Like Tree1Likes
Old 09-16-2013, 05:05 AM   #1351
Potoczak's Avatar
Trader Rating: 110 (100%+)
Originally Posted by Lutz View Post
I know that there will be a conversion kit with new chassis, servo mount, motor mount,
Short shocks and new driveshafts.
Should be available in early 2014.
Wow that sounds great. Does anyone have more information on this???
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 09-21-2013, 02:08 PM   #1352
Potoczak's Avatar
Does anyone know if the rear gear diff can be run in the front??
Pete Potoczak
Old 09-21-2013, 06:27 PM   #1353
Yes
Juan Aveytia is offline   Reply With Quote
Old 09-22-2013, 07:19 AM   #1354
theclutch's Avatar
Yes, but why would you want to?
Durango DEST210R, XRAY XB4 2014, Vaterra Slick Rock, Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
theclutch is offline   Reply With Quote
Old 09-22-2013, 12:32 PM   #1355
Trader Rating: 20 (100%+)
I find more initial steering, smoother cornering, better front end durability. I forgot the part number but they have the out drives so you can use the gear diff in the front.
goots is offline   Reply With Quote
Old 09-22-2013, 12:37 PM   #1356
Potoczak's Avatar
So the gear diff is not a straight drop in??
Pete Potoczak
Old 09-22-2013, 12:38 PM   #1357
Potoczak's Avatar
For me it feels like it smooths out the steering and also better durability.
Pete Potoczak
Old 09-22-2013, 01:06 PM   #1358
I think it is. I built a friends tcxx with the front drive cup option part, and the only difference I saw was the use of no driveshaft blades.
Old 09-22-2013, 01:15 PM   #1359
Fred Hubbard's Avatar
Yep direct drop-in but it comes with outdrives that are used in the rear and require blades so for the front we run Hot Bodies Gear Diff Outdrive Set Front/Steel TCXX (2) since these don't require a blade and have a 2mm slit.
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 09-22-2013, 09:46 PM   #1360
Nuno Gancho's Avatar
Hi Fred,
Is the diff normally used on the front if so how do you build it with Putty or diff oil, will you use it on stock and modify?
thanks Nuno.
Nuno Gancho is offline   Reply With Quote
Old 10-02-2013, 06:58 PM   #1361
ShaunMac's Avatar
Anyone use the TCX 2.0mm topdeck? How does it compare to the TCXX 2.0mm topdeck? Any major noticeable flex differences between the two?
ShaunMac is offline   Reply With Quote
Old 10-03-2013, 05:52 AM   #1362
Do the TCXX gear diffs have any leaking issues? I would like to install one in my TCX but it seems like everyone but Xray drives complain about leaky diffs.
kawi650 is offline   Reply With Quote
Old 10-03-2013, 06:47 AM   #1363
More mid-corner rotation due to more flex, and it allows the car to be easier to drive on high grip carpet.
I've only heard of one person on this thread who had an issue with leaking. I have an issue once but it was due to a bad small oring and I've not heard of or seen anyone in my region have an issue with it. BTW I have heard of people having issues with Xray diff's leaking too.
Old 10-11-2013, 08:14 PM   #1364
Bundy_Bear's Avatar
Hi
My brother and I are running the Nitro R10, just wondered if you have issues with the shock bladders on the electric and if you have any suggestions for alternatives?
Andrew
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 10-12-2013, 02:53 AM   #1365
So when I was first starting back up in Rc a year ago, I got a tcx for drifting. After visiting a local track I started racing heavily, and went to an xray t3. Now I have a t3'12 for my VTA, and a t4 for sedan. Love them. Having said that I still have a spot for the tcx-maybe it's the purple, I don't know. But, recently having a look at the tcxx, it looks promising! Same suspension design as the newest t4, narrow chassis, excellent gear diff? What isn't there to like? Any major changes out of the box? How is it in comparison to speed, laptimes, ease of use? Reliability/robustness? I'm actually curious to try one or two..
~Xray~RCAmerica~Motiv~Gravity RC~
Boostinswifty38 is offline   Reply With Quote
Hot Bodies TCX academygaz Electric On-Road 4798 09-09-2015 04:26 PM
HOT BODIES TCX SALE!!! Yokomo_Ant3 Australia For Sale/Trade 19 07-05-2012 07:25 PM
Best 1/10th scale electric car to buy WD40 Electric On-Road 68 04-18-2012 09:22 AM
What Have I Missed? Twism86 Electric On-Road 18 04-02-2012 02:33 PM
