Team CRC Xti 1/12th Scale!!
#1936
I just got my XTI WC. I have a few questions maybe you guys can help me out.
1. Is there any tips on assembling it? Or things I need to watch out for?
2. Which optional parts is a must get?
3. If you guys have been to Tqracing in Chino, what's a good set up there?
4. I will start with blinky 17.5t with Reedy M3 1s. What would be the roll out?
#1937
Must have the front brass pivot balls(use a little of the losi smart diff grease for lube on the king pins)
When assembled, Make sure the front king pin falls under its own weight and there is no bind on the front end at all.
Put on tweak station often, make sure front droop is around .25mm. No more. This will change as the springs wear.
Make sure pod is always level when ready to race.
And hold on, this car is freakin fast!!
#1939
arent the XTI and the WC essentially the same aside from the main chassis and c-plate?
#1940
Thank you for the tips. So only brass pivot balls are needed huh? I like this car already
#1943
I also recommend the aluminum rear standoffs for the tweak plate, but they are far from a required purchase. They do help a little bit with reducing flex if you are going to run the battery forward and I believe they cost like $2-3.
Other then that you are good to go!
#1944
Will do. Thanks again. Since I'll be building the kit this weekend there will probably be more questions coming.
#1947
Only stuff i added to mine was aluminum crossbrace standoffs, shock extender which makes droop adjustment easy.
Brass balls i have in mod car but i never bothered for the stock car.
Im also not running the brace with purple stripe tires. Basically the car is kit stock.
If grip was way higher id get the upper arm spacers and the crossbrace but i usually take away camber rather than put it on. Crc car doesnt seem to need anything to be fast in stock.
#1950
I'll be getting brass pivot ball, ride height shims and aluminum standoff for now. Btw what's the part number for the standoff? Also, is Losi smart diff lube what everyone using for the king pins? Or does it depend on the track condition?
