Like Tree4Likes
Old 11-01-2012, 04:29 PM   #166
Hey guys I'm getting into electric GT racing and I have always used LRP speed controllers with great results. I see that most are using the Tekin line but how about this combo for the e-Cobra:
http://www.amainhobbies.com/product_...r-Combo-2200kV
Will this be competitive? Our track has two long straights one is about 175 feet long and the other is about 225 feet. The laps in my Cobra GT Nitro are in the 24 seconds. I just want to be on pace with the nitros. Any help would be very welcome.
jneg is offline   Reply With Quote
Old 11-02-2012, 02:30 AM   #167
M7H
M7H's Avatar
I've tested that combo in the e-Cobra, and it works great!
Only problem I have, I don't know what speeds the nitro's reach.
I drove the Ix8/2200KV with stock spur in the car, and 20 Pinion and reached a top speed of 75 kmh (measured with mylaps speedtrap).
Gearing heavier is still possible, but maybe going for the 2600KV LRP motor is also something to think about.
Serpent
M7H is offline   Reply With Quote
Old 11-02-2012, 08:17 PM   #168
Thank foe the reply, good info. My Gt might be a little faster so maybe the 2600 might be the ticket for me.
Old 11-03-2012, 04:53 AM   #169
With the Tekin 2650 combo with the stock spur and 20T pinion I reach 58mph on the 230ft straight at our track. That's with giving the car enough room to stop
Top speed with room would be in the 70mph range on 4s
XRAY T4 14 - Orca - Futaba
Serpent 811 Cobra GT-E - Tekin - Hitec
Serpent 811 BE 2.0 - Tekin - Hitec
Voltron989 is offline   Reply With Quote
Old 11-03-2012, 01:44 PM   #170
Would you be kind enough to share your Hotwire setup?
TEAM ASSOCIATED SC8e - Castle XO-1 1650kv and Mamba Monster Extreme
TEAM ASSOCIATED RC8.2e - Castle 2200kv and Mamba Monster
SERPENT Cobra-GTe - Tekin T8 1900kv and RX8
SERPENT S-411 2.0 Team Orion Vortex-R Pro and VST Pro 13.5T
SERPENT S-411 2.0 Team Orion Vortex-R Pro and REVTECH Killshot 17.5T
Bhodi11 is offline   Reply With Quote
Old 11-04-2012, 03:03 PM   #171
Nothing very special at all. Haven't had much time with it since by the time it came out our on road season was to a end.
Throttle profile 3(default)
Timing 15 degrees from 16,000 up
Brake strength 55
Drag brake 3
Current limit 0
Old 11-15-2012, 09:16 AM   #172
D.a.v.e's Avatar
Brake strength 55
Drag brake 3
Current limit 0
What kind of run times are you getting?
D.a.v.e is offline   Reply With Quote
Old 11-15-2012, 03:03 PM   #173
What temps are you getting on the motor and what is the ambient temperature where you race? My local track has an ambient temp of 85F average. With the track temps around 120 to 135F. I don't want to roast the motor.
Old 11-15-2012, 06:07 PM   #174
Depends on Mah and C rating.
With a 14.0v cut off a 4s 5000mah 50C pack will give me a 8-9 minute run time while a 5000mah 65C pack will only last 5-6 minutes
Old 11-15-2012, 06:11 PM   #175
With those same temps with only cut outs on the body motor temps would reach 170-180 degrees in a 7 minute main..When I added high flow fans temps dropped to 150
Old 11-16-2012, 06:33 AM   #176
D.a.v.e's Avatar
Thinking about one of these for next year. How long can one expect to get out of a set of tires?
Old 11-16-2012, 09:55 AM   #177
All depends on how you drive. One guy at our track had a set of sweeps last him all season while I destroyed a set in one battery pack driving like a A-hole.
Same goes for run time. If your not mashing it in and out of every turn your run time will almost double.
Old 11-17-2012, 09:54 AM   #178
D.a.v.e's Avatar
Not sure where you race but will they run the nitro and electric guys together in this class?
Old 11-17-2012, 10:14 AM   #179
We race at the 1/8 racers of Toledo track in Toledo Ohio.
Saturdays are electric and Sundays are Nitro
Old 11-17-2012, 02:59 PM   #180
Not here. If there are not enough electrics then the guy can try to but since most we race 45 to 1 hour A main and 30 minute B main most won't even try. In the big races that I've been there have bein an electric class but none have even tried. Since the electric GT are now comming to the track then in our next big race maybe ther will be at least a main. Nitro we have more than 60 racers with most race turn outs around 30 guys.
Serpent Cobra GT John. Nitro On-Road 2244 05-20-2017 11:02 AM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
What's the gt car to buy???? 1966ss Nitro On-Road 26 06-04-2012 10:34 AM
