 g)
3P
Tim3 is offline   Reply With Quote
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 563 11-20-2016 07:18 AM
