Like Tree4Likes
Old 06-02-2015, 03:24 PM   #586
wwddww34's Avatar
Trader Rating: 9 (91%+)
Originally Posted by scooby61 View Post
Large sweeping track or med tight? I'll post my base setup for you but it's a med tight parking lot track
I am racing in a med tight parking lot.
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is offline   Reply With Quote
Old 06-02-2015, 03:58 PM   #587
scooby61's Avatar
OK
I'm running with black springs all around, 1000wt shock oil stock pistons.
No rear sway bar ( I would try with and without at your track)
1.8 deg camber front, 1 deg rear
0 deg c hubs and 0 deg knuckles
Ride height is 7-8 mm front and around 9to 10 in rear
My car is pretty light I have the lightened steering/esc. Mount ti turnbuckles and have cut away most of the unnecessary plastic.
I run grp s5 and s7 but they are spec. At my track.
My diffs. Are 300k frt. 200k ctr. And 40k rear
The main problem with the handling on this car in my opinion is the front kick up. It results in a lot of caster in the front the c hubs and knuckles along with weight reduction were the best improvements.
Losi 5T (awesome)
Serpent cobra GTe, Serpent s411 eryx 2.0,
AE tc6.1, Losi 8Te 2.0, Losi 22b, AE t4,
Slash 4x4, Axial Deadbolt
scooby61 is offline   Reply With Quote
Old 06-05-2015, 11:38 AM   #588
C@T
C@T's Avatar
For those living in Europe take a look at:
https://www.facebook.com/egtacht
https://www.facebook.com/groups/866766373395288/
C@T is offline   Reply With Quote
Old 06-24-2015, 08:32 PM   #589
Evo 13's Avatar
If you already have the cobra gte, and you want to upgrade to the 2.0 rear, do you need the full kit part #600642 or the partial kit #600643?
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Mugen MBX7T ECO (Truggy)
SMC, Max Amps, LRP, Poseidon Motors, Cordova Research Motors, Xceed.
Evo 13 is offline   Reply With Quote
Old 06-25-2015, 05:44 AM   #590
scooby61's Avatar
You only need the following parts
600102 DriveShaft 98mm
600630 Upright Truggy L+R V2
600633 Wishbone Rear L+R 811 2.0
Losi 5T (awesome)
Old 06-25-2015, 12:53 PM   #591
Evo 13's Avatar
Thanks, Are you running these upgrades? If so hows the performance?
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Old 06-25-2015, 05:05 PM   #592
scooby61's Avatar
I have almost every available upgrade on mine. But the 2.0 rear and the 0 degree c hubs and steering knuckles.ade the most difference.
Too much caster and chassis kick up in the front seems to be the biggest issue with this chassis. Weight reduction seems to make a large difference.
Losi 5T (awesome)
Old 06-26-2015, 05:50 AM   #593
D.a.v.e's Avatar
Had a couple of guys do this to their nitro versions last year and they liked the stock version better.
D.a.v.e is offline   Reply With Quote
Old 06-26-2015, 12:38 PM   #594
Evo 13's Avatar
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Old 07-04-2015, 09:06 AM   #595
Evo 13's Avatar
As part of a motor mod project I'm doing on my cobra get, I installed the aluminum servo savor and the aluminum servo lever. But the plastic piece in between (illustrated in pic) I could not find in aluminum, and as such, there is excessive play at the joint where the servo lever and plastic piece joins together. (where the hex driver is pointing at in pic). Any ideas on how to fix this?
PS. Ignore the position of servo savor as I had to turn it around in order to drop a 78mm truggy motor in.
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Old 07-04-2015, 11:54 AM   #596
Evo 13's Avatar
Is anybody else using the aluminum servo lever, and if so how are you eliminating the excessive play?
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Old 07-04-2015, 12:02 PM   #597
C@T
C@T's Avatar
This might be a solution:
http://www.ebay.com/itm/NEW-RC4WD-M3...-/291496367335
Old 07-04-2015, 06:18 PM   #598
Evo 13's Avatar
Originally Posted by C@T View Post
Thanks, but I fixed it. There was an extra ballhead in one of the parts bag that fixed the excess play. Steering is perfect now.
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Old 11-13-2015, 07:16 AM   #599
blarks's Avatar
Trader Rating: 29 (100%+)
Thread seems a little inactive, you guys still out there . Looking at getting a gt car and was wondering what peoples thoughts are on this car, is it becoming a little outdated? I am surprised to see in amain this kit is actually more than the new mgt7 eco. I have seen the serpent for around $100 less than the mugen here in Australia but I am thinking for the extra money is it better to have a latest model car as opposed to a car that is basically 3 or so years old? How much longer will parts support be available for the cobra? I do like this car and money is a little tight but for longevity maybe the mugen might be a better choice, opinions.
blarks is offline   Reply With Quote
Old 11-13-2015, 07:24 AM   #600
Outdated is a scam. This is perfect with no need to change much of anything. The other companies are just finally catching up to this catagory. As for parts support Serpent has always been great. In the hands of a competent driver with a good setup its hard to beat.
Bhodi11 is offline   Reply With Quote
Serpent Cobra GT John. Nitro On-Road 2351 08-21-2017 03:15 AM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
What's the gt car to buy???? 1966ss Nitro On-Road 26 06-04-2012 10:34 AM
