KO Propo Mars R
KO Propo Mars R
Hi. I got my Mars R yesterday, and I have a few questions that need answering because of the strange update sheet for the "R" (major use of Engrish.) It's fairly new, I don't think anyone will be able to answer these.
Does my 27mhz Mars R require the special KR-301 receiver or can it use any 27mhz receiver?
Can the R use the original Mars' 75mhz module?
TY
TY
hehe, I think i could help...I got one too.
I think you need the KR301F receiver to achieve the Hi speed response from the radio...but if you dont mind the hi speed response system, you could use your 297z receiver.
PPL also told me there is not that much different for the R from the Mars EX-1
I'm not sure about the 75mhz module.
They are talking about the different version of the module from previous EX-1. I think you need to have the module from Mars R and receiver of 301 in order to work properly. Or else, you have to change it back to the 297 receiver or LRP Phaser receiver.
Registered User
Re: KO Propo Mars R
TY
TY
They are pretty good about answering questions.
The Mars R is more like the EX-1 2000R radio only it has the Hi Speed Response, is not Limited Edition and has not got the drop down wheel.
But it still retains the 22 models memory from it's LE brother.
For those who owned previous Mars and Mars R, can you really feel the "hi-speed" response?
I saw and tried my self both radios at the recent Shizuoka hobby show. They installed both of them using the same servo next to each other. I could clearly notice the difference between the two.
This KO type R radio along with the M8 S (only for japanese market) are one step a head of any other brand on the market today. The Futaba 3PK has a bold new look, but does not have the 'response speed' as fast as the KO or M8 S.
The Extension Wheel (drop down ??) for Mars and Mars type R is not the same (have diferent part numbers)
I emailed them here is their replies if you need to know:
Thank you very much for your inquiry.
If you would like to have 75MHz, you have to have a 75mhz module,
receiver,
and a set of crystal. We do not have 75module, and receiver yet, but
we
will have soon.
Because, we just released marsR 27MHz a couples of weeks ago, and 75mhz
will
be here in a few weeks. 75Mhz delays due to FCC approval.
We will have them regular stock here on the end of August.
Best Regards,
T.Nakagawa
KO PROPO USA, INC.
Regarding a new receiver 301, curent EX-1 Mars radio cannot use it.
However, new Mars R radio is able to use old 297F receiver.
Module for Mars, and marsR is the same. The color of the case is a
little
bit different. You cannot tell the different.
Best Regards,
T.Nakagawa
KO PROPO USA, INC.
receiver,
we
will have soon.
will
Best Regards,
T.Nakagawa
KO PROPO USA, INC.
little
Best Regards,
T.Nakagawa
KO PROPO USA, INC.
I have a problem with my Mars-R...its works fine with the new
KR301 receiver...but it doesnt work with the old KR297
strangely...another friend of mine who purchase a new set
of Mars-R are also having the same problem...and he had
4 KR297 which doesnt work with the new transmitter!!!!
PS.. the weird thing is...my new Mars-R works fine with
an old tekin receiver!!!
One of my customers has been able to use a Novak rx with it, but not the 297.
Importer info
Only in German but this info does state that the R will ONLY work with the new receiver and no onger with the "old" one!
KR301F 3 Kanal Micro Empfänger
Die neue KoPropo EX-1 Mars R wurde nun endlich ausgeliefert.
Der neue im coolen Kohlefaserlook mitgelieferte Empfänger KR301 ist ab sofort auch separat erhältlich.
Wichtige Info:
Die neue EX-1 Mars R überträgt die Lenk- und Gas-position mit der doppelten Geschwindigkeit
dadurch kann eine deutlich schnellere Reaktionszeit des Fahrzeuges erzielt werden.
Der Nachteil dieser neuen Technologie ist, das der alte Micro Empfänger KR297FZ
diese höheren Datenraten nicht zulässt und er dadurch mit der neuen EX-1 Mars R
nicht verwendet werden kann.
Wichtige Info:
Some additonal info: the old receiver does not work with the higher info rate the R is using.
i tried 4 - kr297 (40mhz) receiver with the mars-r 40 mhz and mars 40 mhz modules in the mars-r, they doens't function properly
i used my friend mars 2000 29mhz modules with the KR297 (29mhz) receiver it function properly except the speed
( does any one knows the mars, mars-r and mars-2000 lim. have the same modules??? they have the same model no.)
i tried my ex-10 with the KR301-f, it function properly except the speed.
could any one explained pls and TQ.
i think i have to plan to replace all my KR297 receiver
