Like Tree4Likes
Old 08-29-2013, 08:41 AM   #301
Originally Posted by D.a.v.e View Post
What did you use to lock it?
I packed it full of modeling clay. It does not budge a millimeter. Also easy to clean out later if I change my mind.
TEAM ASSOCIATED SC8e - Castle XO-1 1650kv and Mamba Monster Extreme
TEAM ASSOCIATED RC8.2e - Castle 2200kv and Mamba Monster
SERPENT Cobra-GTe - Tekin T8 1900kv and RX8
SERPENT S-411 2.0 Team Orion Vortex-R Pro and VST Pro 13.5T
SERPENT S-411 2.0 Team Orion Vortex-R Pro and REVTECH Killshot 17.5T
Bhodi11 is offline   Reply With Quote
Old 08-29-2013, 03:14 PM   #302
scooby61's Avatar
Just got my rear diff housing assembled and its cogging a bit I used one shim
Is this normal until breakin or is it too tight??
scooby61 is offline   Reply With Quote
Old 08-29-2013, 03:33 PM   #303
scooby61's Avatar
Never mind it was a casting burr in the diff housing dremel fixed it
Old 08-30-2013, 12:41 PM   #304
scooby61's Avatar
Ok getting pissed now, I'm about to take the rear diff case apart for the third time. When I assemble it and tighten the hinge pin bracket screws the ring gear rubs the inside of the diff housing. I have dremeled several casting nubs out already. Has anyone else seen this problem?? For a kit this expensive I shouldn't have 3+ hours into assembling the rear diff. Ridiculous
Old 08-30-2013, 01:43 PM   #305
Julius's Avatar
The ring gear most likely rubs on one of the 3 screws that hold the bearing in the diff case. Either remove the screw closest to the ring gear, or dremel it's head to be smaller.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 08-30-2013, 02:51 PM   #306
scooby61's Avatar
Well to fix that will be taking it apart for the fifth time but ill try it. At this point I've dremeled casting nubs from the the diff housing then found one on the diff case that prevented the ring gear from seating flush. It got better with each Chang but at this point my fingers are raw and fore arms pumped from turning those screws.
Old 08-30-2013, 03:33 PM   #307
tonylunatic's Avatar
Trader Rating: 44 (100%+)
You need a mini power drill.
Serpent/Desoto Racing USA~Murnan Modified Motors~PTRC Racing Fluids~Flo-Control ~IGTHobbies.com
tonylunatic is offline   Reply With Quote
Old 08-31-2013, 03:46 PM   #308
D.a.v.e's Avatar
Wow sounds like they may have had a bad parts run. Only thing I had to do was loosen up a few ball cups that were to tight.
D.a.v.e is offline   Reply With Quote
Old 09-01-2013, 05:07 PM   #309
scooby61's Avatar
Front bulkhead screws hit me as well couldn't even drive 12mm in without stripping. So I got a 3mm tap and cured that. All the ball cups in the front are a little tight trying to decide if they will break loose with a little use or if I nee to loosen them. Overall I really like the designof the kit just a lot of fitment issues I haven't had these problems with my 10th scale serpents. The chassis ready for electronics now so a shakedown cruise will happen soon.
Old 09-01-2013, 05:10 PM   #310
scooby61's Avatar
And yes the ring gears were rubbing the bearing retainer screw so took the one out on the gear side hope this doesn't cause problems later
Old 09-02-2013, 04:14 AM   #311
Julius's Avatar
It should not, especially in in road. However you can always reduce the head of the screw a little and put it back in.
It is very tight there, and it depends a little on the diff shimming if it touches.
Glad it is solved now.
Old 09-10-2013, 09:30 AM   #312
scooby61's Avatar
Wow got the cobra for some test runs on Sunday this chassis tunes in quick. Should be ready to race it this weekend. And the tekin rx8 and 2650 makes it a rocket ship. I can already see this car outhandles and is easier to tune than my gtv2. Plus weighs quite a bit less. Looks like the cobra is my new fav.
Old 09-10-2013, 04:07 PM   #313
Is your GTV2 the Pro or RTR?
XRAY T4 14 - Orca - Futaba
Serpent 811 Cobra GT-E - Tekin - Hitec
Serpent 811 BE 2.0 - Tekin - Hitec
Voltron989 is offline   Reply With Quote
Old 09-11-2013, 03:05 AM   #314
scooby61's Avatar
It was rtr. But with the exception of the shock towers an shocks has been upgraded to pro
Old 09-12-2013, 08:45 AM   #315
D.a.v.e's Avatar
Voltron989: Thinking of running two cars next year like Bill?
Serpent Cobra GT John. Nitro On-Road 2244 05-20-2017 11:02 AM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
What's the gt car to buy???? 1966ss Nitro On-Road 26 06-04-2012 10:34 AM
