Like Tree4Likes
Old 10-04-2013, 08:47 AM   #346
scooby61's Avatar
Originally Posted by D.a.v.e View Post
Unfortunately our season here in MI/OH is done & some of us are dusting off other stuff to race indoors this winter.
Still have 4 weeks left in va
Then offroad weather permitting
Just picked up a tlr 22 for indoor cause the serpent spyder isn't avail. Yet
scooby61 is offline   Reply With Quote
Old 10-17-2013, 07:35 PM   #347
Looks like Serpent has a new truggy e conversion. Might be interesting as from the description it says it uses buggy parts except for the truggy specific parts. The chassis has a new part number. What is really interesting is it says it fits all common buggy and truggy motors. This means there must be more space between the steering blocks and the battery holders. Might be able to squeeze in that Tekin 2250 after all. Anyone know what the wheelbase of the truggy is vs the buggy? Hopefully it's not that much and will allow using the same bodies. Or maybe it's the equivalent of the GT2 or Team C long wheelbase?
http://www.serpent.com/product/600666/
TEAM ASSOCIATED SC8e - Castle XO-1 1650kv and Mamba Monster Extreme
TEAM ASSOCIATED RC8.2e - Castle 2200kv and Mamba Monster
SERPENT Cobra-GTe - Tekin T8 1900kv and RX8
SERPENT S-411 2.0 Team Orion Vortex-R Pro and VST Pro 13.5T
SERPENT S-411 2.0 Team Orion Vortex-R Pro and REVTECH Killshot 17.5T
Bhodi11 is offline   Reply With Quote
Old 10-18-2013, 10:03 AM   #348
D.a.v.e's Avatar
Interesting that they did not include the alumn servo mount and other carbon bits.
D.a.v.e is offline   Reply With Quote
Old 10-24-2013, 05:37 AM   #349
RavenLS1's Avatar
Hi Guy's, who supply's a good fitting body for the serpent cobra GTe? Ive got bodies where the length is ok but the width is wrong, if any one knows where i can find i good fitting body can they let me know, thanks fellers.
RavenLS1 is offline   Reply With Quote
Old 10-24-2013, 07:30 AM   #350
D.a.v.e's Avatar
I ran this one http://www.amainhobbies.com/product_...GTP-Body-Clear
I did not have to do any mods for it to fit but in retrospect maybe should have glued a little extra foam on the bumper to make it a tighter fit to avoid the cracking on the wheel wells.. Though I'm sure avoiding the boards would have helped a lot more
I bought this one toward the end of the season and had to cut the bumper down a lot. This seems to be the case for many bodies.. http://www.amainhobbies.com/product_...-GT-Clear-Body
Old 10-24-2013, 04:00 PM   #351
RavenLS1's Avatar
thanks mate!
Old 11-01-2013, 03:44 AM   #352
RavenLS1's Avatar
Does anyone else know if a narrower body to fit the serpent properly , I just don't like the way normal 1/8th scale bodies fit being perfect length but the width is to wide, if anyone knows our one please let me know, I'm even thinking of cutting a body down the middle and removing the right amount and rejoining it, but there must be a body available for this car that fits like it should, please anyone with any help let me know, thanks everyone!
Old 03-24-2014, 06:11 PM   #353
scooby61's Avatar
First track day of spring yesterday was pain getting tires to temp but the cobra had fast lap in every heat I ran !!
Losi 5T (awesome)
Serpent cobra GTe, Serpent s411 eryx 2.0,
AE tc6.1, Losi 8Te 2.0, Losi 22b, AE t4,
Slash 4x4, Axial Deadbolt
Old 03-31-2014, 09:09 AM   #354
kyle3333's Avatar
I'm sorry if this is has already been covered, but I wanted to know what tires and wheels work best for this car. I know track conditions dictate what tires to use, but what is a good all around slick tire for this car?
Also, what body works the best with this car?
Thanks.
JConcepts UpGrade RC
kyle3333 is offline   Reply With Quote
Old 03-31-2014, 09:44 AM   #355
Thanks.
Tire of choice at our track has been GRP's
No other tire has been able give better lap times.
B compounds have been best for me.
Best place to buy them from is BrucknerHobbies.com
Also if you want to try Alpha's also. nitro guys really like those.
XRAY T4 14 - Orca - Futaba
Serpent 811 Cobra GT-E - Tekin - Hitec
Serpent 811 BE 2.0 - Tekin - Hitec
Voltron989 is offline   Reply With Quote
Old 03-31-2014, 09:52 AM   #356
scooby61's Avatar
Thanks.
I run sweeps for slicks but the alphas are good too however they seem to wear out faster imo for treaded tires I run Grp x and k compound but they are a diff diameter tire and will force you to alter you're setup. The grps are sticky as Hell when they are warmed up though and last for several race days on my track
Losi 5T (awesome)
Old 03-31-2014, 09:55 AM   #357
scooby61's Avatar
I also just got a body from sweep that looks nice but most run the protoform dp8 its cheap and fits nice but req trimming the bumper foam. Any gt1 body will fit not the kyosho or ofna gtv body's
Losi 5T (awesome)
Old 03-31-2014, 10:13 AM   #358
scooby61's Avatar
Thanks.
Can't upload from my phone but my avatar is the proto form body
Losi 5T (awesome)
Old 04-01-2014, 12:41 PM   #359
kyle3333's Avatar
Thanks for the recommendations on tires and bodies.
I come from 1/10th off-road racing, so trying to figure out what diameter tire to get has me clueless.
Can anyone shed some light on that? I see 45mm all the way up to 55mm. What applications and/or circumstances dictate what size to use? Is there a size that is the most popular and works in most conditions?
Old 04-01-2014, 02:47 PM   #360
All Gt tires are about the same size except for the GRPs they are smaller then other tires so they have shorter rollout.
But it's nothing to worry about(unless your doing speed runs) with a 7.40FDR on my GT-e with a 2650 I loose between 2-3mph on our back straight but my lap times are much faster.
Gear for temps not tires. The GRPs do take a little longer to warm up but when the do they out perform slicks by far and they are $12 a set cheaper.
I've been using GRPs for a couple years and tried all compounds but B compound have always been most consistent for me.
Serpent Cobra GT John. Nitro On-Road 2505 10-13-2017 02:10 AM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
What's the gt car to buy???? 1966ss Nitro On-Road 26 06-04-2012 10:34 AM
