Like Tree4Likes
Old 07-27-2014, 10:52 PM   #466
nexxus's Avatar
Trader Rating: 300 (100%+)
I'm in two minds whether or not to buy a GT-e kit build that and gut the rtr to convert a nitro s811 2.0 to electric for a basher.
A800 / A800X Awesomatix
Fry crack corn and I don't care,
Leela crack corn, I still don't care,
Bender crack corn and he is great!
Take that you stupid corn!
nexxus is offline   Reply With Quote
Old 07-28-2014, 03:49 AM   #467
machgo5go's Avatar
Originally Posted by scooby61 View Post
I had similar issues with turn in and was getting frustrated then I copied most of Andy Liu s setup for the nitro and bam car dialed in pretty sweet. I do have the 10 degree c hubs and 0 degree steering knuckles and I used 1000 cat shock oil white springs on the front and red on the rear. Try that might be what your looking for.
Well I don't want to spend another $$ on new 0 degrees knuckle on this money pit & find out steering still pushes not for my driving style in comparing to my Inferno GT2VE.
So I decided to give up in letting it go into the market minus ESC & Motor.
Inferno GT2 VE Sweep PL1 Hobbywing XERUN w/2200KV - 4S. VE Audi R8 LMS Tekin RX8 Gen2 w/2650KV - 4S. AE TC6.1 SP Audi TC Tekin RS Gen2 w/8.5. TT-01E Audi R8 Hobby Wing 21.5T. TT-02 NSX-GT Hobby Wing 13.5T. DF-01 Porsche Cayenne 23T B.
MAJ'S HOBBY SHOP " 214 State st Suite 209 Hackensack, NJ 07601:201-820-1347
Racing: FRIDAY Mini Z Indoor/SATURDAY 1/8 & 1/10 VE Outdoor.
machgo5go is offline   Reply With Quote
Old 07-30-2014, 07:05 AM   #468
nexxus's Avatar
I caved and got a kit, now not sure on motors, I have an Orion VST2 1/8 2200kv and ESC's I have an LRP IX8 and a Hobbywing Xerun 150 and I need to kit out the GT-e and the 811 2.0e so will need another motor of some description. Do I slap the 2200 in the buggy and find a higher kv motor for the GT or put the 2200 in the GT and find a 1900ish for the Buggy? What ESC would be best suited to what car?
The track I race on is here
Old 07-30-2014, 07:33 AM   #469
scooby61's Avatar
I run a rx8 2650 combo it's very smooth and fast. If you run on a small tight track I would stick with 2000-2200 kv my 2650 is over kill on my track and I have to gear low to get into the meat of the power band.
Losi 5T (awesome)
Serpent cobra GTe, Serpent s411 eryx 2.0,
AE tc6.1, Losi 8Te 2.0, Losi 22b, AE t4,
Slash 4x4, Axial Deadbolt
scooby61 is offline   Reply With Quote
Old 07-30-2014, 07:56 PM   #470
nexxus's Avatar
What sort of gearing are you on?
Old 07-30-2014, 08:44 PM   #471
scooby61's Avatar
Stock spur and 15t pinion I was running a 17t but my track was to small and made it slow on the infield
Losi 5T (awesome)
Old 07-30-2014, 08:46 PM   #472
scooby61's Avatar
My motor temp with a pavement temp around 108 deg. Is about 140 after a 8 min main
Losi 5T (awesome)
Old 07-30-2014, 09:30 PM   #473
nexxus's Avatar
That sounds like it'd be on the money for me, our track is quite large 60m Front Straight and 40m back straight, 250m length total, 13.5 Blinky TC is lapping around the 18/19 second area
Old 07-31-2014, 03:09 AM   #474
D.a.v.e's Avatar
Try your 2200 first and see how it does? Sounds like it might be about right?
Most the guys at our track run the Tekin 2650 buggy motors with 20t pinion. We require fans and body cut outs to keep the motor around 175 though.
D.a.v.e is offline   Reply With Quote
Old 07-31-2014, 06:14 PM   #475
nexxus's Avatar
Tried mounting the Orion motor last night and the front endbell has a pair of button head screws that are slightly elevated from the can and these hit the motor mount, so wondering am I best to shave these down or add 1mm or 2mm shims behind the motor mount screws to push the motor back a tad? Also have to dremel a bit off the side guard as the can hits this when you push it in (big can!)
Old 07-31-2014, 06:59 PM   #476
scooby61's Avatar
Check you clearance on the steering post adding shims may cause it to contact that. These chassis are a tight fit I measured three different motors before I found out the tekin would fit.
Losi 5T (awesome)
Old 07-31-2014, 07:01 PM   #477
scooby61's Avatar
Then I had to Dremel the castle fan shroud to clear the receiver box
Losi 5T (awesome)
Old 07-31-2014, 07:03 PM   #478
nexxus's Avatar
Not even at that stage yet! I had a spare mount so been working on that outside the car the length of the motor isn't too much greater than the RTR Dragon motor.
Old 08-01-2014, 06:13 AM   #479
scooby61's Avatar
Does anyone know if and when the rtr body will be available as a part? I like the body and am hoping it will come precut and partial paint like some of the 1/10 stuff.
Losi 5T (awesome)
Old 08-01-2014, 06:16 AM   #480
nexxus's Avatar
You could buy the RTR for the body like I did, scratch that bit of an expensive lesson lol!
Serpent Cobra GT John. Nitro On-Road 2307 Today 06:45 AM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
What's the gt car to buy???? 1966ss Nitro On-Road 26 06-04-2012 10:34 AM
