Like Tree4Likes
Old 05-26-2014, 07:57 PM   #421
machgo5go's Avatar
Originally Posted by racerx1920 View Post
not an up grade per say, just an option
Ok but did anyone experienced rock pebble got trapped inside Center Diff housing and actually jammed up car by chipping of the Composite Gear's center of the teeth?
Inferno GT2 VE Sweep PL1 Hobbywing XERUN w/2200KV - 4S. VE Audi R8 LMS Tekin RX8 Gen2 w/2650KV - 4S. AE TC6.1 SP Audi TC Tekin RS Gen2 w/8.5. TT-01E Audi R8 Hobby Wing 21.5T. TT-02 NSX-GT Hobby Wing 13.5T. DF-01 Porsche Cayenne 23T B.
MAJ'S HOBBY SHOP " 214 State st Suite 209 Hackensack, NJ 07601:201-820-1347
Racing: FRIDAY Mini Z Indoor/SATURDAY 1/8 & 1/10 VE Outdoor.
machgo5go is offline   Reply With Quote
Old 05-26-2014, 09:37 PM   #422
I'm looking at getting this kit but i have looked and can't find which body this is? Its the one on the car kit pic? I checked the serpent site and can't find any info?www.serpent.com/product/600043
rayrush is offline   Reply With Quote
Old 05-27-2014, 01:45 PM   #423
The pro kit does not come with any body. The body shown in the pics is, I believe, the Serpent Blitz body, http://www.absolutehobbyz.com/produc...ducts_id=16704.
Chicky tells me ppl running these cars, nitro at least, are using that or the Alpha R3 body, http://www.absolutehobbyz.com/produc...ducts_id=11954
Don't know which is better, under what conditions, just got my kit myself and ordered the Blitz body.
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 05-27-2014, 02:55 PM   #424
scooby61's Avatar
Don't think it's the blitz body the one in the picture has a scoop on the top
But the blitz performs well the proto form pf8 fits and performs well also both give a little less steering than the Ipanema or the alpha I'm thinking of trying the alpha next. I had a pf8 last an entire season of abuse then I got the sew sweep body it's destroyed after two race days and the thing deforms and flops around at high speeds. Not gonna spend the money on that again
Losi 5T (awesome)
Serpent cobra GTe, Serpent s411 eryx 2.0,
AE tc6.1, Losi 8Te 2.0, Losi 22b, AE t4,
Slash 4x4, Axial Deadbolt
scooby61 is offline   Reply With Quote
Old 05-28-2014, 02:30 AM   #425
Thanks for answers about body!!!!
Old 06-05-2014, 06:01 AM   #426
racerx1920's Avatar
Trader Rating: 208 (100%+)
has anyone used the antiroll bar shaft with the antiroll wires?
http://www.igthobbies.com/SERPENT-SE...R-_p_3006.html
http://www.igthobbies.com/SERPENT-SE...2-_p_3012.html
Desoto Racing / Serpent America / ProOne RC
Serpent 748WC / Serpent s120LTR / Serpent Project 4x
Dunn Graphics
1/8th Scale Racers of Toledo
https://www.facebook.com/DunnGraphics1
racerx1920 is offline   Reply With Quote
Old 06-15-2014, 11:41 AM   #427
racerx1920's Avatar
has anyone ran this motor and if so how is it?
http://www3.towerhobbies.com/cgi-bin...?&I=LXDYFN&P=7
Dunn Graphics
Old 06-15-2014, 06:51 PM   #428
Ran my Cobra GT-e for the first time Saturday. Awesome car, super fun class to run. Track wasn't great, its an old parking lots with worn out asphalt and some bumpy sections. Oddly enough, belted treaded Ofna GT tires worked pretty good. Except they're almost worn out in one day. Lots of wheel-spin coming out of the corner, drifting a bit, at full throttle. Might try some Sweep treaded GT tires. Wish Alpha made treaded tires. Are the electric rated Alpha GT tires even available in the US?
Old 06-25-2014, 04:10 AM   #429
machgo5go's Avatar
On our Parking lot track at 80F +, Sweep 50 EXP Tread works the best in grip & especially in longevity. Ate up EXP 40~45 in a day.
Also I finally gave up on upgrade Composite Spur Gears because rock pebbles easily get in and destroying it
between pinion. Stick with Metal Spurs!
Old 06-25-2014, 06:29 AM   #430
scooby61's Avatar
try the grp treaded tires the last a couple race days and are sticky
Losi 5T (awesome)
Old 06-25-2014, 07:06 AM   #431
machgo5go's Avatar
I did try them but after few heat cycle, they just turn hard rock.
Old 06-25-2014, 02:35 PM   #432
I did try GRP tires last year on the same track. Less capable car tho, a cheap ofna GT car that had far too little rear toe in. The GRP tires just spun a lot and didn't get very good grip. Could have been the track surface too, too dusty. I will try them again on my new car. I will probably order some EXP treaded 50 tires as well.
Old 06-25-2014, 02:49 PM   #433
Yes, I'm running the stock steel spur gear. Got a new steel 44T spur gear to install, so I don't need huge pinions. Do you like the regular white rims over the black ROK rims?
Old 06-25-2014, 04:20 PM   #434
Has anyone tried running the car with the front hinge pin block flipped over? Tried this on the bench and it takes some kick-up out of the front end. Pulls the front of the front A arms down about a mm or so. Still leaves adjustability of the kickup using the front inserts. Should, hopefully, make the front tires wear flatter. Wish Serpent would make 6 and 8 deg. caster blocks for this car
Old 06-25-2014, 08:04 PM   #435
Evo 13's Avatar
Thanks for the input.
Most likely I will go with TrakPower LiPo 2S 7.4V 6000mAh 80C Hard Case 4mm
then due to same space restriction.
Right now I am running Peaks 5000 mAh 90C for testing.
And found an Old School Z that fit quite well!
That body looks tuff man!
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Mugen MBX7T ECO (Truggy)
SMC, Max Amps, LRP, Poseidon Motors, Cordova Research Motors, Xceed.
Evo 13 is offline   Reply With Quote
Serpent Cobra GT John. Nitro On-Road 2244 05-20-2017 11:02 AM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
What's the gt car to buy???? 1966ss Nitro On-Road 26 06-04-2012 10:34 AM
