Serpent Cobra GT-E >
Serpent Cobra GT-E
Like Tree19Likes
Serpent Cobra GT-E
Old 09-30-2014, 10:41 PM
  #511
pullstarter's Avatar
Trader Rating: 14 (100%+)
Originally Posted by RepEvox
Yeah there's a few other parts if you look under the GTE parts list. You might want to get some really thick diff fluid or possibly just get a direct drive spur instead of the center diff.
Cool, cheers
pullstarter is offline
Old 10-07-2014, 07:43 PM
  #512
Evo 13's Avatar
Is there an electric conversion kit out for the Cobra Gt nitro car? IF so whats the part #? I've been bitten by the electric bug and want to convert my Cobra GT nitro to electric. Thanks in advance!
Evo 13 is offline
Old 10-08-2014, 05:39 AM
  #513
D.a.v.e's Avatar
No conversion kit but I would assume this kit going from gas buggy to electric truggy would give you most of the part numbers that would be needed: http://www.amain.com/Serpent-Cobra-8...on-Kit/p261362
D.a.v.e is offline
Old 11-16-2014, 10:16 AM
  #514
Hi guys, I'm looking at getting me a GT8E kit, I won't buy the RTR.....RTR always sucks....but anyway.....I just want to know what you guys think I Wi ll need for the cars initial setup, is there any upgrades I need? could someone kindly give me a list of recommended parts/ electronics and so on....I would really appreciate it. I just sold my Kyosho GT1 and GT2 rs. I'm hooked on 1/8 Gt....thought of the 977e but just won't work on our track....
Thanks in advance guys
Reaper1ct is offline
Old 11-16-2014, 10:58 AM
  #515
scooby61's Avatar
Need 0 degree c hubs and knuckles, metal servo arm (has to be the serpent one) probably some springs to tune for your track. Be careful of your motor selection can length cannot exceed 96mm
scooby61 is offline
Old 11-16-2014, 02:59 PM
  #516
C@T
C@T's Avatar
Is that 96 mm measurement from the Sertpent Cobra or the GTE8e ?
C@T is offline
Old 11-16-2014, 05:21 PM
  #517
scooby61's Avatar
Oops should be 69 mm for the gte ex: only the 2650 and the 2050 tekin motors fit
I run the 2650 on 4s with 17t pinion
scooby61 is offline
Old 11-17-2014, 12:18 AM
  #518
Thanks guys...important info....i actually have a 2050kv sitting at home but a lhs has a losi L8ight on such a good special that im trying to decide between the two.....doing alot of head scratching here
Pros and cons?
Old 11-17-2014, 12:20 AM
  #519
R/C Tech Elite Member
nexxus's Avatar
Trader Rating: 315 (100%+)
The Team Orion 1/8 Motor also fits, but barely, it will only work on the kit chassis which is milled (the RTR isn't) you need 2mm washers between the motor mount and motor and then you have about 1/2 a mm clearance between the end of the motor and the steering assembly.
I'm running a 2100kv on 4s, 20t pinion I think
nexxus is offline
Old 11-17-2014, 12:40 AM
  #520
thanks...would only buy a kit anyway.....so then the big hobbywing motors wont work? like the 4274....is it length or diameter that is the issue
Old 11-17-2014, 03:22 AM
  #521
scooby61's Avatar
Length is the main issue
scooby61 is offline
Old 11-17-2014, 05:02 AM
  #522
ok so i would need:
the kit,
a motor thats not longer than 69mm,
0* knuckles and C hubs
Serpent servo horn...
Besides Body, Wheels and tyres.....
What else should i factor in?
i have a 2050kv tekin...what gearing do i need? i believe the kit comes with a 50t spur...do i need a 48t? what else would i need to look out for?
Old 11-17-2014, 09:25 PM
  #523
I just bought one of those cobra gte and im anxious to get, i hope before the weekend for the race.
if some one can help me with the timming and gearing? Just to have a start.
Viper vtx2 1900 motor short track
manny531 is offline
Old 11-17-2014, 11:04 PM
  #524
nexxus's Avatar
Start with a 19t Pinion and monitor temps, My motor usually comes off at 75c after a 5 minute race without a heatsink or fan.
nexxus is offline
Old 11-18-2014, 12:29 AM
  #525
ok so i would need:
the kit,
Some help?
