Like Tree5Likes
Old 03-27-2017, 04:58 AM   #646
I just finished building my GT-e 3.0. I see many of you have changed the battery tray to the carbon fiber battery plates. Where do you buy them? What other after market hop ups are there?
SoLost is offline   Reply With Quote
Old 03-27-2017, 08:01 AM   #647
Rockin G's Avatar
http://serpent.com/product/600681
I'm sure there are others out there, but the radio tray is a worthwhile upgrade as well. As far as other upgrades, heavy front and center diff fluids and RC Shox Flo Control pistons is all I have on mine that's not stock.
Rockin G is offline   Reply With Quote
Old 03-28-2017, 07:33 AM   #648
Cool thanks!
btw, any of you use 139mm x 47mm x 37mm size 3S batteries? Will require some mod as it is taller then the regular ones. Wonder if it is worth it.
Old 03-28-2017, 08:15 AM   #649
Rockin G's Avatar
Cool thanks!
What KV motor do you run? And what is your goal? Racing or all out speed runs?
Old 03-28-2017, 12:55 PM   #650
C@T's Avatar
1900kV is the best choice. Good cooling required!
Have a look at eGT8 and eGT8-Racing on Facbook.
YouŽll find a lot of usefull Information.
C@T is offline   Reply With Quote
Old 03-30-2017, 07:30 AM   #651
D.a.v.e's Avatar
Cool thanks!
I ran the taller 3 Cell packs in my car for 2yrs. Found some body post extenders to make it work. Worked great. I think I ran a 1700KV motor with the 6 cell set up.
D.a.v.e is offline   Reply With Quote
Old 04-20-2017, 03:04 PM   #652
I have a gt8 that I got a bunch of parts for like 0 degree hub carriers and the plates to raise diffs the alloy server arm and hard saver spring any of it usable in the gte or is it not compantibe?
teo1213 is offline   Reply With Quote
Old 04-21-2017, 07:57 AM   #653
Hello from France,
you can use all the parts from the nitro (excepts some transmission parts!!!).
The rear raising plate will hit the bottom of the plastic battery box.
Just have to shave a little materiel with a hobby knife.
Au revoir,
Romuald
romuald31 is offline   Reply With Quote
Old 04-21-2017, 08:02 AM   #654
Cool thanks!
Hello from France,
I run with 30mm height 3S batteries and, I use this:
Au revoir,
Romuald
Old 04-21-2017, 08:28 AM   #655
Wow!! Great looking body, super paint job, Romuald.
nitrohead5300 is offline   Reply With Quote
Old 04-22-2017, 10:00 AM   #656
Is the cobra 811 be 2.1 chassis same as cobra gt-e chassis? Part numbers don't look to be but visual is same
SER600016
Ser600445
Old 04-22-2017, 10:27 AM   #657
Oh cancel that both those for the buggy my guess is it is different sorry
Old 04-23-2017, 01:30 AM   #658
Hello from France,
my cobra Gte 3.0 is "heavy", around 4,1kg !!!
So, I started a "WeightWatcher" diet...
Around 40g with milling the chassis!!!
Old 04-25-2017, 12:45 AM   #659
Now, going for 50g shaving!!!
Machining of a rigid axle instead of center differential!!!
Old 04-25-2017, 06:03 AM   #660
Now, how to gain 110g???
Prototype in 3D impression for testing
Some machining...
Another test
Machining of the 3mm carbon sheet.
Nice!!!
110g less!!! And lowering the LiPo by 6mm!!
You can buy this carbon kit for 60€ in France!!!
G-rem likes this.
Serpent Cobra GT John. Nitro On-Road 2510 10-21-2017 06:59 PM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
What's the gt car to buy???? 1966ss Nitro On-Road 26 06-04-2012 10:34 AM
