Team CRC Xti 1/12th Scale!!
#1786
Was that three heats and a main? How did you sauce?
#1787
I tested the extended-mount pod top plate and I think it actually allowed my car to carry a little more corner speed. It might have caused the car to be a little more front-biased, but it seemed minor and I think the car controlled the turn-in forces on the grippy carpet surface better than with the stock top plate.
#1788
#1789
Hi Crc'ers!
I have a little problem with my xti-wc... the center shock pops off if hitting the barriers.... The car is pretty new, still the plastic cup has some play on the ball...
I have seen the Team Prime shock, and my question is: is it possible to fit in my xti? I mean, the alloy balls are the same or do I have to switch to others? Do the crc springs fit the shock?
#1790
That's been my experience as well. I run extended plates on my 12th scale car and WGT car. I found that it allows you to run a less aggressive front-end set-up, but still carry excellent cornerspeed. A very useful trait when battling super high traction situations that might lead to traction rolling.
#1791
Hi Crc'ers!
#1792
Yeah I've never had that problem ever. I've broken shafts and plates in nasty hits but the ball cups were still on. Try some new balls and cups.
#1793
Hi Crc'ers!
#1794
I've seen some pic's where the servo is in a rear position and seen it in the backward position. Looks like directions say to install it backwards. Is it that so you get the weight bias correct or can I install the servo with splines*facing forward with no ill effects?
#1796
on the cap end of the shock, I prefer the plastic piece that has a hole in it rather than the one that looks more like an enclosed ballcup. I have the cap end of my shock towards the front of the car and I'm using a coated ballstud that installs with an allen wrench.....which can be accessed via the hole in the plastic shock cap. That combo works great and the plastic cap never gets loose on the ballstud because I don't ever need to unsnap it. Rather I just unscrew the ballstud on the rare occasions when I want to re-oil or service the shock. For the shaft end, CRC now offers a little aluminum adapter that threads onto the shock shaft and increases its thread size to 4-40. That newish adapter allows you to use most any type of plastic ballcup of your choosing. I use a dubro ball end on mine with a longish 4-40 button head screw that remains in the upper pod plate (in lieu of a ballstud there) so that it's super easy to remove one 4-40 nut to accommodate quick and easy battery changes. This combo does increase the overall length of the shock, so the shock mount needs to move foward one hole in the main chassis, but I consider that too as a benefit.
#1797
Here's a problem I've been having consistently, lately: What body fits over the front end when you run the 0 degree reactive caster blocks and the roll center adjusters? It stands the front arms way up. The only one I can find that fits is the Strakka, or maybe the Mohawk.
#1798
#1800
What traction level are you running on?
