Old 08-21-2013, 06:17 AM   #1321
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by tc3 racer sc View Post
ok I'm not going there about your child but when you work 12/14 hrs aday sentences an happen like that also I run 17.5
you'll probably will want to stay in the 84-88t range...anything lower and you'll run the issue of gears not meshing
88t is what I have on mine and it gives the biggest range of gearing
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 08-21-2013, 06:29 AM   #1322
CCDrift's Avatar
Trader Rating: 18 (100%+)
I am gathering that you are using a 64P spur gear, what size pinion have you used in the past as an average as I will be using a 21.5T for VTA. Sorry to drop a TC question in the TCXX post.
CCDrift is offline   Reply With Quote
Old 08-21-2013, 06:35 AM   #1323
k_bojar's Avatar
yes, its 64p
and I've run 55-58t pinions...I haven't run 21.5 in a while - but with the 25.5, I've run down to a 3.1-3.3 FDR
Old 08-21-2013, 06:43 AM   #1324
CCDrift's Avatar
yes, its 64p
Thanks for that info on the pinion, I am looking to shoot for a 3.5 FDR and will then test and check the motor/esc temps, have a good one.
Old 08-21-2013, 02:32 PM   #1325
tc3 racer sc's Avatar
thanks a lot
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 08-21-2013, 11:18 PM   #1326
Trader Rating: 20 (100%+)
thanks a lot
for me 96 64p gets me in the range of 17.5 and 13.5
I'm usually in the range of 3.6-4.4
goots is offline   Reply With Quote
Old 08-23-2013, 10:47 AM   #1327
Fred Hubbard's Avatar
In stock at Tower Hobbies: 67717 Hot Bodies Graphite Suspension Arm Set
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 08-26-2013, 01:42 PM   #1328
Originally Posted by Fred Hubbard View Post
When the spindle set going to be in stock
Old 08-26-2013, 03:58 PM   #1329
I don't know
Old 08-26-2013, 04:51 PM   #1330
Trader Rating: 77 (100%+)
I don't know
You taking over Hara's ride and start traveling the world?
TRF 418 - Team Powers 17.5, HobbyWing Stock Spec, Xpert servo
Xray T4 2016 - Trinity D4, HobbyWing Stock Spec, Ko Propo servo and radio
KustomRCGraphics.com (Best looking novice on the track)
goin2drt is offline   Reply With Quote
Old 08-31-2013, 11:11 AM   #1331
How is the TCXX for drifting? lol
"POW"
RC18T Factory Team
SC10 2WD Factory Team (Reedy 4900KV)
SC10 4x4 Team kit (MMP & 4.5 Reedy Sonic)
HPI Vorza 8th Scale E-Buggy
teamPOW is offline   Reply With Quote
Old 09-01-2013, 01:48 AM   #1332
Wynnum_Racer's Avatar
Hey Guys,
I've been having some rear diff breakage issues. I've found its only on one of our tracks here. Its a tight track with lots of start stop hair pins and the grip is fairly descent grip which adds to the issue.
I've only be able to get around 1-2 runs out of a new rear diff. Ive been building the diffs to kit specs with 2 shims either side of the gear with no sanding of the gears. I have also tried adding extra shim's however i didn't see any improvement.
The diff has mainly been stripping the main larger gear only 1 side at a time. I have however had one time where it was the back of the gear where the pin sits which stripped out.
Does anyone have any solutions to my problems or know of any other brand gears that will fit the the tcxx housing ? Any help would be much appreciated.
-Jason
http://www.youtube.com/watch?v=canY93sF15I
http://www.youtube.com/watch?v=NmxE9udKKdA
Everyone watch my movies on youtube
Wynnum_Racer is offline   Reply With Quote
Old 09-01-2013, 02:38 AM   #1333
Originally Posted by Wynnum_Racer View Post
Hey Guys,
-Jason
I can't think of a sensible reason as to why but if you've rebuilt the diff with new gears several times I would suspect there's something wrong with the housing. Gear diffs don't break on a regular basis.
markrobinson is offline   Reply With Quote
Old 09-01-2013, 03:55 AM   #1334
TryHard's Avatar
Hey Guys,
-Jason
Wynuum bumps Jason, I had a diff gear go on me on the snake last night, no rhyme or reason for it!
Old 09-01-2013, 04:48 AM   #1335
Korey Harbke's Avatar
You guys must have a really rough track. I beat the living crap out of my diff and it's still going strong. I've neglected to even touch it all season!!!
Apex RC - Prospec America - LRP - Roche RC USA - Awesomatix USA - Protoform - AVID - Xpert - Sweep - Slapmaster Tools - Hebiki Design Works - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Hot Bodies TCX academygaz Electric On-Road 4798 09-09-2015 05:26 PM
HOT BODIES TCX SALE!!! Yokomo_Ant3 Australia For Sale/Trade 19 07-05-2012 08:25 PM
Best 1/10th scale electric car to buy WD40 Electric On-Road 68 04-18-2012 10:22 AM
What Have I Missed? Twism86 Electric On-Road 18 04-02-2012 03:33 PM
