Old 07-09-2014, 05:08 AM   #451
machgo5go's Avatar
Originally Posted by myndesye View Post
Yes, these are the $$ if you want to play with Serpent. That's is why I named it the Million $ Car in my collection = "Euro PIT!!
Inferno GT2 VE Sweep PL1 Hobbywing XERUN w/2200KV - 4S. VE Audi R8 LMS Tekin RX8 Gen2 w/2650KV - 4S. AE TC6.1 SP Audi TC Tekin RS Gen2 w/8.5. TT-01E Audi R8 Hobby Wing 21.5T. TT-02 NSX-GT Hobby Wing 13.5T. DF-01 Porsche Cayenne 23T B.
MAJ'S HOBBY SHOP " 214 State st Suite 209 Hackensack, NJ 07601:201-820-1347
Racing: FRIDAY Mini Z Indoor/SATURDAY 1/8 & 1/10 VE Outdoor.
machgo5go is offline   Reply With Quote
Old 07-09-2014, 11:07 AM   #452
myndesye's Avatar
i was talking about the fact that they are over half off right now..... is this a legitimate retailer?
myndesye is offline   Reply With Quote
Old 07-09-2014, 12:52 PM   #453
scooby61's Avatar
Don't know looks like they are skimming A mains customers with that name research it if it says it's in hk or has been up less than 6 months I'd be wary.
Losi 5T (awesome)
Serpent cobra GTe, Serpent s411 eryx 2.0,
AE tc6.1, Losi 8Te 2.0, Losi 22b, AE t4,
Slash 4x4, Axial Deadbolt
scooby61 is offline   Reply With Quote
Old 07-10-2014, 06:22 PM   #454
machgo5go's Avatar
Originally Posted by Stealth_RT View Post
Most people use the buggy 10 deg caster blocks, to help keep the tires flatter during cornering. The 0 deg steering arms should give you more on power steering. I've also found, but not yet tested, that if you flip the front-front hinge pin block upside down, it takes some kickup out of the front arms, which should also help keep the tires flatter during cornering. Eventually, hopefully soon, we should see 0 deg caster blocks from Serpent.
There are so many adjustments to play with, to tune out things like on power push. Also, and it may just be how your picture was taken, it looks like you have a lot of toe out in the front. That will give you a lot of turn-in, but cost you steering coming out of the turns. Try less front toe out, get the 10 deg. buggy caster blocks, and the 0 deg. aluminum steering arms.
It is debut on FB on 0 deg. hubs. My question is why so drastic change from stock 12 degree to 0 instead of making something in between like 6 degree since other competitor cars are around that no.?
Old 07-10-2014, 07:54 PM   #455
ViperZ's Avatar
That's not such a bad price for those caster blocks...
Who races a Mazda Sedan...? Honestly...? :D
ViperZ is offline   Reply With Quote
Old 07-13-2014, 07:31 PM   #456
I figure this car would pretty easy to 'convert' to a buggy because of its inherent layout. Driveshafts, arms, links, center diff, bumpers, hardware, etc. Other than those few things, it's pretty much the same, correct? Are the differentials the same as well? I only mention this because this and the GTv2e are fairly competent GT8 cars, but the gt-e is basically a slightly different 811 b-e. The serpent is easily $130-180 more than the gtv2e, but you get carbon fiber decks and whatnot.
Though I'm waiting to see the e-truggy from serpent and possibly Losi, it would be cool to have the 1/8 onroad and e-truggy share some parts and overall layout design. I realize the parts support is pretty much online only for Serpent, Tekno, etc which isn't a big deal for me. I'd prefer not to have to buy a lot of parts, or lots of different parts. Still reading up on the durability of Serpent vs Tekno vs Durango.
RepEvox is offline   Reply With Quote
Old 07-13-2014, 07:59 PM   #457
scooby61's Avatar
I'm in the middle of my second season with the cobra gt e and I sold my gtv2e mostly because of lack of parts support and durability I've crashed the serpent hard more times than I can count and have never broken anything all the links and diffs are still slop free and smooth it's very sturdy
Losi 5T (awesome)
Old 07-14-2014, 07:40 AM   #458
D.a.v.e's Avatar
I've had great luck with mine as well racing it most every week last summer and a few times this year. I bought a bunch of extra parts and the only thing I've done is bent a drive shaft and stripped out the plastic in the servo horn.
Depending how many parts you really need to change vs the true differences to convert to get it to a buggy it can be expensive. Like cheaper to buy a new one expensive vs convert. But it does share a lot of parts. I have not looked at the options since they came out with the V2 & V3 buggies though.
D.a.v.e is offline   Reply With Quote
Old 07-14-2014, 07:52 AM   #459
D.a.v.e's Avatar
Wow its almost $100 map for those new caster blocks.. That might be a hard one for me to pull the trigger on? Too bad they did not do them in the composite material like the 10 degree ones.
Old 07-16-2014, 07:31 PM   #460
Keep in mind that the stock kickup on the Cobra is like 10 deg. So even with 0 deg. caster blocks, you'll still have 10 deg total caster. Plus or minus what you do with the front inner hinge pin inserts.
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 07-16-2014, 08:08 PM   #461
machgo5go's Avatar
Well after spending $$$ on this chassis, I am kind of giving up on it's steering characteristic. It just seem to have that understeer in off power into the corner that I can not get rid of. Other racer told me Serpent design slight brake in order to get tight turn to get on power steering which is hard for me to adapter from Kyosho's Inferno GT2 VE which out of the box gets lots of off power steering into a turn which I am use to.
Old 07-16-2014, 09:25 PM   #462
scooby61's Avatar
I had similar issues with turn in and was getting frustrated then I copied most of Andy Liu s setup for the nitro and bam car dialed in pretty sweet. I do have the 10 degree c hubs and 0 degree steering knuckles and I used 1000 cat shock oil white springs on the front and red on the rear. Try that might be what your looking for.
Losi 5T (awesome)
Old 07-25-2014, 11:04 AM   #463
Got my aluminum 0 deg caster blocks in today! Already got them installed on the car, but haven't raced it yet. On the bench, I can already see that the tires stay WAY flatter when at full steering lock than they ever did with the 10 deg caster blocks. Still using the 0 deg steering knuckles, not sure if they are absolutely necessary now. I think they will be more of a tuning option than a requirement. Can't wait to race it!
Also, I changed over my rear suspension to the 2.0 style. Racer at the same track bought the RTR Cobra GT-e, and it comes with the complete 2.0 style rear suspension, instead of the kit 1.0 style. Asked Chicky about this and he said Serpent was changing over to the 2.0 sytle on the GT cars. Makes sense from an inventory standpoint for serpent. All of the offroad buggies use the 2.0 style, so why keep making and stocking the old 1.0 style for the smaller number of GT cars they sell. And hey, more rear grip is always a good thing, especially now with the 0 deg caster blocks available. Getting enough steering should not be a problem. I didn't buy the full 2.0 conversion kit, I already had the 2.0 rear arms and 98mm dogbones from my offroad escale. Swapped in those parts, swapped the stock 1.0 rear hubs from left to right, and used -1mm hexes that I already had. Flipped the sway bar and camber links between front and rear of the shock tower, and reset droop, camber, and ride height. Stoked about running it this Sunday to see how much faster it is.
Old 07-26-2014, 11:57 PM   #464
nexxus's Avatar
Trader Rating: 294 (100%+)
I just picked up the RTR GT-E (painted lid was what called it for me) and I can't believe how cheaped out it is, luckily I have most of the upgrades from my Buggys but rear dog bones? Centre dog bones? And the screws are shocking, have stripped the two under the diff mount already, they're as soft as butter!
nexxus is offline   Reply With Quote
Old 07-27-2014, 10:13 AM   #465
I will never buy an RTR ever again, unless it happens to be RTR from the seller when I buy the kit version used. Besides, the differences between the RTR and kit seem to be biggest factor for me (carbon fibers plates, buggy/truggy high quality parts). I wish I could find a used GTE kit, but I havent had much luck so far.
Serpent Cobra GT John. Nitro On-Road 2073 01-19-2017 05:43 PM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 04:11 AM
What's the gt car to buy???? 1966ss Nitro On-Road 26 06-04-2012 11:34 AM
SEO by vBSEO 3.5.0
