Old 10-09-2012, 12:36 PM   #211
theatriks's Avatar
hey will cln3381 ride height spacers work with the xti?
theatriks is offline   Reply With Quote
Old 10-09-2012, 12:43 PM   #212
Originally Posted by LonnyJ1950 View Post
The fact that your weights are off diagonally suggests your car is tweaked. Back the side springs all the way off and disconnect the damper tubes and see if that makes a difference. Also be sure the scales and car are level side to side and front to back.
what spring r u referring too all of them? ok i missed read.
ok xti was rf 174.9 lf 136.9 now is rf 169.4 lf 142.2 the rear was rr186.9 lr 205.3 now rr 208.7 lr 183.5
xi was rf 124.6 now 130.5 lf 171.4 now 165.9 rear was rr 228.6 now 229.8 lr 162.8 now 171.1.
that did not make any positive changes if anything it got worst
bigtee is offline   Reply With Quote
Old 10-09-2012, 12:47 PM   #213
Default slapmaster6000
you got a pm
Old 10-09-2012, 02:22 PM   #214
Originally Posted by Andrew Knapp View Post
I ran my 13.5 car transverse and my mod car inline!
Why ?
zozo is offline   Reply With Quote
Old 10-09-2012, 02:33 PM   #215
al dente's Avatar
for what it's worth.......
i ran my xti in the inline configuration all week at vegas. after practice, i was seeded 5th for the qualifying runs, with a fast lap of 10.2 and was on pace with the rest of the a main guys. poor driving left me out in the cold after qualifying, and i have no one to blame but myself, landing in the 19th qualifying spot. however, a good run in the main had me miss out on bumping to the "A" by .8 second, and had i not been taken out by a back marker in said main, with 10 laps to go, there would have been one more XTI in the "A" at vegas.
the inline configuration has proven that it it can be fast in all classes, from stock to mod. the beauty of this car is it's ability to be changed into what you want it to be. around the pits, one of the sayings i over heard was, "this car is the "play dough" of 1/12, because you can mold it into any shape you like."
kudos to frank for thinking outside the box, and giving us a truly remarkable car that gives you the option of doing what YOU want to do, instead of settling for a "one size fits all" approach. so for all of you people who think that you know what a car is supposed to be, and feel like, pick one up, and go to town. for some, the inline configuration will not be better, for others it will. remember, it's not the arrow....its the indian.
look for big things from this car in races throughout the year.
Team CRC / Dumper's Speed Shop / Team Scream Racing / Black Art
RC America / FB/FX / Colorado On Road RC Club
5280 Raceway (5280raceway.com) home of the MILE HIGH INDOOR CHAMPS April 20-23, 2017
al dente is offline   Reply With Quote
Old 10-09-2012, 02:51 PM   #216
What can I say about the new CRC XTI other than that it's DIALED!
I took the win in 12th 13.5 in Vegas and finished 6th in mod 12th!
Post setups soon!
Andrew,
what factor(s) motivated your decision to run 13.5 with a transverse battery and to run mod with the battery inline?
vafactor is offline   Reply With Quote
Old 10-09-2012, 03:25 PM   #217
LonnyJ1950's Avatar
But now both heavy wheels are on the same side. You need to start moving the electronics around to try to balance the car. Are you running inline or crossways battery?
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 10-09-2012, 04:21 PM   #218
Trader Rating: 38 (100%+)
I'd guess that the scales heights are different and the heavy wheels are going to be dependent on which scales are where. Weigh the car, turn it 180 and weigh again. Now swap the scales left to right and weight a third time. For the fourth set of values turn the car again. If your scales are like mine you will see that the weights are all over the place. I'm certain that one of my scales is higher than the others and affecting the weights. For left/right balance I am now just using the Hudy balance tools and using the scales only for front/rear weight bias until I can get them to read much more consistently.
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
Old 10-09-2012, 05:23 PM   #219
have it inline xti.
crossways xi
Old 10-09-2012, 05:27 PM   #220
i was thinking of pulling the rear pod and front tires and just try to balance the main chassis. any thoughts on that option?
Old 10-09-2012, 05:32 PM   #221
Default team crc help
can the team give some insight on balancing both xti and xi
Old 10-09-2012, 06:33 PM   #222
LonnyJ1950's Avatar
The XTI should be pretty close as is. All the equipment is lined up along the center axis. If it's way off, you may have a problem with your scales alignment as linkless said. You might try borrowing a car that is in balance from someone and see how it checks on your scales. If they are not level and at the same exact height, they will be off.
Lonny
Old 10-09-2012, 11:44 PM   #223
Slapmaster6000's Avatar
Trader Rating: 15 (100%+)
You guys are trying too hard with high end equipment to achieve balance. I will take some pic's in the morning showing something really simple. You will absolutely drive yourself crazy with scales.
Stay dialed my friends!
www.slapmastertools.com
Team Roche USA
Team Orca orcharc.com
Slapmaster6000 is offline   Reply With Quote
Old 10-10-2012, 12:11 AM   #224
303slowdown's Avatar
Trader Rating: 19 (100%+)
WOW....... Can't tell your a team driver. Lol
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 10-10-2012, 07:49 AM   #225
Andrew Knapp's Avatar
Send a message via AIM to Andrew Knapp Send a message via Yahoo to Andrew Knapp
Originally Posted by zozo View Post
Why ?
Originally Posted by vafactor View Post
Andrew,
I wanted to try the car both ways, see what it did, I figured modified would tell me if the car is good inline, and it did just that! I thought the inline car drove awesome. I rant 13.5 car transverse and what I noticed between the two cars is that my modified car was a little bit more responsive through the corners, now at home I will be changing my 13.5 car to inline as well!
Team CRC www.teamcrc.com--Team Trinity--Revtech--Team Spektrum www.spektrumrc.com--protoform--SXT--Rapid Competition RC Raceway and my dad!
Andrew Knapp is offline   Reply With Quote
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 563 11-20-2016 08:18 AM
