Roll out for Kontronik Twist 42?
I am trying to find a starting rollout for a Kontronik Twist 42 in a 1/10th touring car. I realise this won't be the fastest motor for 6 cell applications but it is actually for a 3 cell li-po project and I was advised by the relevant manufacturers that this was about the best I could get that wouldn't blow up at this voltage.
I am just looking for a gearing starting point for some data collection. I want to start with 6 cell subC and work my way up. I have heard that around 35mm on the Novak system SS5800 is good on an open track and this would give a theoretical top speed of 86km/hr which sounds about right for a mod.
So if I gear the Kontronik to the same speed given that it is 4200Kv and the Novak is 5800Kv I end up with a roll out of around 48mm.
This sounds pretty high to me though but the math seems correct. If anyone has first hand experience using this motor I would appreciate any roll out suggestions you may have.
anyone using this motor?
