Old 08-22-2013, 08:18 PM   #256
D.a.v.e's Avatar
I like the newest setup posted in the nitro section of the serpent site. The only change you will need to make is on ride hight and droop as those tires are a bit smaller. The front kick up and rear settings help a lot over the stock and are no cost.
My diffs are 200,300,50 I have the v1's though there are recommendations for v2 on the setup sheet. I also like the 60wt/800 shock oil as well. The red and white springs mentioned above worked well on the stock setup but I found my back end bottoming out with red on the softer shock set up.
The upgrades mentioned above are all good recommendations I would add the wheel off sets -1 or -2 in front and +2 or 3 in the rear. I have -1 up front and +3 in the rear.
Eventually you may want some different springs and sway bars but the ones in the newest setup work well for me. I messed with setup a lot making one change at a time.
the upgrades are nice but a lot can be done with a little shock and diff oil then tuning using various setting avail out of the box. After getting some fans, I would suggest getting the 0 degree hubs and 10 degree caster blocks (together removes 7 degrees) as it seems to help reduce front tire wear a lot.
D.a.v.e is offline   Reply With Quote
Old 08-22-2013, 10:27 PM   #257
RavenLS1's Avatar
Originally Posted by Voltron989 View Post
Truggy motors like the 2200 castle or the 4038 line of tekin truggy motors will not fit.
will the castle 2650kv fit?
RavenLS1 is offline   Reply With Quote
Old 08-22-2013, 10:29 PM   #258
RavenLS1's Avatar
im starting to think i should have bought the ofna gtv2e instead, whats the best motor that fits that can handle 6s?
Old 08-23-2013, 12:58 AM   #259
M7H
M7H's Avatar
6S, in a Cobra? Are you crazy?.....
But if you really want to, go for the Tekin Buggy motors....
I drive the 1900kV, on 6S, in my 966e.
Serpent
M7H is offline   Reply With Quote
Old 08-23-2013, 01:26 AM   #260
RavenLS1's Avatar
why would you say i'm crazy? i run 6s in all of my 1/8 on road cars and they are fine, whats with the cobra thats different? It sounds like i defiantly have made a mistake by buying this car by the sounds of it. Any one want to swap for a Ofna GTV2e?
does a CC 2650kv fit ok? i wont mind running 4s as long as its this motor
Old 08-23-2013, 02:00 AM   #261
M7H
M7H's Avatar
On 6S the car can be very fast, depending of course on the motor you put in.
What's the size of the CC 2650 motor?
Serpent
Old 08-23-2013, 02:20 AM   #262
RavenLS1's Avatar
Motor Diameter: 39.98mm 41.78mm with fins
Motor Length: 68mm
Old 08-23-2013, 02:29 AM   #263
M7H
M7H's Avatar
Motor Length: 68mm
Yep, I found that to, on the CC site.
and what does Serpent's site say on the max Motor size?
Or because you have the car, did you measure the available space already?
Serpent
Old 08-23-2013, 02:34 AM   #264
RavenLS1's Avatar
nah the car is in the post, so i cant measure it
Old 08-23-2013, 02:36 AM   #265
RC MARKET's Avatar
Serpent New Option Parts
RC MARKET is offline   Reply With Quote
Old 08-23-2013, 02:38 AM   #266
RavenLS1's Avatar
Motor mount
Machined 7075 T6 aluminium motor-mount with one-screw fixation and easy slider system. Flex-free and very strong motormount. The space for the motor allows a maximum motor-length of 72mm, which covers most widely used motors.
Old 08-23-2013, 02:38 AM   #267
M7H
M7H's Avatar
Ok, well depending a bit on the diameter of the motor, but you can put up to 72mm of can size in the Cobra, so yes, your CC 2650kv will fit.
Serpent
Old 08-23-2013, 02:38 AM   #268
RavenLS1's Avatar
sweet looks like i can fit a CC 2200kv in it!
Old 08-23-2013, 02:39 AM   #269
RavenLS1's Avatar
im gonna fit a 2200kv and run 6s
Old 08-23-2013, 02:41 AM   #270
RavenLS1's Avatar
actually it wont fit
will have to make do with a 2650kv and 4s, should be plenty fast still i reckon.
Serpent Cobra GT John. Nitro On-Road 2174 03-24-2017 03:48 PM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
What's the gt car to buy???? 1966ss Nitro On-Road 26 06-04-2012 10:34 AM
