Like Tree11Likes
Old 10-04-2012, 09:21 AM   #181
Default crc xti build using the new GQ tires
using the new GQ tires on my xti the off set is different then the normal 1/12 scale tires anyone know what i should be shimming them out too? or better what should the track width front and rear? thanks for any info
bigtee is offline   Reply With Quote
Old 10-04-2012, 09:24 AM   #182
johnnywhopper's Avatar
Originally Posted by Csaari77 View Post
Thanks. I messed with it last night and got it set. I had the side links too tight, which was binding the movement. Are there any tricks to setting them, or is it just trial and error?
you shouldn't even have to hardly turn the clamp screws in on the links at all (especially when their new and not worn yet). you just run them in until they just touch the plastic, no real clamping force needed. The screw keeps the link end from spreading in the event of a crash so you don't pop a link.
after you have alot of time on the car and the links start to wear slightly, then you can mess with the clamp screws to get rid of any play, but it's trial and error.
john
Team CRC, Spektrum, Hobbywing, JDJ Vinyl Graphics, Moby Graphix, Black Art, Power Push
johnnywhopper is offline   Reply With Quote
Old 10-04-2012, 09:26 AM   #183
max track width is 172mm. the front is always narrower than the rear (the rear would be maxed out to 172mm), but i don't have a meausrement handy. i just bolt on crc front rims with 1 shim on the inside and go.
Old 10-04-2012, 09:41 AM   #184
the new GQ tire offset is different on the front using the three shims on each side i still have about a 4mm gap between the rim and the nut . so i guess i should shim out the rear to max and shim out the front to about 170mm to 171mm
Old 10-04-2012, 10:32 AM   #185
Which front cross braces fits the stock Xti suspension? Long or short?
malkiy is offline   Reply With Quote
Old 10-05-2012, 05:40 AM   #186
dougo96's Avatar
Long
Team CRC-TS Paint-Bauer's Speed Shop-HobbyWing North America
dougo96 is offline   Reply With Quote
Old 10-05-2012, 09:04 PM   #187
jarrodh's Avatar
get the brace for the short arm suspension..= long brace
got mine put together today..still thinking about painting the edges of the chassis plates red..
ANYONE ELSE HAVE TROUBLE WITH THE SERVO NOT FITTING AND HAVING TO FILLE DOWN THE CF ON THE FRONT SUSP. MOUNTS THAT WRAPS AROUND? (lower left corner) took me about an hours to get it to fit..
and i think mine was missing the little rubber oring for inside the shock, instructions say its a travel limiter..
www.irocc.ca
jarrodh is offline   Reply With Quote
Old 10-06-2012, 04:07 AM   #188
Trader Rating: 59 (100%+)
What's everyone using for front ride height adjustment? The aluminum spacers under the 4-40 screws are a PITA. Are they making new plastic shims for this, or you guys trimming up the plastic shims to fit?
MC112b is offline   Reply With Quote
Old 10-06-2012, 04:38 AM   #189
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
Easily fits the JR 3650, Spektrum 5040 and Sanwa 94761 and SRG-HR (recommended) mini servos.
From the website.
dontfeelcold is offline   Reply With Quote
Old 10-06-2012, 03:48 PM   #190
Anyone shimming the front for ride height?
Old 10-06-2012, 10:09 PM   #191
Trader Rating: 38 (100%+)
There will be shims available for the front end soon. Slotted inserts that go in place of the current aluminum spacers and inserts for between the chassis plates and the suspension blocks. This is much easier to do than the aluminum spacers.
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
Old 10-06-2012, 11:58 PM   #192
nashrcracer's Avatar
R/C Tech Charter Subscriber
http://www.liverc.com/view_result_fi...8C_Main%29.xml
"C" main 13.5 12th
Position Driver Name Car # Laps Race Time Fast Lap
1 Wynn, Brian 2 48 8:03.544 9.627
2 Bodine, Brian 5 48 8:08.123 9.766
3 Wiita, John 3 48 8:09.531 9.786
4 Ashby, Steve 8 47 8:02.992 9.861
5 Dirla, Robert 7 47 8:07.193 9.581
6 Lundberg, James 1 47 8:08.623 9.787
7 Nelson, Sam 4 45 8:05.497 9.724
8 Flipse, Jody 6 42 8:00.491 10.055
my XTI was stupid fast and handled great. just wish I would of found that speed in the quals.
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 10-07-2012, 03:40 AM   #193
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
"C" main 13.5 12th
=me at carpet nats.
#Toolittletoolate.
Old 10-07-2012, 06:27 AM   #194
That sounds very cool. I was at the track Friday and was like "wuuuuut?" I thought I was blanking out. Hopefully they come out pretty quick.
Old 10-07-2012, 06:40 AM   #195
Just a quick update from the IIC...
Andrew Knapp took his Xti to an A-main win in the 13.5 Superstock class. Andrew used CRC Magenta front and rear tires in the main and set fast lap time in the process. Joining Andrew were CRC drivers Hupo Honigl and John Tortorice.
In the 17.5 class, it was a CRC sweep with Xti inline cars taking 2nd and 3rd in the hands of Mark Smyka and Kenny Lambert. Birthday boy John Tortorice had a lot to celebrate taking the TQ and win with his CRC Gen-Xi. John also used the CRC 1s lipo and CRC tires to win and set fast lap. Joining the podium trio were CRC drivers Carrissa Smyka and Robert Dirla making it 5 out of 10 drivers with CRC rides. The 3 podium drivers used CRC 1s lipos.
In the modified 1:12th class, Andrew Knapp put on quite a show with his inline Xti charging to the front in a fury of flying foam. An unfortunate and untimely "board" meeting sent him back a few positions. In his charge back, Andrew managed to hot-lap the field setting fast lap time in the A-main with his inline Xti. Knapp used Magenta front and pink rear CRC 1:12th tires.
In the World GT 13.5 class, another CRC podium sweep with TQ man Dave Ehrlich taking the win with his CRC Gen-X 10 LE and CRC lipos. Joining Dave on the podium, Denver driver Mario Ficco (2nd) and Brian Bohlman (3rd) in their Gen-X 10 LE rides.
It was another great event in Vegas and another great result for Team CRC!
Team CRC is offline   Reply With Quote
12th Scale Racing is Alive and Well in So Cal RedBullFiXX California Racing 564 06-09-2017 04:00 PM
Currently Active Users Viewing This Thread: 6 (2 members and 4 guests)
LonnyJ1950, Ted Su(TW)
