Like Tree3Likes
Old 10-12-2012, 11:35 AM   #241
howardcano's Avatar
Trader Rating: 35 (100%+)
Originally Posted by InspGadgt View Post
I got tired of dealing with boosters and got a VTX1 ESC instead
I'm quite happy with my four Novak Havoc 1s ESCs with their built-in boosters. I use the Novak Smart Boost for my ESCs that don't have the booster built-in.
Now we should probably get back on topic.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 10-12-2012, 12:07 PM   #242
Trader Rating: 58 (100%+)
Yeah, like how sweet itll be to have real front ride height shims.
MC112b is offline   Reply With Quote
Old 10-12-2012, 12:43 PM   #243
True back on topic...I expect to purchase my XTI next month...sooner if I can
Old 10-12-2012, 01:43 PM   #244
Could someone please post Smyka's and Lambert's setups from the IIC? Trying to get a baseline for my 17.5 setup on high bite carpet.
malkiy is offline   Reply With Quote
Old 10-12-2012, 02:09 PM   #245
FaanP's Avatar
Here she is .... whoohoo. Taking her out for the first time on Sunday.
When in doubt - GAS IT!!
FaanP is offline   Reply With Quote
Old 10-13-2012, 03:38 AM   #246
Originally Posted by smyka View Post
i love scales but thats me i use them to set a car up for the first time and i move electronics out to find the best cross weight so tweaking the car will be a ton easier and the car will drive way smoother .
i can send you pictures of my car if you want but i did stick a 1/4 ounce of weight on battery as far back on right side as i could
send pics
bigtee is offline   Reply With Quote
Old 10-13-2012, 09:17 AM   #247
smyka's Avatar
Send a message via AIM to smyka
BIGTEE send me a text 860 716 5720 i can never get pictures to post here
as for setup this is what i ran and kenny was clost i believe his frontend was a touch different
front
10 degree reactive but raised 2mm (between arm and reac. block )
two shims back one forward
crc graphite brace across top arms
short arm .5 camber
50 front springs 15k lube on king pin
.5 toe out in nose
middle
stock kit white spring front raised .30
30 wt oil
.5mm droop
rear
20k tube lube
associated blue side springs just touching then tweak
rear max roar width
standered xti configuration (battery inline)
for tires i ran bsr white rears(crc yellow) and grey fronts with saftey glue only
crc black art body mounted 2 mm more forward then stock holes
my car weighted 732 grams with 7 grams added to left side rear
Trinity, Proline ,EA motorsports, T.O.P Racing ,Futaba ,Bsr Racing tires ,Advantage racing products,Hot Bodies racing,Tq Wire ,REDS Racing, Orca ,Protoform racing
smyka is offline   Reply With Quote
Old 10-13-2012, 09:36 AM   #248
theatriks's Avatar
What battery are you guys running i was looking at the calandra shorty pack cln3703 but its only 4200 mah im think thats not enough for a 8 minute main...any reccomendations?
theatriks is offline   Reply With Quote
Old 10-13-2012, 05:45 PM   #249
wingman2's Avatar
Our local club runs 10.5 blinky on a quite small (7 sec lap) track.
An 8 minute run takes about 2500mah from the pack (Revtech motor and LiPo).
Sponsored by CML Distribution - http://www.cmldistribution.co.uk
wingman2 is offline   Reply With Quote
Old 10-13-2012, 07:11 PM   #250
theatriks's Avatar
Really....ok then i will stick with that battery then....thanks
Old 10-13-2012, 09:35 PM   #251
It depends on the class and the track. At our local track with 13.5 blinky I come off the track with only about 500-800mah to spare. At the IIC in 13.5 blinky I had a bit more at the end of the run but not much.
Old 10-14-2012, 08:29 AM   #252
theatriks's Avatar
Were you using the rocket 4200 mah pack?
Old 10-14-2012, 08:30 AM   #253
theatriks's Avatar
Also are these in stock at calandra ?.....im getting sick of waiting for horizon to get these in stock.
Old 10-14-2012, 08:35 AM   #254
b_recliner's Avatar
Trader Rating: 22 (100%+)
what's the timeline on the xt to xti conversion kits?
Tracks: Richfield Raceway, LCRC, DRP
Current Cars: Xray t4 '14, Schumacher Cougar KF, Schumacher Mi5, Losi 22 2.0, Losi 8ight E 3.0
b_recliner is offline   Reply With Quote
Old 10-14-2012, 10:40 AM   #255
Yes I was using the 4200mah shorty pack. When I get my Xti I plan to go back to a normal sized 1 cell pack.
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 563 11-20-2016 07:18 AM
