Team CRC Xti 1/12th Scale!!
#2176
As the carpet season comes winding down I have a new setup for people to try!
I've been doing some testing with the ultimate goal of making my car as easy to drive as possible and so far this setup has been the ticket. It's incredibly easy to drive while also maintaining enough aggression to yield fast lap times. I would encourage anyone who wants to try something different to give this one a go. All results are on medium-high grip CRC Black Carpet.
Kevin Van Ert March 2017 Setup:
Front:
168mm width
5* reactive caster blocks
1 shim forward, two back
.45mm springs with .5mm droop (more droop if you need it to be more aggressive)
Losi smart grease on the kingpins
.5* camber (can go up or down .25* depending on what you like to drive)
1mm toe out (this should equate to about 1*)
2mm roll center spacer
3.5mm ride height
CRC stripe tires 40mm glued all the way up to the surface (do not hesitate to run bigger tires but continue to apply enough glue)
Rear:
Battery forward
171mm width
35 weight AE oil in shock
AE Gold spring
CRC .45mm side springs ran inboard (inboard is crucial here, outboard will be more aggressive)
10,000 weight tube lube (Either CRC or Hudy will do great here)
3.5mm ride height
2mm pod droop (less will be smoother)
CRC stripe tires 40.5mm
CRC Lola body cut on all cut lines
If anyone has questions do not hesitate to ask. I think some of you might really like this setup!
Front:
168mm width
3.5mm ride height
Rear:
Battery forward
171mm width
AE Gold spring
3.5mm ride height
#2177
The 0.45mm front end springs are very soft, for some reason I have never gotten my car to be efficient through corners with such a soft setup, 0.50 or 0.55 was more predictable and held better lines for me.
Aside from that, I will have to try the losi smart grease. I typically run some light oil on the front kingpins, but maybe grease is the way to go.
#2178
#2179
Are you running 17.5 or 13.5? In the faster classes the 45 springs tend to compress a bit too fast for my liking some of the time. I am experimenting with some slightly longer springs with decent results so far. In 13.5 I ran the same setup with slightly stiffer (.475 Xenon) front springs. Had similar results with CRC .50s and would have liked to do more testing.
I had tried running a non-reactive front end setup with the soft springs as I had seen others use successfully, and when I had it running right it worked decently, but it wasn't to my liking. The car felt like it was struggling to control its weight and right or straighten itself coming out of corners, felt heavy and plodding as opposed to the light feel of the harder spring set with a more reactive front end.
#2181
#2182
#2183
#2185
Hey guys, hope this is the correct place to post this. I am looking to get back into 1/12 onroad as a track is near me and I didn't know this till now! I have found a killer deal on a crc carpet knife xti but am unsure if this is a good car to get back in the game with. I last raced a rc12l3... any help is appreciated! Thanks
#2186
The good thing about CRC is that they offer many different combinations of main chassis, pod plate, and front end. Xti can mean quite a few things these days. 1/12 hasn't changed in that any half decent car can win a race with a good tune and driver.
#2187
If it's a good deal, then sure. Is it the older inline car or is it a newer transverse mount Altered Ego or the like?
Though now I am debating after your reply in my other thread
#2188
I have a mcfactory aluminum chassis for the crc
#2189
I've bought the updated pod and installed it in my car. I can't seem to find a good location for the motor. The wires are on top and the sensor is on the bottom. Am I missing something or do I need a motor with the sensor board up for this. Otherwise there isn't any clearance for the sensor cable
#2190
