Like Tree1Likes
Old 12-19-2013, 04:39 PM   #1441
Trader Rating: 101 (99%+)
Originally Posted by Yukie View Post
Anyone maybe want the car or other bits separately? I'm willing to split up the package.
Also selling a brand new, still in package, MYLAPS Personal RC4 Hybrid Direct Powered Transponder for 75$.
2 PM's sent about MyLaps Personal Transponder, just waiting on the response! Thanks! Richard
~ Richard Watchorn ~
* Team Associated/Reedy Electronics * OCRC Raceway *
* Schelle Racing * CBuilt Designs * Complex Ink *
desertracerdad is offline   Reply With Quote
Old 12-28-2013, 06:00 PM   #1442
ShaunMac's Avatar
Any other manufacturers outdrives compatible with the HB spool? I'm looking for outdrives that allow for the use of blades.
ShaunMac is offline   Reply With Quote
Old 12-31-2013, 01:30 PM   #1443
English365's Avatar
Trader Rating: 128 (100%+)
Don't the steel out drives allow the use of blades?
Kyosho America~Thunder Power~Team Orion~KO PROPO~AKA
Mikes Hobby Shop...TeamTreeTop!
English365 is offline   Reply With Quote
Old 12-31-2013, 03:54 PM   #1444
Trader Rating: 20 (100%+)
nope the POM and steel spool outdrives are perfect fit with the 2mm axle pins up front. You can run the HB gear diff up front if you want to use blades also.
On my older TCX I was using Spec R gear diffs with blades, and I can use the ver.1 hb dcj that had bigger axle pins.
goots is offline   Reply With Quote
Old 12-31-2013, 08:16 PM   #1445
ShaunMac's Avatar
What's the difference between the Ver.1 and Ver.2 DCJ? I thought it was just the pin size that was different. Price for the Ver.2 is $45 each!!!
Old 12-31-2013, 08:26 PM   #1446
Chrisgt2's Avatar
Send a message via MSN to Chrisgt2 Send a message via Yahoo to Chrisgt2
The original version wasn't rebuildable, v2 are.
Hot Bodies Pro 5
*Sponsors*
Hot Bodies, Speed Passion, Team Scream Racing, Rockstar Paint
Franchise Racing Products
The Raceway - Beaver, PA
Chrisgt2 is offline   Reply With Quote
Old 12-31-2013, 08:35 PM   #1447
ShaunMac's Avatar
Really? They look identical to each other and I can't find it listed anywhere that they are rebuildable. Do you have a set of Ver.2 that you have rebuilt recently?
Old 12-31-2013, 08:42 PM   #1448
Chrisgt2's Avatar
I run the tamiya shafts, but when I was comparing before, that was the info I found out about the hb parts. I also heard that the tamiya shafts were more durable. I also have a set of spec r shafts in my other car that are well made.
Hot Bodies Pro 5
*Sponsors*
Old 01-01-2014, 07:54 AM   #1449
theclutch's Avatar
I've never seen DCJs from any manufacturer to be rebuild able. I believe the difference are in the pin size. I have the old ones and I beleive I spent around $30 each which I already thought was pricey...
Durango DEST210R, XRAY XB4 2014, Vaterra Slick Rock, Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
theclutch is offline   Reply With Quote
Old 01-01-2014, 08:10 AM   #1450
Chrisgt2's Avatar
The tamiya dcj's I'm using are rebuildable. There are clips that hold the pins in.
In looking at my hb shafts in the other car, it appears they are Not rebuildable like I was told. I really never looked at them closely.
So, I would purchase more tamiya shafts or the rsd shafts from reflex racing.
Hot Bodies Pro 5
*Sponsors*
Old 01-01-2014, 08:10 AM   #1451
Chrisgt2's Avatar
Hot Bodies Pro 5
*Sponsors*
Old 01-01-2014, 03:19 PM   #1452
tc3 racer sc's Avatar
Default where can i get a steering rack for my tcxx
ever since i build my tcxx i been having problems out of the steering rack i had to replace the +2arms the bearing were not in it from the kit towerhobbies replace them i feel like i got a bad kit i want to continue running my tcxx im getting second thoughs my hotbodies tc with the exotek chassis more consistent than my tcxx so in other word where can i get a steering rack
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 01-01-2014, 03:27 PM   #1453
So your tcxx is a bad kit and inconsistent because there was no bearings in the steering rack. Is that what you're saying?
Old 01-01-2014, 03:36 PM   #1454
first it was the arms now the steering rack lost the bearing i ran the car sunday spoiled my whole day i build the kit 2month ago ever since i could not get the screw stay in on the bottom of the rack so fred told me to put blue lock tight on them it stayed and now this
Old 01-01-2014, 06:52 PM   #1455
ShaunMac's Avatar
A-Main has HBS68824 Hot Bodies +2mm Steering Arm Set -in stock-
This is the rack that comes with the TCXX.
Hot Bodies TCX academygaz Electric On-Road 4798 09-09-2015 04:26 PM
HOT BODIES TCX SALE!!! Yokomo_Ant3 Australia For Sale/Trade 19 07-05-2012 07:25 PM
Best 1/10th scale electric car to buy WD40 Electric On-Road 68 04-18-2012 09:22 AM
What Have I Missed? Twism86 Electric On-Road 18 04-02-2012 02:33 PM
