Like Tree5Likes
Old 05-06-2016, 11:11 PM   #616
Considering this car over the other offerings.
Can the cobra accept a longer chassis to use the 360mm bodies?
Sabin is offline   Reply With Quote
Old 05-15-2016, 05:45 PM   #617
Rockin G's Avatar
Any fluid set up advice for the 3.0 yet? Stock sheet shows 300/300/40 on the diffs...any real world testing on this yet? Medium traction track local, for the most part.
Rockin G is offline   Reply With Quote
Old 06-16-2016, 12:14 AM   #618
JPucko's Avatar
Hey, I currently run serpent off road buggies at my local carpet indoor track but it may be shutting down so with the only other track near me being an on road I'm looking at my options. The track runs mainly 1/8 gas and electric as far as I know. What is the cobra rtr gt-e serpent like for a starting point? http://www.serpent.com/product/600045
JPucko is offline   Reply With Quote
Old 06-16-2016, 01:10 AM   #619
dan_vector's Avatar
Trader Rating: 27 (100%+)
It is a very good option actually the included electronics are of high quality and the kit itself is fully upgradable to the race level kit. Many parts from your existing cobra buggies will also carry over.
Ideally I'd go for the 3.0 race kit (as you get all of the new suspension components included) hobbywing electronics if I was not on a tight budget and if I already had good radio gear and servo.
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 06-16-2016, 02:12 AM   #620
Yes the truggy chassis work for the 360mm body however it handles like a shoe box with wheels I converted it to the long chassis and only did 1 race meet and then went back to the shorter chassis
pieter is offline   Reply With Quote
Old 07-13-2016, 07:57 AM   #621
Hello from France,
here's my Serpent Cobra GTe 2.0 upgraded with the 3.0 kit and some options...
http://www.automodelisme.com/index.p....msg571640#new
romuald31 is offline   Reply With Quote
Old 07-18-2016, 06:41 AM   #622
Can anybody tell me how much room there is for the motor? What would be the longest can that would fit?
MallenP30 is offline   Reply With Quote
Old 07-18-2016, 07:45 AM   #623
serpent.com/product/600048
Motor mount
Machined 7075 T6 aluminium motor-mount with one-screw fixation and easy slider system. Flex-free and very strong motormount. The space for the motor allows a maximum motor-length of 68mm, which covers most widely used motors.
Serpent MRC is offline   Reply With Quote
Old 07-18-2016, 08:18 AM   #624
Motor mount
Thanks for the info! It looked like it would be a good speed run car but if it can only take a 68mm long motor it would be very limited! I'm currently using the Mgt7 running an 83mm motor with about an inch to spare
Old 07-18-2016, 08:21 AM   #625
I have 2 motors.
Team Orion VST2 Pro 690 and Tenshock 812.
Both are around 69mm an, there's a little room more.
So, I think 70mm is the max.
Like Serpent MRC told, most of motor brands have an "under 70mm" model.
Old 07-18-2016, 12:21 PM   #626
C@T's Avatar
With a little modification you can use a motor with up to 74mm length.
Have a look at:
https://www.facebook.com/photo.php?f...4512639&type=3
C@T is offline   Reply With Quote
Old 07-19-2016, 12:48 AM   #627
That's fine. It will be used for drag racing anyways. Thanks for the headsup. Do you have a part number by chance? gotta be sure I get the right one.
Old 07-25-2016, 07:46 AM   #628
C@T's Avatar
Get an impression of whats possible with the Cobra GTe V3.0 and the right setup.
https://www.facebook.com/egtacht/vid...0480316737618/
Old 07-25-2016, 07:39 PM   #629
nexxus's Avatar
Trader Rating: 302 (100%+)
I ran the alloy 0 caster blocks on the 3.0 over the weekend, gives you a lot of off power turn in without hampering you with on power oversteer (I use a Thunder Power 2400kv as they are slightly smaller than most 1/8 motors so less torque) but they hammer the front tyres so it's a trade off.
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 07-31-2016, 05:47 PM   #630
TPR 1's Avatar
Trader Rating: 26 (100%+)
Do you guys think 6000mah Thunder power 70c velocity series lipos will have enough capacity to make a 6 min race + 2 lap practise using a 2400kv motor?
lap times are about 18.5 - 19 sec per lap
i know driving smooth and gearing will play into the equation.
-Adelaide RC -
-Game On
TPR 1 is offline   Reply With Quote
Serpent Cobra GT John. Nitro On-Road 2536 11-16-2017 02:45 PM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 04:11 AM
What's the gt car to buy???? 1966ss Nitro On-Road 26 06-04-2012 11:34 AM
