Old 07-03-2013, 10:07 PM   #241
RC-ProSpeed's Avatar
Originally Posted by FastPete View Post
I would be running 500 200 100 V2 gears
200 100 40 V1
Thanks, i'll give it a try.
RCRNV (www.rcrnv.com) / *Keep On-Road alive!*
- Nitro Touring - Kyosho EVO 2 WC
- Electric - TC6 (Out of the Box! No upgrades needed)
- F1 - F103RM (Out of the Box! No upgrades needed)
RC-ProSpeed is offline   Reply With Quote
Old 07-04-2013, 04:35 AM   #242
M7H
M7H's Avatar
Originally Posted by scooby61 View Post
Running on a small track 140 ft straight but some really fast guys there I'm currently running a teamc gt8le but the long chassis makes the infield difficult so handleing is more key than speed I will be doing a lot of quick throttle bursts with stand of braking
Then I think with a 2650 motor, a 17 or 18 pinion is where you need to go for.
Originally Posted by D.a.v.e View Post
I've got a 1700KV running 6 cells with a 19 tooth pinion (my car is at least 30% heavier then theirs..maybe 50%). When I'm on the track with the nitro guys I'm way faster then them accelerating out of a corner (does not matter if its a touring, pan, or GT car.. Have not shared the track with a 1/8 scale yet). On the long strait they did seem a bit quicker at the top end.
At our rather large track we turn faster lap times then the nitro guys by 1 to 2 seconds. But we also don't run on the same day and for some reason we run different tires so a true comparison is tough.
Thanks for the info.
Serpent
M7H is offline   Reply With Quote
Old 07-10-2013, 09:20 AM   #243
Default serpent motor
the max size motor that will fit is 71mm.im running tekin 2650kv on 4s in mine and it really hauls.i have a gtp2e,dm1e,gtv2e pro,and an x01 and the serpent is by far the best of all.
rlinds is offline   Reply With Quote
Old 08-03-2013, 04:25 PM   #244
scooby61's Avatar
Has anyone here dealt with a Chinese wholesaler called "Valeo gccu"
They have a really good price on cobra gte's but I'm worried about dealing direct with China
scooby61 is offline   Reply With Quote
Old 08-03-2013, 04:36 PM   #245
scooby61's Avatar
Actually its vankeinc.com the other name is just the host
Old 08-05-2013, 07:29 AM   #246
D.a.v.e's Avatar
Let us know if you try it. Looks like they have a $300 min order.. You'll have to get two
D.a.v.e is offline   Reply With Quote
Old 08-05-2013, 09:33 AM   #247
scooby61's Avatar
Actually did some research domain is only reg. 45 days ago and with western union only pay method smells like a scam site
Old 08-20-2013, 06:13 PM   #248
D.a.v.e's Avatar
Has anyone found a better set up then what the nitro guys are running right now? I've been running the newest set up with a bit higher ride height for a couple weeks now and the car is feeling better then ever.
Old 08-21-2013, 07:46 AM   #249
RavenLS1's Avatar
I'm about to purchase a cobra and need to know what body's fit as from what ive read it dosent come with one
RavenLS1 is offline   Reply With Quote
Old 08-21-2013, 08:13 AM   #250
Jspeed's Avatar
Thumbs up
The Ipanema Warrior body is a great option.
Jspeed is offline   Reply With Quote
Old 08-21-2013, 08:59 AM   #251
scooby61's Avatar
Any 330mm body will fit ie: body's for ofna gtp2,dm1, kyosho gt body's (not gt2) protoform dp8, alpha r1&2
The gtv2 ans kyoshogt2 are 360mm
Old 08-21-2013, 03:04 PM   #252
RavenLS1's Avatar
thanks guys! yep the warrior body is what ill get, its the best looking and it works so well in high speed runs
Old 08-22-2013, 06:17 AM   #253
scooby61's Avatar
Pulled the trigger on my gt-e a few days ago, order diff fluids with the kit and picked up the shorter front bulkhead screws. Any other issues I should be prepared for in the build?? Probably going with the tekin 2650 setup. What springs and shock oil is everyone using? This will be for a parking lot track with grp's as the spec tire and 4 cell battery
Old 08-22-2013, 06:20 AM   #254
RavenLS1's Avatar
is that length or diameteI'm tossing up between a CC 2650kv or a 2200kv will they both fit?
Old 08-22-2013, 07:38 AM   #255
Things I'd personally recommend are
10 degree c-hubs and the 0 degree steering blocks.
The steering blocks are kind of pricey if you don't go with them atleast get the plastic 10 degree C-hubs
Aluminum servo horn and the Hard servo saver spring. Stock servo spring is too soft.
Serrated wheel nuts, serpent ones are pricey at $30 for the set but any 17mm fine thread wheel nuts will work
2.3mm front sway bar
I'd also suggest the 46T composite center diff spur instead of steel and some high flow motor and ESC fans.
As far as springs and fluid. That depends on the track and your style of driving.
For a prepped high bite track id go on the stiffer side while on a looser unprepped track id go softer.
I recently switched to a softer setup and really like it.
800cst all around with red springs in rear and yellow upfront.
Stock set up is a good starting point though
Truggy motors like the 2200 castle or the 4038 line of tekin truggy motors will not fit.
XRAY T4 14 - Orca - Futaba
Serpent 811 Cobra GT-E - Tekin - Hitec
Serpent 811 BE 2.0 - Tekin - Hitec
Voltron989 is offline   Reply With Quote
Serpent Cobra GT John. Nitro On-Road 2061 Today 01:42 PM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 04:11 AM
What's the gt car to buy???? 1966ss Nitro On-Road 26 06-04-2012 11:34 AM
SEO by vBSEO 3.5.0
