Like Tree4Likes
Old 08-23-2013, 02:42 AM   #271
M7H
M7H's Avatar
Originally Posted by RavenLS1 View Post
sweet looks like i can fit a CC 2200kv in it!
If your talking Neu-Castle 1515 can size, then no.....
Edit, you already found out that.
Yes, in my opinion, a 2650 on 4S is fast enough, actually depending on the gearing you put in, it might be faster then the Nitro GT.
On our club, there is 1 GT-e running with Tekin RX8/T8-2650, and it reaches 90 kmh (55 miles) I think thats about the max speed the car should go on our track, and still be controlable to reach good laptimes.....
Serpent
M7H is offline   Reply With Quote
Old 08-23-2013, 02:50 AM   #272
RavenLS1's Avatar
sounds good, thanks mate!
RavenLS1 is offline   Reply With Quote
Old 08-23-2013, 08:21 AM   #273
D.a.v.e's Avatar
I suspect you will blow up that motor running 6 cell. I've had good luck running 6 cell this season with a 1700KV Tekin. Running 6 cell its just as fast as the 2650 on 4 cell.
The hardest part about running 6 cell is finding packs that fit in the trays. I run 2 x 3 cell 5000mah packs and had to add extenders on the battery tray posts due to the added height of the packs. I only use about 60% of the pack during a 7 min race and a 2-3 min warm up. I would look for something in the range of 3800-4200's next time I buy batts. Note: The guys running 4 cell are in the 7000mah range at my track and sometimes run out of juice.
D.a.v.e is offline   Reply With Quote
Old 08-23-2013, 08:54 AM   #274
D.a.v.e's Avatar
Guess they are putting the receiver on the cf that is hanging at the top there?
I suppose this will make more room for a larger motor and or heat sync with fan. I had to hack a few things up to get one to fit in the current configuration. Will also make centering the servo horn and reinstalling the front drive shaft way easier. Trying to imagine how to hide all the wires with this?
I really like that it will make working on the car faster/easier but it's a pricy upgrade for $108.
Old 08-23-2013, 09:12 AM   #275
Motor size isn't going to change. Will still be limited to short can motors. Picture throws u off because no steering rack is in that pic.
Will help with airflow around the motor though which I like.
I also like the machined servo mount. Mine is slightly twisting as I turn wheels
I keep retightening everything but always loosens back up.
Should also give a little more flex to the chassis too
I have the kit already but probably won't install it untill the winter because I really don't want to break it down at the moment. Unless something breaks that is lol rather wait till winter when I plan to refresh some parts anyways
XRAY T4 14 - Orca - Futaba
Serpent 811 Cobra GT-E - Tekin - Hitec
Serpent 811 BE 2.0 - Tekin - Hitec
Voltron989 is offline   Reply With Quote
Old 08-23-2013, 09:55 AM   #276
Well not exactly true. Only time I've ever ran out of juice was when I used 5600mah batteries and did practice laps. I don't have a problem with 7000's. after a race I'm right at 3.8/cell which is pretty much perfect.
And to be fair when comparing power consumption, bill and I run our cars harder and end up doing 2-3 laps per race more so obviously more power is being used.
Let bill run your car for a full race and see what your temps and batteries are at after
Old 08-23-2013, 02:50 PM   #277
RavenLS1's Avatar
i will only be running 4s with the 2650kv fitted
Old 08-23-2013, 03:18 PM   #278
Jspeed's Avatar
Thumbs up
The Ipanema Top Speed Club contest starts September 1st.
We’re looking to give back to the Top Speed R/C community for your incredible accomplishments.
Feel free to visit our website for full event rules, how to enter and win.
Good luck everyone and thank you all very much!
Jspeed is offline   Reply With Quote
Old 08-24-2013, 07:49 PM   #279
RavenLS1's Avatar
will these spare parts work with the on road serpent cobra?
http://stores.ebay.com/Jennys-RCSpor...=p4634.c0.m322
Old 08-26-2013, 12:58 PM   #280
the only thing really would be the 2.0 diffs but honestly if you looking for back ups theres really not much use for them... ive had the car a year and have yet to need to replace anything. worse I came across is a screw or 2 backing out on me. only parts you need to buy are upgrades
Old 08-26-2013, 05:42 PM   #281
scooby61's Avatar
Got the hard servo saver ,front swaybar, yellow springset, and diff oil on the way with the kit can't find the 10* c hubs any where and do they make the 0* steering block in plastic the alum. Is ridiculously expensive
scooby61 is offline   Reply With Quote
Old 08-26-2013, 06:03 PM   #282
http://www.amainhobbies.com/product_...t-10-C-Hub-Set
Old 08-26-2013, 08:08 PM   #283
scooby61's Avatar
Originally Posted by Voltron989 View Post
what hubs does the kit come with ??
Old 08-27-2013, 10:18 PM   #284
Got to run it at the track today.
Ran tekin 2650 geared 46/22. Ran nice and smooth.
Fans help a lot they are the 2-cell YR fans, I believe 0180
Really need windshield cut outs and fans when running any onroad regardless of motor and ESC combo because they all get hot unless your geared really slow
240 degrees is nuts. Highest I seen was 140's after 5000mah packs.. ran with the fans and no cut outs. If your windshield doesn't have cut out that would be the first thing I do
What heatsinks did you use or how did you mount your tornado fans? My heat problem has mysteriously reappeared. I want to duplicate your setup to see if it helps. Thanks.
TEAM ASSOCIATED SC8e - Castle XO-1 1650kv and Mamba Monster Extreme
TEAM ASSOCIATED RC8.2e - Castle 2200kv and Mamba Monster
SERPENT Cobra-GTe - Tekin T8 1900kv and RX8
SERPENT S-411 2.0 Team Orion Vortex-R Pro and VST Pro 13.5T
SERPENT S-411 2.0 Team Orion Vortex-R Pro and REVTECH Killshot 17.5T
Bhodi11 is offline   Reply With Quote
Old 08-28-2013, 05:28 AM   #285
I use this heatsink and fan combo
http://www.rcmart.com/yeah-racing-ya...?cPath=1560_32
To fit the heatsink I had to dremel off a couple fins off the heatsink because the bottom corner of the RX Box/compartment would press against the heatsink
I also have a 25mmx25mm YR fan mounted on the front corner of the mud guards that points at the back of the motor for some extra airflow.
What batteries are u using? I had heat issues running 7200 80c lipos.
I switch to 7000 50c gen ace lipos and it helped out.
What temps are u hitting? If you were running fine and all of a sudden your temps are getting much hotter then it could be a sign that your motor might be on its way out. What gearing are u running with the 1900?
Serpent Cobra GT John. Nitro On-Road 2295 Yesterday 09:24 PM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
What's the gt car to buy???? 1966ss Nitro On-Road 26 06-04-2012 10:34 AM
